Old 08-03-2015, 05:05 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Domestic Thermoster Repair Kit
Has anyone tried this mod?
Dometic Thermistor Repair Kit
MICHAEL
Old 08-04-2015, 09:59 AM   #2
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Haven't but have been wondering if my cooling problems are related to the thermistor.
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 08-04-2015, 11:29 AM   #3
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
I tried it. I couldn't tell that it worked any better than the OEM ones that you slide up and down on the fin. I can't recommend it.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 08-04-2015, 11:54 AM   #4
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Is there a way to test a thermistor?
Old 08-04-2015, 02:27 PM   #5
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I contacted Dave at the Cooling Unit Warehouse today. He recommended making sure the thermistor is on the top right fin. He said to make sure the tip of the thermistor is at the top and not just the plastic clip. He also suggested that if you suspect the thermistor to be defective to unplug it from the control board, which will take it out of the loop and keep the frig running solid. That is a good way to see if the thermistor is operational or not. Just some thoughts.
Old 08-04-2015, 03:07 PM   #6
2016 16' Sport
Corvallis , Oregon
Works well
Yes, I installed this thermistor kit on my stock Dometic 2351 fridge. It was previously always freezing the refrigerator contents no matter the position of the original sliding thermistor. This kit solved the problem.
I added a wireless refrigerator/freezer temperature monitor to keep tabs on things without opening the door.
FishermanDan is offline   Reply With Quote
Old 08-10-2015, 05:05 PM   #7
AWCHIEF's Avatar
Images: 33
Update on install of new adjustable thermistor. Ambient temps still in the high 90's. Before install temps ranged from 40 to 50 in the fridge section and 3 to 10 in the freezer. After install fridge temps 37 to 41 and freezer -3 to 2. Thermistor is set at mid range of adjustment. Sounds like an improvement in cooling performance to me.
MICHAEL
Old 08-10-2015, 06:53 PM   #8
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
AWCHIEF...does your refrigerator have a control to adjust temperature or is the thermistor the adjustment? My dometic (15 years old) has a 1-5 setting for cooling from the control board. I am adding fans to the condenser in the back but still wondering about replacing the thermistor. Glad this worked for you.
Old 08-10-2015, 07:36 PM   #9
AWCHIEF's Avatar
Images: 33
Only built in adjustment was sliding the Thermistor up and down on the fin. I noticed no change when doing that. New thermistor is a simple little stick on device with a screw adjustment for temp. I upgraded the fan several months ago. It seemed to help some. In these high temps it runs nonstop. I installed an on/off switch. It is so hot I have been leaving it on. The new fan just hums, not annoying to me at all.
MICHAEL
Old 08-10-2015, 09:12 PM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have been battling this problem for a long time. The kit sounds like a workable idea.
My next experiment was going to be the installation of an analog clock across the heater to record the duty cycle of the frig. The problem is I can't find an analog 110 volt clock. They are all gone.
I may just break down and install the thermistor kit
2004 Excursion 4x4
Old 08-10-2015, 09:51 PM   #11
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Ordered! thanks
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
domestic fridge problem nightowlhooter1 Refrigerators 7 05-11-2016 10:25 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Oldest Domestic Refrigrator wc3780 Refrigerators 6 06-17-2009 08:34 PM
Interesting take on Imports vs. domestic Denis4x4 Tow Vehicles 10 12-07-2006 05:52 PM
Domestic Shipping Recommendations? BeBop Shipping & Export/Import 1 12-10-2005 06:29 PM
