Old 06-22-2015, 08:43 AM   #1
surrey , British Columbia
Cooling fan
How do I change the cooling fan outside of my flying cloud fridge?
jillya is offline   Reply With Quote
Old 06-22-2015, 09:41 AM   #2
richw46's Avatar
Lexington , Kentucky
How do you know the fan is bad? There is a button switch connected to the fan, sits on the cooling fins of the refrigerator. If the fins are cool (below 85*F) the fan won't engage; it's not needed. I would check that first.
If the button switch is bad and won't close the circuit there's just 4 screws that hold the fan in. Disconnect the wiring and remove the screws. The fans are 12vdc and you should be able to get one locally, even at a computer store, they are similar to the fans used in some computer equipment. You can also order online. Put the new one in with the 4 screws and plug it back in. Again, it won't engage unless the button switch is closed or you use a jumper wire to bypass it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-22-2015, 10:07 PM   #3
Fridge fan
Thank you very much
For Sale: Snyder Fridge cooling fan kit grantb4 Refrigerators 0 11-02-2009 09:09 PM
Dometic cooling fan noise dlb435 Refrigerators 10 06-24-2009 07:48 AM
cooling fan ?? kepko Land Yacht/Legacy Motorhomes 4 08-10-2008 10:50 AM
Auxiliary Electric Engine Cooling Fan cooperhawk Airstream Motorhome Forums 8 02-25-2007 07:18 AM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
