Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-03-2006, 07:23 AM   #21
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
I'd like a gas refer for my 55 FC anyone know of one out there?
Don
NorCal Bambi is offline   Reply With Quote
Old 09-03-2006, 07:40 AM   #22
Sugarfoot's Avatar
1958 22' Flying Cloud
1956 30' Sovereign of the Road
1963 16' Bambi
Southeastern Area , Tennessee
Originally Posted by RV_cool
Is the flame big enough? It should be blue, with small spikes coming from the center, be about 1/2 inch tall and shaped like a hersey kiss.
As far as I can tell, the flame looks great, exactly like you describe. I was so excited to have it that I snapped this pic looking from the exterior access door after it lit.
Name:   Klixon Flame.jpg
The first thing I'm going to try is making sure the trailer is level. I know it is level from streetside to curbside right now, but it may be out of level from front to rear. I'm open to any suggestions.
Traveling With Elvis
life with a 1956 Sovereign of the Road
Sugarfoot is offline   Reply With Quote
Old 09-04-2006, 10:12 PM   #23
1960 24' Tradewind
santa barbara , California
I have a long metal rod in the pantry on a hook ,looks like a device to reach the burner of your fridges ,has a square little apendage on the end for a match maybe ? was in the trailer there when i bought it .i have a dometic RM660 in it so the click I hear is the electric pushbutton start ,works good,
cold fridge ,the freezer isn't really icing ,but does get colder than the fridge
the door on the freezer is held closed by the fridge door ,should there be
some other type of latch ,no provision for it. RV cool ,any ideas on the 660?
It does need a new seal on the freezer door.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 09-04-2006, 10:31 PM   #24
1960 24' Tradewind
lighting rod
Hello 59 newbie,
This does indeed look like a lighting rod ,the wick is in great shape.
hope the pics load as It seems hard to do before the (page not found )
decides to pop up .
Scott
Name:	2006 8 005.jpg
ID:	25639   Click image for larger version
Name:	2006 8 006.jpg
Old 09-05-2006, 03:21 AM   #25
east stroudsburg , Pennsylvania
how cold is it getting in the freezer section (temp. reading)
RV_cool is offline   Reply With Quote
Old 09-05-2006, 07:58 PM   #26
1960 24' Tradewind
RV cool,
I went out last night and turned on the fridge at #7 ,this morning I realized I forgot to plug it in as it plugs in right above the counter on top above the fridge .So tonight its 40 degress in the fridge and the freezer is 4 degrees .
I haven,t tried the freezer since the last outing before I did a velcrow strip
on the top of the freezer door to keep it shut.Now ,it may not work as well
when its hotter weather ,but it does seem to be working good.I have never
seen frost in the freezer before .Today it was about 70 degrees outside.
Can i get a new door seal ? RM660 model?
thanks Scott
Old 09-06-2006, 03:26 AM   #27
RV cool,
thanks Scott
Measure it see if its this one...GASKET 7-1/8H X 17-1/2W$45.84
Old 09-06-2006, 08:32 PM   #28
1960 24' Tradewind
RV Cool ,
Thats the correct size ,its white in color and about 1/4 wide .I would like to buy it .Is the door of freezer suppose to be held shut by fridge upper shelf
when closed? there is no latch ,but the velcro seems to have fixed the freezer as it was -2 degrees this morning and icy cold! .now do you have an upper shelf ,its a dark see thru 70s plastic ,got broken some how .
Scott
Old 09-06-2006, 08:35 PM   #29
doors are spring loaded I believe...PM me and I'll give you the info where to order your parts.
Old 09-10-2006, 04:23 AM   #30
Originally Posted by Ken J
From what I can tell - it looks all there - I had one and the ceramic burner was cracked and therefore useless.......
Ken J.
If anybody is interested, I can obtain burner parts, the head, ceramic, rings, ect.
Old 09-10-2006, 04:47 AM   #31
Originally Posted by 1959newbie
I have an original LP-only Dometic in my trailer, with "the dreaded Klixon valve." The outside and inside of refer are in fairly good condition, though, and as I was suckered into buying a trailer that needed a complete ground-up restore, I am truly hoping to avoid the $1000 purchase of a new refer!
