Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-15-2019, 07:04 AM   #21
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
The downside risk is that if the fridge is operated off-level long enough, one can get ammonia crystals in the lines, and that would indeed kill the fridge. Hopefully, that has not happened.l!
Old 10-15-2019, 09:26 PM   #22
Steamguy's Avatar
2024 19' Caravel
Washougal , Washington
There is a lot of good advice here. May i add my two cents' worth, from many years of experience with both older and newer fridges...
As to 'burping', there used to be a last resort of pulling the fridge and setting it on its top for a day, then reinstalling it and allowing it to sit for another day, before starting it... Often worked...
But the smartest thing I ever saw is what i used to see my Dad do: put a bullseye level in the floor of the fridge, as he was leveling the trailer. He always said, "You don't know if the fridge was installed plumb or not."
To prove him right, we had one trailer where the fridge was installed a half bubble off from the floor.
Hope that helps.
Steamguy is offline   Reply With Quote
Old 10-16-2019, 12:19 PM   #23
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Your Dad Was Correct
Hope that helps.
I always double check the fridge itself after I level Airstream.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-23-2019, 12:11 PM   #24
1985 34' Limited
1986 34.5' Airstream 345
Sausalito , California
It worked!
So I followed the first (and easiest) level of advice here: Drive it around for a while to shake everything up, then park it someplace level and turn it on.
We drove it some 60 miles in several different spurts, then parked it in front of a friend's on a street that is level fore-and-aft, drove the doorside wheels onto some blocks to mostly level it side to side. The next morning I turned it on using AC power. In a few hours it was quite cold, and has been working fine ever since.
Thanks for the help!
JoeFlower is offline   Reply With Quote
Hello all, Our 'Valentine' is the love of our life, and fast becoming our 24/7 addict errol108 Member Introductions 6 10-14-2019 07:04 PM
If I Did a 'Blow Out' Of the Water Lines and No Water Came Out Did I do it Wrong? mrpettit Winterizing, Storage, Carports & Covers 15 12-03-2014 09:51 AM
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 01:01 PM
Kill switch for electric jack ? remark83 Jacks, Stabilizers, Lifting and Leveling 9 06-24-2003 10:14 PM
Kill A WATT™ 53flyingcloud Our Community 6 06-20-2003 12:08 PM
