Old 09-14-2015, 01:57 PM   #1
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
Jacksonville , Florida
Anybody have a refrigerator with ice maker?
I'm going to replace an old Dometic refrigerator, a small one, and I'd like to install a larger unit. I know my space requirements. I've been looking for a while now, and I see some of the units come with ice makers in the freezer compartment. Does anyone have this set up? Any problems? Love it?
And how did you run the water line? My kitchen sink is directly opposite the refrigerator location.
Thanks for all the guidance you can offer!
Melaine Taylor
Life Is A Journey - Enjoy the Ride!
TMT is offline   Reply With Quote
Old 09-22-2015, 08:01 AM   #2
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
Going to try this once more. Does anyone have a replacement refrigerator and you added an ice maker? Need advice please.
Melaine Taylor
Old 09-22-2015, 05:49 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Yes, I added an ice maker to my Dometic. I have a '15 Classic and just bought a complete ice maker kit online. Not all that hard to install. I had the fridge out of the trailer to do some wiring, and getting it out without damaging any of the wood framing was the tense part. I drilled a hole through the rear of the freezer for the water inlet (sealing it carefully afterwards, of course), as well as the wiring harness. The solenoid valve is screwed to the floor of the fridge compartment (accessible from the exterior door), and I tapped into an adjacent PEX water line with a properly sized T connector. (I put a separate shutoff valve in that line so I could isolate it from the main water supply.) I did use 1/4" copper tubing from the PEX to the solenoid. The other water line -- up to the ice maker, was supplied with the kit...it's plastic. Winterizing this ice maker set up will require getting all the water out of the solenoid and copper tubing. I've used the ice maker all summer and I can't extoll the virtues of plentiful ice enough. I read somewhere that adsorption freezers don't get cold enough for an ice maker. Not true, at least in my case.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
ice maker mlmarch General Motorhome Topics 13 06-29-2010 03:47 PM
fridge with or without ice maker remcolent Refrigerators 12 07-04-2008 10:18 AM
U-Line Ice maker in '94 LY blkmagikca Plumbing - Systems & Fixtures 5 08-15-2007 03:11 PM
Portable ice-maker experience? Kistler Our Community 6 06-22-2005 10:13 PM
Dometic with ice maker Minnie's Mate Refrigerators 0 09-27-2004 07:27 AM
