Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-03-2011, 11:55 AM   #1
1969 23' Safari
Athens , Georgia
Automatic electric to gas refer
I thought I read somewhere that you could buy a refer that automatically switches over from electric to gas when the 110 power shut off. Did I imagine this, or is there such a thing?
sarasafari is offline   Reply With Quote
Old 10-03-2011, 12:08 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
They are common. Almost all of the current production gas fridges will do this. Check the websites of Norcold and Dometic and their dealers.
Old 10-03-2011, 12:08 PM   #3
x
XXXX , XXXX
All modern RV refigerators are automatic switchover types. They use 12VDC to power a circuit control board and use either 110VAC or propane gas to provide the coolong. Depending on the make and model you can select aotomatic mode which when 110VAC is available will use that and automatically switch to gas mode when shore power is disconnected. On some you can select electric only or gas only.
To use this type of fridge in a vintage A/S you must supply both 12VDC and 110VAC and propane gas to the fridge. The vintage unit will not have 12VDC at the fridge and will require adding 12VDC wiring to the rear of the fridge area.
wasagachris is offline   Reply With Quote
Old 10-03-2011, 12:53 PM   #4
1974 Argosy 22
1976 Argosy 28
1972 Argosy 24
Chico , California
I just put one (Dometic) in my 74 Argosy. This is the greatest thing ever! Not only does it detect which power souce available is the best to use, it will also ignite the gas without having to click on anything. It's like magic! I run some heavy gauge wire to the batery block, put in an inline fuse, and I'm ready to roll. I added a second battery to the unit, ran it on DC during the 4 hour tow, had it on propane for 3 days, along with the hot water heater and cooking. Used a small tank (BBQ size) of lp gas up over the 3 days, but didn't notice a dip in the electric charge.
twilder is offline   Reply With Quote
'69 Overlander Fridge: RM 2500 gas electric edglenn Refrigerators 1 09-07-2011 10:09 AM
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 08:40 PM
Got gas? ROBERTSUNRUS Off Topic Forum 13 06-25-2011 12:14 AM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
