Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-28-2015, 07:24 PM   #1
Chelsea , Alabama
Dometic 2620 wiring question
I recently removed a 93 Dometic 2620 and replaced with a new 2620. the old one had three wires Pink, white, and Red. My new fridge only has two wire block for connection. Can someone please help. I figured the white was ground and the red was 12volt but what is the pink? where should it go? This is in a 1993 25' excella
I will try to upload pics of the old and new blocks to help describe what I am looking at.
this is the old. wires were pink, white, and red if not mistaken.
new frig block, where would the pink ignition lock wire go??
drjeff is offline   Reply With Quote
Old 10-29-2015, 09:17 AM   #2
Livingston , Texas
On your old fridge the pink wire was designed to be connected to the TV ignition switch so that a time delay would prevent the fridge from firing on gas when stopping for fuel. The new fridge does not have this function so the pink wire is not used.
pattydoug is offline   Reply With Quote
Dometic 2510 wiring question jrsygrl Refrigerators 4 01-21-2015 01:37 PM
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Garmin 2620 GPS unit wingfoot321 Electronics & Connectivity 1 09-11-2005 05:11 AM
Dometic 2620? Boondocker Refrigerators 4 08-29-2005 03:33 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
