Old 04-04-2006, 04:36 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
DC Fridge
Is anyone running on DC for the fridge while on the road.
I am about to get a fridge for "The Bat Cave Express". I like the idea of a three way but I don't see on the dometic site how much they draw (RM2663). They have a 30amps inline fuse and call for #8 wire for 25 feet from the battery. However, how much can I expect my truck (2005 2500 Duramax) to put back into the battery while going down the road give the truck wiring which I think may be #12 or #10. Will I be drawing down the battery. Would an inverter to the AC side of the fridge be a better option?
Over59 is offline   Reply With Quote
Old 04-13-2006, 10:47 PM   #2
1960 24' Tradewind
santa barbara , California
Hello Over59,
Lew will probably have your correct answer ,but it does depend on ,as you say ,the draw .from the fridge .Im sure a good rv store with a dometic catalog could tell you. now I am looking at some norcold fridges in my rv catalog from biils rv .It shows a n300 3 way ,draws 11.7amps @12v dc. its a 1.7 cu.ft. The largern510 5.5 cu. ft draws.14 amps at 12v dc, the big n400 3 way draws 14.2 amps.It appears that depending on your fridge size ,you will can draw 11 amps to 14 .Sorry no dometics are listed.Run the fridge on lp if it allows .My 60 trdwnd has a dometic not new,stays on ,always has.I have had no trouble and no 12v troubles.I would believe that it would work just fine with you chevys charging system .Your 10 gauge charge wire is fine. they want the power line from the fridge to the batteries to be 8 gauge ,but then it wont be 25ft away from the batteries will it?Now if you do the inverter the a/c draw is only about 2 amps ,even there big rv fridge is 2 amps seems that idea is a better one . 14 amp dc draw is decent size,youll note that most auto and truck fuses are 15, 20, and 30 amps (power windows or a/c on the 30 amp)tail ,stop signals interior lamps ,dash lamps etc. are on 15 or 20 amp fuses This is all for your comparison of what the fridge can draw. 14 amps is at the limit within 1 amp of blowing a 15 amp fuse but fine with a 20 amp fuse.I say that it will work , after all when driving at night your lights are all on, headlights on, wipers in the rain and the charging system handles all of that including charging the rv batteries and all the lights on your coach.The batteries should be fine and stay in a good state of charge. Now if you have the tow vehical umbilical unplugged and have the fridge going ,there will be power loses of course .you could and should install a 12volt amp gauge in the wireing to monitor your battery loads when power devices are on , Only then will you be able to see how much each appliance draws ,you can turn each device or appliance on 1 at a time and see.Long post Im sorry ,I hope this can help you.
Scott
scottanlily is offline   Reply With Quote
Old 04-14-2006, 12:16 AM   #3
My Dometic takes 22 amps on 12 volt, which is too much for the charging system on my Dodge 3/4 ton truck. You will find several discussions on this by using the search facility. One is at http://www.airforums.com/forum...t=nick+dometic
These refrigerators rely on a heat source to boil the internal fluid. The same amount of heat, and hence, energy, will be required if you use an inverter for 12v/120v conversion or 12v direct. In fact, because of the % efficiency of the inverter, you would use slightly more.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-14-2006, 06:00 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Over59,
I think that the DC fridge was a bad idea from the start....way too much amp draw for most applications and you have to have a really big cable to get those little amps back to the DC heating element. As far as your Dodge powering it.....depends on the size of your alternator and the associated demands of your TV. I think that your idea of an inverter is a much better way to go. Use the +12VDC charge line that runs through your 7-way plug to keep your batteries up and the inverter will put out enough to power the fridge on AC. If you go this way, I would add a second battery (if you don't already have 2) and size the inverter to have twice the capacity you need to power the fridge. I personally like the Xantrex line of inverters. They have a huge selection of models and the prices have come way down for the lower wattage units. The spec on the fridge should tell you the wattage requirements of the AC heating element.
