08-21-2006, 08:55 AM
1980 20' Caravelle
Coeur d alene
, Idaho
Brown Stain in Frig?
A Brownish colored liquid keeps showing up in the back of my Frig? A week after I clean it, more shows up. I can live with it, but what to know the cause. Also where is the best place to buy a door gasket for a Norcold 774 EG2? Thanks, Don
08-21-2006, 10:45 AM
Retired.
, At Large
Rust?
Does it look like rust? You could have something rusting up inside the unit, that when the fridge defrosts, the water comes out rusty.
08-21-2006, 11:54 AM
2001 30' Excella
Bedford
, New Hampshire
Brown stain
I was just at a seminar held at the Region One Rally this weekend about absorption referigerators. The brown stain is probably a failing unit with leaking into the fridge.
I have a business card at home from the person holding the seminar. I'll try to email you the contact information this evening. You can then ask the professional.
Mark
-Life is a journey, not a destination.
Aerosmith
08-21-2006, 12:55 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
missed you at the rally! where were you parked?
that was an interesting demo that the guy put on....he came up with a neat gizmo for increasing the efficiency of a gas absorption fridge. sounds like a great idea for newer model trailers with the vents in the side wall that get covered up by an open entry door....
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
08-21-2006, 12:57 PM
1968 17' Caravel
Battle Ground
Is that big white thing the gizmo? Looks like a little fan in the bottom blowing up over the tubes, with the air directed by the white thing. Good idea! I'm always looking for ways to make my fridge work better.
Stephanie
08-21-2006, 01:03 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
yep. and it has a sensor on it that only turns the fan on when the unit is hot. (which it won't be, unless its "on"). So you don't have to remember to turn it on or off...and its inaudible, too. no noise at all.
Air:291
Wbcci: 3752
'73 Safari 23'
08-21-2006, 01:31 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
chuck
as i recall that fan device is reasonably priced as well!
john
you call them ferrets, i call them weasels.
08-21-2006, 01:37 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Originally Posted by john hd
chuck
john
I think it was around 50 bucks...
Air:291
Wbcci: 3752
'73 Safari 23'
08-21-2006, 02:10 PM
1968 17' Caravel
Battle Ground
Definitly post his info when you find it.
Stephanie
08-21-2006, 02:19 PM
1968 26' Overlander
Wenatchee WA
, Cape Cod
Didn't ChrisJ put a special fan in his refridge vent to increase air circulation when he rebuilt the Caravel? Maybe he will chime in here.
Jim & Kathleen 1968 Overlander - WBCCI #5793
08-21-2006, 03:29 PM
1968 17' Caravel
Battle Ground
I put one in mine. Two computer-type fans mounted on a frame. I placed them above the radiator-thing (note I'm getting very technical here - I don't seem to remmeber the exact words for anything all of a sudden) at the opening to the chimney to help create an updraft. But I think this gadget would work better and only use one fan. Also my fans are turned on manually (I forgot to turn them off after the last trip and totally drained my battery). I like the temperture switch idea to make them automatic.
Stephanie
08-21-2006, 03:31 PM
Moderator dude
1966 26' Overlander
Phoenix
I know of a number of people that have put fans in their absorption refer. None that were tied to the operation of the refer. That sounds neat!
Create a new thread and post the details.
>>>>>>>>>>>>>>>Action
08-21-2006, 04:00 PM
1976 25' Caravanner
Campton
, New Hampshire
Here's the web site " www.snydersrvrefrigeration.com ". He also does repairs and rebuilds.
08-21-2006, 07:44 PM
1980 20' Caravelle
Coeur d alene
, Idaho
Mean While Back at the Ranch--- It's me again --The Brown Stain in the Frig? Talking to a local RV tech. he said I should remove the fins and clean off the coils and check for leaks and rust. If I find leaks it's toast sooo new frig or remanufactured coils. I spent the day trying to find a new gasket for the door, but no Luck for a Norcold 774 EG2. I guess they no longer make the right gasket for this model. It looks like I have a boat anchor, but If it breaks down soon I can always use it as an Ice Box, and get a SBA loan and buy a new one next year!!! Thanks for the info, Don
08-21-2006, 08:15 PM
Round on both ends
1979 31' Excella 500
1975 28' Argosy 28
Rutledge
, Georgia
Hi, glacierrunne,
I've seen those stains in my two fridges, too. I always thought they were some form of reddish mildew, as I keep one fridge defrosted and the other does it itself. I use Armorall "Ultimate Interior Cleaner" on it, and it disappears nicely.
I'd think rust would be easy to identify. Lick a fingertip and press it against the stain. Then sniff. Wet rust has an ironlike odor that you should pick up on right away.
Also, the paint on the fridge compartment fins of my '75 gave up years ago. As of yesterday, it was still happily making cold.
I really think the best thing we can do for old ammonia-absorption fridges is to keep them running and recirculating all the time.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
08-21-2006, 08:49 PM
1980 20' Caravelle
Coeur d alene
, Idaho
Lamar, Thanks for the info, I am glad I finally found someone who has seen this stain, I am rehabbing the gasket and just going to keep using it and let the chips fall. Thanks again, Don
09-03-2006, 03:59 AM
east stroudsburg
, Pennsylvania
