Old 08-27-2010, 07:47 AM   #1
nevada , Nevada
changing fridge vent
Have noticed a lot of airstreams with two side vents for the fridge. I assume these were not original? I installed a new dometic fridge but the exhaust flows throughout the top cabinets before leaving through the roof vent. this doesnt seem safe to me. open a cabinet door and get a wiff of exhaust.
seems like a big chore to build a secondary wall all the way up. do most people throw in the towel and and block off the top and and seal the top of the fridge and then cut a hole in the side and install a vent.
wolfpack is offline   Reply With Quote
Old 08-27-2010, 09:30 AM   #2
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Thumbs down Older Fridge Setup
[QUOTE=wolfpack;887722]Have noticed a lot of airstreams with two side vents for the fridge. I assume these were not original? I installed a new dometic fridge but the exhaust flows throughout the top cabinets before leaving through the roof vent. this doesnt seem safe to me. open a cabinet door and get a wiff of exhaust.
Take pictures of what you have so we can lend assistance. Hacking away at the shell is a dicey proposition.
arcamedies is offline   Reply With Quote
Old 08-27-2010, 10:06 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Sounds like you're missing a piece of the original fridge vent. It should not be venting into the back of the cabinets before going out the roof - it should be completely sealed so no exhaust can get into the interior space.
Yes, pics would help.
Old 08-27-2010, 11:14 AM   #4
Images: 59
Under certain conditions you can use two side vents. I don't know the exact conditions (minumum separation between the vents for good draft) but I remember seeing it in the installation manual for my new Dometic.
In any event, if you do the side vents, I would put in a fan or two to help the air flow.
Old 08-27-2010, 11:21 AM   #5
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
In 59 and at least 60 (and probably before) they litterally depended on the fact that heat rises and didn't enclose the flu. Most just had a little aluminum "flap/shed" above the combustion air outlet in the shared cabin airspace, not even inside a cabinet.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 08-27-2010, 12:54 PM   #6
2007 25' Safari FB SE
Eureka Springs , Arkansas
Our coach had been modified for commercial display use with the refr. and cabinet removed.
I built a new cabinet to house the ref.
My RV mech made a point to tell me to seal cabinet/sidewall joints to keep fumes and hot air in the cavity. The cabinet I built is similar dimensions to stock, with door at top. I did put a removable panel at the top to access vent clean out, per mechanics recommendation. Entire refr. space is now sealed.
I don't see how a vent in the side would help much as I would think a lot of hot air would still flow up to the ceiling.
I would check into modifying the cabinetry to enclose that space, and install proper venting.
triplenet is offline   Reply With Quote
'64 fridge vent putback Roof Vents, Skylights & Fans 11 09-20-2010 02:30 AM
Changing the look of a Dometic fridge? 72Blazerod Refrigerators 12 10-22-2009 12:03 AM
Adding a fridge vent Safari Tim Refrigerators 15 02-25-2007 01:13 PM
Fridge Vent CampSayler Refrigerators 14 04-19-2005 03:11 PM
Vent under Fridge on 66 Caravel JMoy Refrigerators 4 09-08-2003 10:42 PM
