Old 04-30-2011, 03:08 PM   #1
1974 29' Ambassador
1971 31' Sovereign
Klickitat , Washington
Cracks in refrigerator lining
The liner in my 40-yo Dometic is just starting to show a few cracks. Don't want to replace the old girl, is there some sort of modern goop that will stabilize the cracks? Or is there another easy fix?
jacqueg is offline   Reply With Quote
Old 04-30-2011, 04:32 PM   #2
2010 27' FB Classic
N/A , Texas
Yes there is a product that will work. I used these products on my home fridge with very good results.
Whirlpool makes a repair kit for fridge liners. P/N 482395 for cracks. It's actually a special tape with adhesive on it. Then they sell an electrical grade silicone sealant P/N 482338 for holes.
To use the tape for the repair you must drill a small hole at each end of the crack so it does not travel any further then apply the tape.
I used it a few years ago, both products part numbers I mentioned are bright white. You could check for other shades or colors available for what you need.
I bought the items at FSB Appliance Care, 2801 Airwest Blvd., Plainfield, IN 46168
This stuff was a little pricey for what you get but, it does work on fridge liners.
Maybe Dometic has similar products for repairs.
Old 05-02-2011, 05:13 AM   #3
1974 29' Ambassador
1971 31' Sovereign
Wink
Thanks Bluto, I'll look for it!
Old 05-02-2011, 07:42 AM   #4
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
You may try a goop called "G-Flex.
see the application on our refer. liner.
62 Safari Airstream Renovation
good luck
Indy
indy is offline   Reply With Quote
Old 05-04-2011, 06:36 PM   #5
1974 29' Ambassador
1971 31' Sovereign
Indy, that is a beautiful repair.
Where did you get the G-Fleax? and what did you use to bridge the hole?
Old 05-05-2011, 06:05 AM   #6
indy's Avatar
1962 22' Safari
Images: 22
I used some fiberglass cloth as an added filler and for structural strength.
I know this may sound funny but I used the duct tape to form the mold shape.
then mix the goop and away we go.
hope all go'es well
Indy
NRS is where i got mine comes in thin or thick I used the thick.
http://www.nrsweb.us
Old 06-30-2011, 02:47 PM   #7
Summerfield , Florida
What kind of problems might happen if the cracks are not patched?
waypylant is offline   Reply With Quote
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
Acquired ambivalence sgldwright Member Introductions 11 02-19-2011 04:09 PM
