Old 10-06-2015, 06:51 AM   #1
1989 32' Excella
Sharon Springs , New York
Do refrigerators have draintubes?
Bought a 1989 Excella that had the refrigerator replaced in 2007 according to the paperwork in the manual binder. Upon further inspection (after I bought it of course) I found a soft floor spot in bottom of the cabinet forward the refrigerator in the street-side corner going under the cabinet sideboard towards the refrigerator. The spot is about 9" in diameter and is dry and crumbly. I think it may have been condensation run off from either the original refrigerator or the newer one. The unit hasn't been used in a couple of years so before I go on the road next Spring would like to repair the floor, but first determine where the leakage originated so it doesn't continue to be a problem. Have been RV'ing on and off for a while and can't remember if there is a drainage system for the RV refrigerator like there is for the AC. Any advice would be greatly appreciated...
Regards,
James
Easyrider06 is offline   Reply With Quote
Old 10-06-2015, 07:03 AM   #2
dznf0g's Avatar
Oswego , Illinois
Most ASes do, but my old SOBs didn't. I can't say when AS started using a drain. My SOBs just filled the tray inside the fridge and had to be removed and dumped from time to time.
-Rich-
Old 10-06-2015, 08:08 AM   #3
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Look outside on the body in the close vicinity of the refrig. If like mine, there will be a plastic drain tube protruding.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 10-06-2015, 09:02 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine does.
MICHAEL
Old 10-06-2015, 10:10 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Mine has a drain plus an aluminum pan that covers the entire floor area directly under the fridge.
After you fix the floor, add a pan of aluminum.
AtomicNo13 is online now   Reply With Quote
Old 10-06-2015, 11:06 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
My Airstream refrigerator drains through the floor via plastic tubing.
My previous sob trailer drained through the refrigerator vent on the outside of the trailer via plastic tubing.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-06-2015, 11:21 AM   #7
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Mine drains through a plastic tube, it looks like it terminates in the exterior fridge access compartment. My old SOB hose went through the floor and drained over the tires. Great question for newer units, where will the water go on level ground?
DoublTrouble is offline   Reply With Quote
Old 10-06-2015, 11:26 AM   #8
1974 Argosy 20
Kooskia , Idaho
I have had 3 types of drain systems, all on Dometic refrigerators.
1. No drain at all, water goes into a plastic part under the fins which has to be periodically removed and dumped out manually.
2. A drain tube from the inside which dripped water into a metal cup which sat on one of the bottom refrigerator coils and by being kept hot, evaporated the water.
3. A drain tube with a small check valve in it which leads to the exterior lower access door and drips water out the door, down the side of the trailer.
So, depending on which refrigerator you have, and what Dometic was doing with the drain water at the time, you may or may not have any drain water visible at all.
Old 10-06-2015, 03:14 PM   #9
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
Our '69 AS has the original Dometic and it still runs like a champ on electric & gas. There is no drain for the unit to the outside. When we come home from a trip the freezer de-frosts right into the refrigerator itself (and all over anything that may be stored below the freezer). Fortunately we have not had a problem as long as we wipe the water out and make sure it is dry.
kdickinson is offline   Reply With Quote
Old 10-06-2015, 04:14 PM   #10
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
My 2001 fridge has a drain tube that runs down to the street side service access compartment. It ends inside the service area and water drains under the access panel door and down the side (exterior) of the trailer. It only drains when I shut it off and it defrosts. There is a little perforated end cap on the drain tube to keep out critters.
Nomad518 is offline   Reply With Quote
Old 10-06-2015, 11:38 PM   #11
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
My 77 RM100 drains into a metal cup that is heated by the coils and evaporates the water
4RXLA is offline   Reply With Quote
thermistor in Dometic refrigerators nickcrowhurst Refrigerators 4 05-02-2011 09:09 AM
Two Door Dometic Refrigerators Models, Parts, Data jaco Refrigerators 10 07-25-2009 04:12 PM
Airstream Dometic Refrigerators RECALL (FIRE HAZARD) bbop_96 Refrigerators 12 10-27-2008 10:42 PM
renewing old refrigerators eubank Refrigerators 20 12-24-2006 09:16 AM
refrigerators smallfry Refrigerators 5 07-27-2003 08:22 PM
