Old 10-01-2010, 11:20 PM   #1
LucyPepper's Avatar
1975 27' Overlander
Salt Lake City , Utah
Wink Can I repaint the inside of my vintage Domestic fridge?
Hi guys!
I have an old vintage Domestic in my 1975 Overlander that luckily works, but I would like to repaint the inside to give it a bit of a face lift. Can this be done? If so, what would you suggest using?
P.S. Sorry if there is already a thread on this..could not find anything!
Thanks in advance my AS family!
Lucy Pepper
LucyPepper is offline   Reply With Quote
Old 10-02-2010, 03:52 AM   #2
1969 21' Globetrotter
Seattle & Olympic Peninsula , Washington
Lucy,
I'd be sure that any paint I used *inside* a refrigerator, or any where that comes in contact with my food for that matter, is 'food grade' and non-toxic.
But give this a gander...
http://www.airforums.com/forums/f425...tor-28671.html
Best of luck,
Dave
EvelynDickinson is offline   Reply With Quote
Old 10-02-2010, 04:26 PM   #3
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Krylon's standard aerosol paints are safe for use inside refrigerators. You'll need to rub over the surface with a 600 grit or finer sandpaper to help the paint grip or it will peel. After sanding, wipe out with soapy water to remove grease and dust, allow to properly dry, then paint. Only white or very light colors should be used - I recommend almond or biscuit for a natural vintage-appropriate color.
Leave the refer open for 48 hours in a low humidity environment to allow the paint properly cure before closing the door.
TX-16
Dave Park is offline   Reply With Quote
Old 10-02-2010, 05:35 PM   #4
OO , OO
Send a message via Skype™ to cruiser54
Lucy, YES YOU CAN !!
Somewhere already heard, laugh...
Lots of love from Switzerland
Werner
cruiser54 is offline   Reply With Quote
Old 10-03-2010, 06:28 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Tac cloth
After sanding, go over the surface with a tac cloth. You can get tham at most auto parts stores. They are designed to clean a surface prior to painting and leave no residue. You may discover that after sanding the unit looks pretty good and may be able to just clear coat it to get the gloss back.
dometic, refrigerator, paint
domestic fridge problem nightowlhooter1 Refrigerators 7 05-11-2016 10:25 AM
Vintage 18 foot 1959 Airstream renovated inside & out eBay Watch Airstreams on eBay 0 04-17-2010 11:50 PM
Vintage 18 foot 1959 Airstream renovated inside & out eBay Watch Airstreams on eBay 0 04-09-2010 09:40 PM
Vintage 18 foot 1959 Airstream renovated inside & out eBay Watch Airstreams on eBay 0 04-02-2010 09:30 PM
'62 LP Domestic Fridge NJtoNC Refrigerators 0 01-18-2010 07:07 PM
