Old 06-21-2007, 05:22 PM   #1
1964 22' Safari
Saint-Apollinaire , Quebec
Question Burner for a refrigerator Safari 1964
Were can I find a burner for my refrigerator for a Safari 1964?
jpsabourin is offline   Reply With Quote
Old 06-21-2007, 05:48 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Snyder's RV refrigeration.
Tom
Old 06-22-2007, 01:48 PM   #3
1964 22' Safari
I brock the pilot burner . Is it possible to find and other one?
Old 06-23-2007, 08:34 AM   #4
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Do you have a picture of it. That would be really helpful here. There are hundreds of different styles.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 06-23-2007, 12:32 PM   #5
1964 22' Safari
Thes is 2 pictures of the burner . One shows wre it is broken.
ID:	39743   Click image for larger version
Old 06-23-2007, 01:48 PM   #6
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Well I hate to be the one to give you the bad news but, that burner is NLA (no longer available) I broke mine and it looks just like that one. There is an outside chance that you may find one someday.
The only way you can get one is to get one from a dead refer, make one(or have someone do it), or change the burner assembly out with a newer one(by newer I mean late 60's early 70's)
What I did was locate a dead refer that was newer and I used the burner assembly out of that one. The bolt pattern is the same on the flue and everything else lines up pretty good.
Other options Make it into and icebox and put a drain tube in the bottom
Buy a new refer
Get a cooler and use it for a cabinet
If I were you and I had the money, I would get a new refer. Just my opinion.
Project 2k5
Old 06-23-2007, 02:36 PM   #7
1964 22' Safari
Thank you very much . I will try to find a newer one if possible.
JPS
Old story (from 1964) casarodante On The Road... 14 04-04-2006 09:02 PM
1964 GlobeTrotter InsideOut 1960 - 1964 Globetrotter 3 09-29-2005 11:56 PM
Blinds for my 1964 Safari Neenm Upholstery, Blinds, Walls & Interior Finishes 19 09-18-2003 04:33 PM
Bowen W/H burner retrofit Jabba Water Heaters, Filters & Pumps 2 11-26-2002 05:27 AM
Towing my 1964 Safari - what tow vehicle do I use Neenm Tow Vehicles 6 06-28-2002 04:26 PM
