Old 11-29-2009, 08:23 AM   #1
2008 27' International FB
1999 19' "B" Van Airstream 190
Marietta , Georgia
Changing refrigerator surface so magnets stick
Has anyone made any changes to the front surface of a Dometic refrigerator with something that magnets stick to? We have a ?stainless steel? front now but I want to change it as we're gathering a large magnet collection. Has anyone done this? Any suggestions?
karenjude is offline   Reply With Quote
Old 11-29-2009, 08:42 AM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
My guess is your "stainless steel" is really plastic that looks the part but does not act it. Is stainless steel magnetic? The answer is yes, the magnetic properties of stainless steel are very dependent on the elements added into the alloy, however, the steel elements make the alloy magnetic! So why plastic, less $$$ and lighter weight. The "fake" stainless steel on your refrigerator is a mylar coating over the plastic. So to truly answer your post you must replace the "fake" with real, however due to the added weight and cost, I would search for a more magnetic place.... Vin
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 11-29-2009, 09:03 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Is stainless steel magnetic? Many are not; eg, a magnet adheres to none of the appliances in my kitchen.
My Safari is in storage and I won't venture how readily the front panel can be replaced. I don't believe my fridge front panel is plastic. Keeping an open mind there... Do they even have any avocado enameled steel any more?
5 meter Langford Nahanni
Old 11-29-2009, 09:32 AM   #4
vinstream's Avatar
Most kitchen appliances are made with Austenitic stainless steel that are generally a non magnetic in nature... Austenitic stainless steel is used in Higher end Kitchen Appliances because you can "cold form" them with out damaging the metal. These types of stainless steel are made with large amounts of Nickel and the chemical properties of large amounts of Nickel mixed with steel make Austenitic stainless steel non magnetic! Sorry for any confusion!
www.VINSTREAM.com
WBCCI # 1962
Old 11-29-2009, 09:45 AM   #5
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Try a magnet. Magnets will stick to my "Stainless" refrig door. The lower content of nickel the more likely it will hold a magnet.
Michelle TAC MT-0
Sarah, Snowball
Old 11-29-2009, 09:48 AM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I have changed the panels on my Dometic but not to a magnet sensitive material. I took out the cheap fake wood and put in a mahogany veneer that closely matches my original interior wood. Thought about putting in a steel surface for magnets but am using the oven door for that.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-29-2009, 05:32 PM   #7
Lily&Me's Avatar
Normal , Illinois
The surface of our frig is, I think, a brushed aluminum which will not hold a magnet. Maggie LOVES magnets. Problem recently solved with a sticky-backed, brushed metal wipe-off calendar now adhered to the bathroom door in our Interstate. We have to have a calendar to keep track of what day it is and appointments/events---the brushed metal surface looks very nice in our interior---and the generous surface holds our magnets! We got this at Office Max or Office Depot.
Old 11-29-2009, 06:32 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I didn't on mine but did help a buddy do his. We use a piece of Kynar Coated 26 gauge steel that was leftover from a project. It happens to be Pizza Hut Red
Aaron
WBCCI #XXXX AIR #2495
Old 11-29-2009, 08:21 PM   #9
JimGolden's Avatar
1977 31' Excella 500
Just make your own panels. It's not hard. I made mine from thin gauge sheet brushed aluminum I had left over from another project (Dometic wanted $90 for the stainless look panels....too $$$ for me....I made mine for free). Hit them with a power buffer and they look great.
But anyway, you could make your's out of plain old sheet steel; something like the 26 gauge mentioned above. Cut it to the proper size, clean it up, polish it up, then degrease it and clear coat it. Then carefully slide it into place.
If you don't clear coat it, it'll rust on you. You could just wax it periodically; which might actually be better than a clear coat. But a good clear would work. Or, if you don't really want silver, get some sheet steel that is enamel coated.
Good luck!
- Jim
JimGolden is offline   Reply With Quote
Grease on brake magnets lbrodsky Brakes & Brake Controllers 43 11-25-2006 07:06 PM
Electric wire splice on magnets LI Pets Brakes & Brake Controllers 15 09-02-2006 11:45 PM
Need a couple of old brake magnets Excella CM Brakes & Brake Controllers 1 07-02-2006 07:47 AM
magnets worn remcolent Brakes & Brake Controllers 15 03-19-2004 08:49 PM
Brushed Surface Help Randy Johnson Ribs, Skins & Rivets 2 05-05-2003 04:57 PM
