Old 09-01-2013, 02:48 PM   #1
1977 Argosy 24
Milltown , Wisconsin
Dometic 2652 no power to anything
I was installing an LED light inside my Dometic 2652 fridge. The LED came on for about 5 seconds and then went out. Now I have no power to the control, it will not light up showing status. I have power to the connector at the back and on the fridge side of the connector. Is there a fuse in the fridge somewhere? I can't imagine the LED drew more power then the stock incandescent bulb. What did I do to cut all the power to the fridge?
ventport is offline   Reply With Quote
Old 09-01-2013, 03:35 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
The led may have been hooked up backwards and shorted out blowing a fuse.
There may be a fuse on the control board but I'm not sure, there is a 12VDC fuse somewhere for the fridge probably by the converter.
Garry
Old 09-01-2013, 03:48 PM   #3
1977 Argosy 24
I found the fuse, in the back of the fridge. After I opened the power module there is a 3 amp and 5 amp fuse in there. I blew the 3 amp, put in a new one and all is good. So much for my LED panel.