Klixon valve seems to operate OK on lighting, and unit cools down quickly. Gas won't stay on for a prolonged period, however. I have found diagrams and operating instructions online (VAC website), am trying to figure out if my burner and valve assembly are all there, and if the aluminum "tongue" on the Klixon valve is in the right place. Below are some pics. If anyone out there has (or has had and remembers!) this type of unit, please look at these closely and tell me what you think. (The burner nose is what doesn't look exactly like the diagrams I found, to me. Tongue location seems about right, but not sure.)
Thanks for any input on troubleshooting.
I think I can get new Klixon valves also
Old 09-11-2006, 06:39 PM   #32
Sugarfoot's Avatar
1963 16' Bambi
I'm one happy camper!
Its amazing how one bubble out of plumb can affect one's life. I got the TW completely level yesterday, turned the refer thermostat to 9, lit the Klixon and hoped for the best. In about 20 minutes the freezer was 65 degrees. Four hours later, freezer at 30. Today, WOOHOO! I HAVE ICE. Never knew a chunk of frozen water sitting in a 46 year old ice box could look so good. Freezer is a frosty 18 degrees and the fridge was 30. Lesson learned, leveling IS important.
Old 09-12-2006, 01:31 PM   #33
good to hear that...level is important, because the tubing in those units are pitched so the ammonia runs to the bottom. when the fridge is off level, it can disturbe the flow of the ammonia. Remember these don't have compressors, they rely on gravity to work.
Old 09-12-2006, 02:03 PM   #34
Sugarfoot's Avatar
1963 16' Bambi
Thanks RV Cool, so in this case with my refer, gravity is my friend, right? Too bad that isn't true for people as they get older!
Old 09-12-2006, 02:30 PM   #35
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
ice
I was so excited I got the klixon fired up and was able to make ice I took a picture of it . . . then didn't post it because I thought people would think I was nuts (which I am). Glad to hear you got it working again.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-12-2006, 02:40 PM   #36
Sugarfoot's Avatar
1963 16' Bambi
No Mark, you're not nuts at all . . . . or maybe we both are. I debated grabbing my camera yesterday, but naw . . . people would think I was nuts! Congratulations on your refer's good health. I know exactly how much it means.
Dacia
BTW, is that your vintage Tradewind table under your vintage ice cube tray? Looks good.
Old 09-12-2006, 02:47 PM   #37
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
no that's my vintage Flying Cloud table, and thanks we like it too (it's the "coffee table" in our living room).
Old 09-12-2006, 08:37 PM   #38
1960 24' Tradewind
It is very exciting to get the fridge fired up an have it make ice like it did
40 years ago .Its also exciting to order Ogden water purifier carteidges for a
purifier thats has not been made for 40 years .very high on the COOL factor.
thanks Sugarfoot.
scott
Old 03-18-2011, 11:15 AM   #39
1959newbie's Avatar
Hill Country , Texas
Unhappy Anyone still out there with a working 1950's-1960's LP-only Dometic?
because I'm really frustrated!
My trailer has been stationary and in use merely as a guest room for the past 3 years, and so I've been slow to repair the inside door liner of the original Dometic fridge, to build a chase for the new vents I installed high and low behind it, or to find a new gasket for the door.
But now I'm getting ready to start using the trailer for camping, so working on fridge again, and had my RV tech out yesterday to work on a couple of other things.
He and I were BOTH frustrated because, although I've gotten the Klixon valve lit and the fridge working three times before -- most recently about 18 months ago with him -- NEITHER ONE OF US CAN REMEMBER HOW WE DID IT! I mean, I do remember having to hold heat on the Klixon a long time, but is there some obscure kind of gas valve to turn on first? There was nothing obvious to either of us, e.g., to push in or turn on while holding heat on the Klixon. But all we had were some wimpy grill lighters, so maybe that was the problem -- I'm hoping!
All the helpful-looking links on this thread are no longer functioning. Can anyone refresh my memory? Or do I just need to go get a mini-torch?
Thanks!
Lynne
1959newbie is offline   Reply With Quote
Old 03-18-2011, 03:01 PM   #40
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Might not be any gas getting to the unit itself?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
New refer. 77caravaner Refrigerators 1 10-31-2002 11:04 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
