10-11-2019, 10:30 AM
1985 34' Limited
1986 34.5' Airstream 345
Sausalito
Did I kill our refrigerator?
Joe Flower here, husband of Jennifer Flower who has been active on these forums for years. Finally got my own account.
You may recall a long discussion the missing parts for our Dometic fridge — only to find out that the parts were not missing at all. So I went to test it on AC and on propane. At first it seemed to work some, at least making the freezer plate quite cold. I decided to leave it running overnight to see if it totally worked. In the morning, though, it seemed it had not worked at all.
That's when Jenni looked glum and remembered what had slipped her mind: These fridges must only be operated on level ground, because they rely on gravity rather than a pump to return the chemicals through the condenser.
Our 345 Classic MH is parked for now on a 6% slope at a friend's place.
You'd think such critical information would be prominent in the operating instructions printed inside the fridge on the bottom sill. Nope.
Obviously, the next step is to get it on level ground at some campground and plugged in to 30 amps, and test it again on AC and propane.
But what do the assembled think? Have I killed it? If so, how possible/easy is it to just replace the refrigeration unit and not the whole box? Any ideas?
10-11-2019, 10:33 AM
2013 20' Flying Cloud
Westerly
, Rhode Island
Our driveway is sloped just enough that if I don't lower the tongue right down to the ground the fridge does not work. I've made the mistake of not lowering it enough several times, left the fridge running overnight and the fridge is still fine. No worries.
10-11-2019, 10:44 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I had our refrigerator quit once because of a very sloped campsite. We cut it off and left it until we moved. It took 3 days for it to really run properly again. I am not sure that just hooking it up and trying it for 30 mins is a good test. It seemed to me that the best thing for ours to recover was to run it while we were pulling the trailer. It quit a couple of times but finally recovered and has worked for 8 more years now.
10-11-2019, 10:50 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Best approach is to go out for an hour's drive on some bumpy roads. If there is an "air block" that should shake it out of the pipes.
10-11-2019, 10:56 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
You may be just fine.
Get it nice and level, hook up to 120 VAC, turn it on in the "Electric" mode and give it 48 hours to cool down before you jump to any conclusions.
Remember the following:
(1) Ammonia absorption refrigerators accomplish with a tiny flame, or an electric heating element, what your household refrigerator accomplishes with a 1/3 horsepower electric motor and a good sized compressor. It just takes more time.
(2) Good refrigeration depends on very good ventilation and air circulation through the space between the back of the fridge and the inside wall of your Airstream.
(3) Never load the fridge with warm food and beverages. Get them nice and cold in your household fridge before you put them in the Airstream fridge. Only put already frozen items in the freezer. And again, give your RV fridge 48 hours to cool down before you hit the road.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
10-11-2019, 11:13 AM
2019 19' Flying Cloud
Canyon Country
There was a thread in Popupportal.com and someone had the similar experience. The solution was to move to a leveled ground and wait 24 hours before turning it on. It works every time.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
10-11-2019, 02:36 PM
Sag Harbor
, New York
I seem to recall that the owner's manual for our 1985 AS 25' was quite clear about needing to level the rig. At the time, I did not understand it.
Getting your coach level, and waiting 24 hours to start the fridge, will hopefully do the trick.
Good luck,
Peter
10-12-2019, 07:43 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The street in front of our house is more than a little off level (left to right). We pull up and plug in the evening before a trip. The next morning the fridge is nice and cold. We then load it up with all the "stuff" from the fridge in the house. So far it's worked fine for us.
Indeed if the trailer is there and it is being worked on, the fridge *might* get used longer term to chill an inventory of beverages .... burp .... That also seems to work out pretty well.
10-12-2019, 08:01 AM
Sag Harbor
, New York
Bob, your 2017 fridge is probably more tolerant of "off-level" than the OP's 1985/1986 fridge IMO.
Peter
FWIW
10-12-2019, 09:29 AM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Yep you did BUT it can be resuscitated! Go for a drive to have the refrig stabilized. Make sure you are level then test it our. You will probably find it's OK
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
10-12-2019, 09:41 AM
2005 31' Classic
Venice
Our new Dometic refrigerator came with a manual & states on the first page that it needs to be level ...
10-12-2019, 10:11 AM
2012 23' FB International
Woodstock
, Ontario
Ditto all those who say take it out and shake it up. The liquids need to get back to the lower portion of the system so the absorption process can get started again
Apparently if you leave a fridge running for a long time off level there is a possibility of some of the refrigerant component becoming crystallized or baked on the coils
Not likely a problem overnight....
JCW
10-12-2019, 11:50 AM
1985 34' Limited
Sausalito
Thanks for the responses
...they seem quite encouraging. In maybe a week we will take it someplace level, let it rest, then try it again. I'll report back.
10-12-2019, 01:39 PM
1966 22' Safari
Hilltop Lakes
If none of these very good suggestions work, look up a method of "burping" the fridge. It involves removing it from the coach and turning it first one way and then another to allow the gases and fluids inside to flow where they should be. Some say it works, some say it doesn't.
When I first got my Safari, I had the fridge cooling unit rebuilt, reinstalled it, and the fridge worked fine. Then it sat for about a year (while the warranty on the work ran out) before we tried it again. It didn't work. We tried the burping routine, because we figured we had nothing to lose. It worked, and the fridge has worked ever since.
But, it is possible to destroy a cooling unit by running it off level, because my trailer's PO had done just that. If that's your case, there are several places that can rebuild just the cooling unit. No reason to throw away a good fridge that fits your unit, and a cooling unit rebuild is cheaper than a new fridge by a lot.
10-12-2019, 01:46 PM
Sag Harbor
, New York
Sounds like a good plan. Moving the coach will be the functional equivalent of Mimi's recent "burping" suggestion IMO. In the meantime, any chance of getting the coach reasonably level right away?
Peter
10-12-2019, 02:59 PM
Albuquerque
, New Mexico
I Too Have Burped
When I renovated a 1976 Sovereign in 2005-2006, I removed the fridge that seemed not work any more. Since I had ordered a new one, I decided to try burping under monitored, test conditions while recording the results.
I recorded the experience somewhere on these fora.
In summary, burping worked great and had the freezer freezing (0-4 degrees F)
and the fridge cooling (32-35 degrees F).
Can't vouch for long term outcome since I had already installed a new unit and gave the old one away.
10-12-2019, 05:36 PM
1987 25' Sovereign
Fort Collins
Could be wrong, but I think the “level” requirement is fore-aft rather than side to side.
Alumacoot
“We are confronted with insurmountable opportunities.”
10-12-2019, 07:38 PM
Albuquerque
, New Mexico
You are correct. Level fore and aft is critical to the ammonia evaporation and absorption refrigerator.
Level side to side is for creature comfort and frying eggs.
10-14-2019, 11:10 AM
1985 34' Limited
Sausalito
Burping and its functional equivalents
We are planning to move it in three days. In the meantime, we are keeping the fridge off. Burping may not be necessary.
10-14-2019, 08:59 PM
1986 31' Sovereign
Miami
Before you do any “burping”, get it reasonably level and turn it on for 12 hours.
I suspect all will be well.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
