Old 07-16-2011, 10:56 AM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I have been learning more about my fridge also and I just tried this trick this AM to get a look at the top coils of the unit.
I used a video camera with a swivel screen and an LED flashlight and took pictures and video of the upper coils. It was fairly easy to see the screen and move the light for the best illumination. I can't share any pics cause I left one cable at work, we'll see what they look like in detail later.
Cold food, safe + good. Cold brew = great. More to learn.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-16-2011, 12:45 PM   #16
richinny's Avatar
2011 34' Classic
Originally Posted by DEITZ645 View Post
Rick,
Where is there an LP pressure gauge on the old Excellas??? We have an '87 34' Excella 1000 and we don't have one.
on the 94 it is on the back of the fridge. maybe it was an add on?
Ricky
Old 07-16-2011, 01:54 PM   #17
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have exhausted every approach except for testing the propane pressure. I ordered a manometer this morning. Hopefully, I will find poor gas pressure.
I get an occasional red light on the water heater, as well. That could be the same problem.
My previous refrigerator was not great on gas, either and the regulator is the main common thread between the two. The old refrigerator was 1 1/2 cu ft smaller than the new one and was just barely acceptable on gas from day one. Perhaps the new and bigger box was the proverbial straw that broke the camel's back. I always blamed the former refrigerator poor gas cooling on poor airflow without ever having checked gas pressure.
John W. Irwin
WBCCI #9632
Old 07-18-2011, 04:09 PM   #18
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
John,
Our trailers are only a year apart in vintage. Does yours have the luann plywood baffle to reduce the dead space between the trailer's inner walls and the back of the refrigerator? Ours does and I'm thinking of installing the cooling fans to circulate more air up the "chimney" to boost the refrigerator efficiency.
My water heater is also a little persnickety. It's a gas / electric model and it doesn't get run too much on gas, but when I need it on gas, it rarely starts on the first go round. It tries three time before the little red light comes on and you have to reset the switch. I thought the gas pressure would solve the water heater problem too, but it didn't. It's still touchy when it tries to light. I have cleaned and repositioned the burner tube, ignitor, and thermocouple sensor with no improvement. Anybody have any other ideas?
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-18-2011, 04:14 PM   #19
DEITZ645's Avatar
Rick,
That looks like an after market addition...but a good one. I don't know why they just don't make the regulators with the gauge attached. It would save us a lot of work
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-18-2011, 04:43 PM   #20
Pahaska's Avatar
Hays County , Texas
John,
Yes, mine has the baffle. It starts on the first try.
I can recommend the Snyder fan kit that I have on mine for $60 shipped. It greatly improved cooling in my old refrigerator and I moved it to my new one where it keeps mid-30s inside with 102 temp outside on AC operation. You need to pull the refrigerator out to install the kit on the fins, but because it is directly on the fins, it is much more efficient than fans mounted elsewhere. I can barely hear mine running.
John W. Irwin
WBCCI #9632
Old 07-18-2011, 05:11 PM   #21
DEITZ645's Avatar
My trfrigerator starts on the firsat try, but the water heater takes gives us some trouble sometime.
I like the idea of the Snyder kit, but I don't relish the idea of having to pull the refigerator.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-18-2011, 05:38 PM   #22
DEITZ645's Avatar
Snyder Cooling Fan
OK, I ordered the Snyder kit which means I'll have to bite the bullet and pull the refrigerator out onto the kitchen floor. The removal looks simple enough (gas line, 12V wires, 110V plug, two lag bolts on the back, and 5 screws around the front trim oanel). But my question is how heavy is the refrigerator. It isn't that high off of the floor, but I want to know what I'm up against so I know how many friends to invite over for a beer.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-18-2011, 09:34 PM   #23
Pahaska's Avatar
Hays County , Texas
I pulled mine by myself and I am 78 years old. I simply built a wood box the height of the woodwork to fit under the refrigerator and slid the fridge out on the box after disconnecting the gas and electric.
I didn't have to pull it out completely ... when it was out far enough that I could swivel it enough to reach behind, that was good enough. The kit went in in minutes. Loosen two screws, slip the plenum in place and tighten the screws. Then clamp the thermostat to the pipe above the boiler. The wires simply hook in on the terminal block where the fridge gets 12v and ground. Total time, maybe 30 minutes.
The Snyder kit is so much more efficient than other fans that, to me, it is a no-brainer to go that way.
John W. Irwin
WBCCI #9632
Old 07-19-2011, 05:55 AM   #24
DEITZ645's Avatar
John,
BRILLIANT! Some time I get so wrapped up in the project / problem that I can't see the forest for the trees. I have a hydraulic lift I use for detailing and storing my motorcycle. That will work perfectly to support the refrigerator as it is slid out from the enclosure. ow all I have to do is wait o nthe UPS man to show up.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-19-2011, 07:46 AM   #25
DEITZ645's Avatar
It's A Small World
I just got through reading all the pages on the Snyder Refrigeration web site and found out they aren't even two hours away from where we live. I could have driven up and picked up the cooling kit.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-19-2011, 08:22 AM   #26
Pahaska's Avatar
Hays County , Texas
I might add that I used four of the slick plastic moving pads between the wood box and the vinyl floor. That made the box slide beautifully once the weight of the refrigerator was on the box.
A couple of photos of my fan installation can be seen on my Classic 28 thread at post #287.
John W. Irwin
WBCCI #9632
Old 07-20-2011, 04:13 PM   #27
DEITZ645's Avatar
Water Heater Problem Solved
I replaced the spark ignitor on the Atwood electric/gas water heater and the water heater has been igniting and staying lit on the first spark.
I am waiting on the Snyder fan kit to arrive. Hopefully it comes soon, because we're heading out boondocking 07/29/2011.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-21-2011, 11:48 AM   #28
Pahaska's Avatar
Hays County , Texas
Low gas pressure!
I received the manometer by UPS yesterday afternoon. This morning, I filled it with water and hooked it up to the test port on the refrigerator. The pressure was only 8 3/4" of water column.
It took quite a bit of turning on the regulator diaphragm to get the pressure up to the proper 11". The flame is now noticeably larger.
I have it running on gas now with a starting temperature of 35 degrees inside. It is supposed to be about 99 degrees today. I'll check in the morning and see if it is holding temperature now.
John W. Irwin
WBCCI #9632
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
27FB AC cooling problem pendletonkm 2011 - 2015 International 61 02-08-2012 12:42 PM
Frozen gas valve robert claus LP Gas, Piping, Tanks & Regulators 6 05-10-2011 07:18 AM
