Old 07-07-2003, 07:30 PM   #1
1983 31' Excella
Bemidji , Minnesota
Send a message via Yahoo to nightowlhooter1
domestic fridge problem
Does anyone know why the upper freezer compartment would work and the lower fridge compartment not cool? I had it on elec not LPgas at the time. I would appreciate any suggestions.
Thank you
Linda
nightowlhooter1 is offline   Reply With Quote
Old 07-07-2003, 07:38 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Linda,
I'm no fridge expert, but it might help others that are if you post some info on model, age, etc. A bit more specifics might yield a bit better feedback.
Must be that time of year....fridge problems galore this week.
Eric
Old 05-11-2016, 10:11 AM   #3
2011 23' FB Flying Cloud
Tallahassee , Florida
Dometic Cooling
Linda, you may be experiencing a "cooling unit" problem. The first place that gets "cool" is the freezer. if you are not getting cold temp in the compartment then I suggest you have a technician further diagnose your problem.
1Cruzin is offline   Reply With Quote
Old 05-11-2016, 10:15 AM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If it cools correctly under LP then its not the cooling unit. Probably the 120v heating element needs replacing. It may not be pulling sufficient watts.
Kelvin
Old 05-11-2016, 10:20 AM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm not sure this applies as much to running the unit on electric power, because I suspect it's more of an issue with the hotter gas flame. However, I've seen a presentation on mods to the cooling unit (basically wrapping the appropriate part of the tubing in insulating tape) that sharply improved performance on marginal units. The refrigerant hits the freezer section first, and if all of the gas condenses to liquid in the freezer there's nothing left for cooling the refrigerator section.
The presentation was done by Tim Kendziorski, a former president of the VAC. I don't know if he has any printed or online material available to detail the improvements.
David
Old 05-11-2016, 10:25 AM   #6
richw46's Avatar
Lexington , Kentucky
Before today, these posts are from 2003. I don't think Linda still has a fridge problem.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-11-2016, 10:38 AM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That's correct. After 13 years, I'm sure that the problem has been handled in one way or another.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 05-11-2016, 11:25 AM   #8
Kevin245's Avatar
Records show that she last posted in August 2010.
Eleanor Roosevelt
dometic fridge problem nightowlhooter1 Refrigerators 27 08-19-2006 06:06 PM
Let's start with the Fridge.... 05ModPod Refrigerators 6 03-03-2004 10:01 PM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 02:46 PM
fridge on when travelling? sjptak Refrigerators 2 06-16-2003 10:54 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 09:21 PM