The other benefit to going 2-way is you have a much bigger selection of units. There are very few 3-ways made any more .
Old 04-14-2006, 09:20 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I remember running the fridge on battery on my old Hi-Lo while towing. On our first long trip out we drove from STL to just west of Nashville Tn. It was close to 95 degrees so I'm sure the fridge was pulling a goodly amount of amperage. Well, we get to our site, I unhitched and pushed the button on the Hi-Lo to raise the top up. All I heard was a groan with little lift. I quickly diagnosed that the battery is dead. To make matters worse, even though I plugged into the electrical outlet at the campsite, the charger in the trailer wasn't putting enough voltage back into the battery fast enough, to run the sizable motor that was used to power the hydraulic ram which was connected to the lift cables. It ended up I turned the car around and used my jumper cables to jump the trailer battery and get enough voltage to raise the top.
When I went to diagnose the original problem I found that the 12 volt feed contact in the trailer plug was somewhat corroded and therefore not providing a good clean connection. From that point on I learned to make sure the outlet on the TV and the plug on the trailer were clean before going on a trip. Bottom line you have to have a good amperage flow from the TV to the trailer battery to keep enough charge in the battery to support that DC refrigerator. A dead battery is not the end of the world, unless you are boon docking, but obviously it will put a damper on the life of a deep cycle if you continue to discharge it fully.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-14-2006, 10:32 AM   #6
Images: 59
I believe that most TV charging systems cannot push enough power to the house batteries to run a Dometic.
If you look at the voltage drops from the alternator, through an isolator, through 20 to 40 feet of #10 wire, and a corroded umbilical cord plug, I think you would be lucky to have 12.5 volts at the house battery. That's not enough to charge the battery. You'd need to put a lot of thought into design and wire sizes to make it work efficiently.
If you want a regular compressor refrigerator that runs on 12V and uses very little (6 amps) juice, you need to buy a NovaKool. Bring your checkbook!
Old 04-14-2006, 10:53 AM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
DC Fridge
The first RV that I purchased new came with a 3-Way refrigerator in 1980. Since then, I have always insisted upon the 3-Way refrigerators in my RVs -- it was something of a relief when it came time to replace the 2-Way refrigerator in my '64 Overlander with a modern 3-Way Dometic. In the 25+ years that I have utilized these 3-Way refrigerators, I have never had a problem when traveling -- I always remind the dealer about the 3-Way refrigerator when a "new" tow vehicle is prepared for towing -- and as Jack mentioned, I also keep close tabs on all of my 12-volt connections. Most of my travel is limited to the hot, Midwestern summers, and often I am on the road for seven or eight hours with no problems. I very rarely boondock as air conditioning is a requirement during Midwestern summers so the coach battery is replenished each night by the power converter. My Overlander also has solar panels, but even with my prior coaches that relied only on the house battery I didn't experience any problems with battery capacity.
With certain tow vehicles, particularly my pre-1980 Chrysler product, it was necessary to adjust the voltage regulator output. I haven't encountered any problems with my GM tow vehicles (1975-1999) once they have been properly wired.
I know based upon my past experiences, the 2-Way Dometic in my Minuet is history the first time it gives me any trouble; and its replacement will be a new 3-Way Dometic.
Good luck with your research and refrigerator selection!
