There are four refrige wires that come out of the wall behind my refrige. I hooked up the 12V dc connection (red and black) to my new frige and it works fine... What is the purpose behind the brown and green? I feel like I'm missing something.
Possibly the propane relite sparker circuit. Mine were wired direct to the battery by a previous owner. When I cleaned up the wiring, I managed to wire them in to the breaker board backwards, duhhh.
The Red, Black, Brown and Green wires that exit the wall just above the fridge in my '73 don't connect to the fridge. They are for the thermostat for the air conditioner. It hangs on the wall right next to my fridge. Have you measured the voltage on the red & black? Where is the thermostat for your air conditioner?
What is that line from "Miracle on 34th Street"? Something like "Maybe he's only a little crazy, like those men in Washington."
So wait... I dont understand. Why is there an AC thermo hook up behind the fridge? When I bought my airstream the AC thermostat was ripped off the wall... I don't know for sure, but I'm guessing the assortment of 6 wires went to the AC thermostat. right? Why would there be a power hook up behind the fridge if you install the themostat in a different location?
On a side note, I need to purchase an AC thermostat. Do they all have this 6 wire hook up? or do i need to purchase one according to my AC brand?
I replaced our OEM thermostat with an electronic household model. It cost $20, and works fine. It will turn the fan off when temp is reached, which cuts down noise when it's not running.
Terry Change is inevitable, except from a vending machine
AIR#2611
