Old 10-03-2011, 12:19 PM   #1
1981 31' Excella II
New Market , Alabama
Can you use gas on the road?
I was wondering if you can run your Dometic on gas while towing? The last camper I had, the pilot light would blow out. Airstream probably has things figured out a little better. The Dometics run best on gas and it is all you have when towing unless you have a generator. My old camper fridge would let you run on DC but it would kill a battery even while hooked to the tow vehicle.
Perry
Old 10-03-2011, 12:22 PM   #2
Perry
I run mine. It never blows out. There is a warning message to turn the refrigerator off when fueling.
handn is offline   Reply With Quote
Old 10-03-2011, 12:38 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
You can and most people do. There are a few people who consider it unsafe or who find it unnecessary because they are rarely on the road for more than an hour or two.
Old 10-03-2011, 12:45 PM   #4
1981 31' Excella II
Well I am probably going to be on the road for about 8 hours so it might be an issue. It is a good idea to shut it off when refueling. It is amazing how many yahoos you see that leave their car running or smoke while filling their gas tank. A while back I brought it to the attention of the attendant that the fire extenquisher had been discharged. I got this deer in headlight look, like who cares.
Perry
Old 10-03-2011, 12:47 PM   #5
1974 Argosy 22
1976 Argosy 28
1972 Argosy 24
Chico , California
I run mine on the DC, my tow charges the system as I go. If yours doesn't, have it checked. Or run a line from the tv to the fridge.
twilder is offline   Reply With Quote
Old 10-03-2011, 01:04 PM   #6
1974 Argosy 20
Kooskia , Idaho
I have run my refrigerators on propane on the road for the past 32 years and probably 100,000 towing miles. Once in a while in heavy gusty cross winds while towing at speed, they have gone out, but it has been very uncommon. Many self light when they go out these days. Older ones do not.
Old 10-03-2011, 01:10 PM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
We run ours on the road!
Skatiero is offline   Reply With Quote
Old 10-03-2011, 01:11 PM   #8
1981 31' Excella II
Mine is 1981 Vintage and it does not have the DC option as far as I know.
Perry
Old 10-03-2011, 01:24 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Perry
Only refrigerators installed by an owner in an Airstream trailer would have the 12v heating element installed, though lots of later trailers have 12v systems for gas-to-120v changeover, and flame ignition on gas operation.
Some people have issues with the flame blowing out (either poor airflow control, low gas pressure, dirty burner orifice or a combination of some of those things.) As long as the system isn't REALLY broken, it shuts off the gas flow when it blows out so the only risk is that the refrigerator compartment starts to warm up.
At least some of the fridges with the 12v control system and 12v ignition will relight automatically when they detect that the flame is off, but I don't know which model does what. Mine's old-school, no electronics.
— David
Old 10-03-2011, 01:59 PM   #10
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Atwood makes a "relighter" that runs on a 9 Volt battery. I have installed several over the years and no more pilots blow out. You can find them on ebay, price has gone crazy, paid 33 for the 1st 20 years ago, 99 bucks now, same model. Present one is to replace old spark lighter on my Dometic RM100 Fridge.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 10-03-2011, 06:27 PM   #11
1981 31' Excella II
You should be able to get a complete used fridge for that. Sorry but I am cheap.
Perry
Old 10-03-2011, 06:57 PM   #12
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
The newer Dometics will run fine going down the road on propane. They no longer have the 12 volt provision and do not require a carpenter's level when you land.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-03-2011, 07:05 PM   #13
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
I run ours on the road too. We tend to travel a maximum of 8-10 hours a day with the fridge running "non-stop" the entire trip. Never any problems. Gas stations are a different debate, I have filled lots of times with the fridge running. You decide for yourself, my setup may be different than yours.
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 10-04-2011, 01:43 PM   #14
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We run with the reefer on propane. My truck is a diesel so I don't feel the risk at fueling is there to the same degree as with petrol. I don't have a 12v option but if I did I would probably use that while on the road rather than the propane.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Gas on, gas off? heavyjumbo LP Gas, Piping, Tanks & Regulators 28 07-23-2011 07:59 AM
Got gas? ROBERTSUNRUS Off Topic Forum 13 06-25-2011 12:14 AM
The Road to San Antonio Foiled Again Solo Streamers 5 06-04-2011 10:25 PM