Kevin
Kevin D. Allen
AIR #827
Old 04-14-2006, 07:41 PM   #8
1960 24' Tradewind
Hello everyone,
22amps is quite a draw , the new norcolds I posted about didnt come close to that ,at least their claim in the specifications. Jcanavaras problem was absolutly the corroded 12v feed wire . the batteries most likely were not getting much of any charge ,how old and how fully charged were they to begin with? I would also recommend a colehersey (brand name) solenoid instead of an isolator (those blue units) They are used in many heavy duty applications to isolate batteries and keep them charged up. I use one on the travelall to provide charging power to the trailer house battery , i have 14volts present the battery ,charging from the travelall.Turn off the ignition and the solenoid shuts off conection is terminated, the house battery cannot draw or drain the tv battery.The isolator terminates the connection also ,but those isolators take 1volt of current to operate ,Just put a voltmeter on your outlet terminals ,there will only be about 13.00 to 13.50 volts present easy to test and its a problem. that extra volt is lost to your tv battery also .The solenoid is used all the time with dual battery installations .It is enough loss to cause poorly charged batteries . the best rate of charge you need is about 14.00 to 14.50 and no more Go higher and overcharging is a result .Bad for the batteries .We have all heard about dead rv batteries ,blue isolators ,you need that lost volt!
Scott of scottanlily
Old 04-14-2006, 08:46 PM   #9
lewster's Avatar
The best company I have found for isolators and separators (depends on your alternator and the application) is Sure Power in Oregon. They are direct manufacturers and their tech dep't. is excellent. Give them a call or check them out at www.surepower.com.
Old 04-14-2006, 10:58 PM   #10
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
There-in lies the heart of the problem. The 7-way flat trailer connectors are rated at only 20A continuous. Add to that a little dirt, corrosion, and undersized factory wiring, and it's bound to fail.
A much better ( unfortunately non-RV standard) solution are the 7-way round connectors, rated at 30A continuous, and 80A peak.
I use them in my rig, as my hydraulic brake requires 30A capacity to conform to factory specs. I also beefed up the factory charge wire, by running a second, 10ga parallel to the 12ga in the loom. I have excellent, and trouble free charging and energy transfer now, surely able to supply 20or so amps to a 12V fridge element. My burb has a 140A alternator with teh factory tow package, if I'm not mistaken.
I think the problem lies not in the 3-way fridge, but rather in the lack of proper preparation for it by the RV owners that had bad experiences with them. After all, 22A is not that much, certainly not more than running headlights and foglights at the same time.
Uwe
www.area63productions.com
Old 04-15-2006, 05:32 AM   #11
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
We have a three way in Chummy and use it all the time. My understanding from Dometic is that it will not cool the unit on DC but will help maintain the cold during the driving times. I was also told that Dometic will no longer be making a three way.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 04-15-2006, 10:03 PM   #12
1960 24' Tradewind
Hello uwe,
The 22amp is is a fair load ,most of your fuses are 15 or 20 amp. You have main fuses to handle your headlights ,alternator ,high load items ,they are 30 ,50,or 80 amp .Your correct about the trailer connector rating,not surprising as 22 amps is a decent load and your 20 amp fuses blow when they are exceeding the rated amps.The ecm is on a 20 amp fuse in the fuse center under the hood ,most power draws in the vehical dont exceed 20 amps,except the a/c compressor and your brake system . what kind of master cylinder setup operates those hydralic brakes?Your fuse for that 30 amp brake load has to be a 40 0r 50 amp .
scott
Old 04-15-2006, 10:12 PM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Originally Posted by scottanlily
Hello uwe,
scott
The hydraulic brakes are operated by an electric/hydraulic actuator. Basically, an electric motor and a hydraulic pump, coupled to a small control unit inside the motor part. It is conected to the trailer batteries and charge line via a 30A fuse as per Dexter's instructions.
Uwe
Old 04-18-2006, 09:55 PM   #14
Over59's Avatar
Images: 37
Have a new Norcold N600 3 way. I'll see what the trimetric says is draws once it's in the trailer. Figure I'll run a dedicated fused #6 charge line back from the alternator or other those big labeled lugs with a switch and a separate plug hookup to the trailer. Have to find a plug/Socket set that will work. Think I'll put a relay on the trailer side so the fridge cann't draw battery juice if the alternator isn't putting out. Not sure how to do that but seems like the right approach.
Thanks for the input.
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
RV Ideas to consider ??? FrankR General Repair Forum 18 09-18-2002 10:43 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
