Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 12-28-2015, 09:43 PM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Smile Any experience with Indel Webasto Danfoss?
So part of my planned 2016 upgrades are a Danfoss refrigerator. I'm always hearing good things about Marine fridges. We are attracted to the lack of need to level and the low amp draw of most of these fridges. But I'm curious if anyone has any experience with one of these units in a newer Airstream.
This one was on my radar, not sure of other brands.
Indel Webasto:Â*CRUISE 195 INOX (Stainless Steel)
I saw some older posts with vintage Airstreamers who usually have under counter models. My wife was really attracted to this model with the larger freezer.
I'm just looking for some real world thoughts and opinions.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-28-2015, 10:14 PM   #2
2002 19' Bambi
Lafayette , California
The website says it is a compressor refrigerator, so it would not run on propane which requires an absorption system. Would you be satisfied with only electric operation?
Tim
Tim A. is offline   Reply With Quote
Old 12-28-2015, 10:40 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Most Airstream Interstates (except the older T1N models) have Nova Kool all-electric 12v/120v refrigerators, very similar in operating principle to the Webasto models you're looking at. They cool more efficiently (use less electricity) than a Dometic propane/electric model in electric mode. And as you already know, no leveling is required, so there is no problem with running the fridge while underway even in mountainous terrain, and with no flame there is no need to shut it off for safety when you refuel.
The only quirk I'd make note of is this… if the fridge is powered by 120vAC, a built-in converter changes the power to 12vDC. And my fridge defaults to 120vAC operation if both 120vAC and 12vDC are available. So it's more energy-efficient if the 120vAC cord is left unplugged and the fridge is used in 12vDC mode all the time whether you're plugged into shore power or not; no energy lost in the 120vAC-to-12vDC conversion.
Old 12-29-2015, 12:43 PM   #4
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Bold,
Lewster highly recommended that fridge when we were in a Vintage Class taught by him a couple of years ago.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 12-29-2015, 01:47 PM   #5
2016 30' Flying Cloud
Oviedo , Florida
Maybe I'm missing the point, but you spend a ton of money upgrading your battery bank and then burn a good amount of it up powering a 12VDC fridge rather than using LPG?
I was under the impression the 12V fridges were current hogs
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 12-29-2015, 01:59 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Leveling for a LP refrigerator is not as critical as it's made out to be. If you're not comfortable with the level of the trailer, your fridge might not be. If you are, it is.
2019 Ford Expedition Platinum
Old 12-29-2015, 02:30 PM   #7
Much less of a current hog than using electric mode on a dual propane/electric fridge. All-electric fridges use Freon or an environmentally-friendlier Freon substitute as their refrigerant, much more efficient for heat transfer than the ammonia used in propane-fueled fridges.
Absorption-cycle refrigerators that run on propane and use ammonia as a refrigerant are very reliable; they're the oldest form of mechanical refrigeration there is, patented by physician John Gorrie of Apalachicola, FL in 1851(!)— but already in use since the 1830's— as a means of refrigerating rooms for housing fever patients; making absorption refrigerators the world's first air conditioners as well. But the absorption refrigeration technology is also the least-efficient form of mechanical refrigeration.
Old 12-29-2015, 02:37 PM   #8
DKB_SATX's Avatar
Alamo Heights , Texas
The Dometic Tundra that's similar in size to the Webasto mentioned here is reported to use about 28 amp-hours/day at 90F. Several cheaper models show much higher usage but the article in which I found this table suggests that their higher current demand is due to poor insulation which requires the compressor to run more frequently.
ON EDIT: I noticed when looking back at that table that several of the models with a higher total or per-cu-ft power consumption are freezers, so not all of the ones on the table with more consumption are necessarily due to poor insulation. The comments in the article text may also refer to some poorly-insulated models not included in the table.
If you're going to go solar anyway you're likely to have plenty of panels and battery to support that. It's a bit less than the useful capacity of one cheap flooded Group 24.
I'm planning to put either the Tundra or that pretty stainless Webasto in my 28' trailer. Since I'm starting from scratch (no fridge in it at all at the moment) the cost of the unit itself is about the same as a big absorption fridge.
— David
Old 12-29-2015, 05:48 PM   #9
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I've been looking into the low draw fridge/freezers as well. The ARB looks pretty good. National Luna and of course Engel. That is a big one that you are looking at there. It does have the Danfoss compressor and that seems to be the thing..
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 12-29-2015, 07:42 PM   #10
1975 Argosy 26
Tulsa , Oklahoma
Not to hijack the thread, but I'm curious about the 12 volt fridges on the lower end of the spectrum. We've been eyeing the Whynter and Grape fridges:
Whynter:
Whynter 85 qt. Portable Fridge/Freezer-FM-85G - The Home Depot
Grape:
Refrigerators : Glacier 5.0 DC/AC FRIDGE/FREEZER
We were looking at the Engel's too....
DDOK is offline   Reply With Quote
Old 12-29-2015, 07:49 PM   #11
Naples , Florida
The cruise 195 has TWO danfoss BD-35 compressors. Each box has it's own t/stat and compressor. It provides great versatility, but at double the amp draw of other marine fridges.
I have installed 2 of the Cruise 195s and the owners love them! That is in addition to about a half dozen of these from VitrFrigo: double compartment refrigerator for bigger boats and a bunch of these: Indel Webasto:Â*CRUISE 130 Elegance
If you have solar and sufficient battery reserves, why hang on to 150+ year old technology that tries it's best but FAILS to keep your food at 33-35ºF, needs to be relatively level so gravity can help it work and is susceptible to ambient temperature swings when you can have a cold fridge (with ice cold beer) and rock hard ice-cream (no more RV soft serve!!!) for a fraction of a comparably sized absorption fridge???????
They also are designed to take a pounding, don't have recalls and will work up to 30ºoff-level. Seems like a no brainer to me……...
lewster
Old 12-29-2015, 09:05 PM   #12
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Mike, we have a 8.1 cubic foot Danfoss fridge (Vitrifrigo) that Lewster installed for us back in September and we love it! Best of all (for you) we are currently in the Palm Canyon State Park in Borrego Springs and will probably head over to the Rockhouse Road boondock area to join you and the other AS'ers there for a few days beginning tomorrow (12/30/15) and we'd be pleased as punch to show it off to you. Bob
Bob Martel
WBCCI# 5766
Old 12-29-2015, 09:49 PM   #13
Silver Hilton
Mark Wiltrakis's Avatar
1959 24' Tradewind
Astoria , Oregon
I'm perplexed. I became very interested in the Airstream Interstate after touring two at Yellowstone this fall. But the refrigerator's electricity hunger gives me pause. How is this better than a propane refer needing zip for battery power? Batteries deplete quickly, propane does not. Cannot an Interstate be adequately leveled to run a propane refer? I like to boondock for a few days or longer at a time - the refer in the Interstate seems to make this impossible. Why is a propane/110 VAC refer somehow less desirable? Is spending $$$ to upgrade battery capacity and solar panels worth more than a propane refer? Should I need to run a generator to support my refrigerator?
At least as I understand it, the 12 v refer in the Interstate prevents me from purchasing the Interstate. I'm not meaning to be contrary, but this has had me thinking for awhile. Thanks -
Mark
Mark Wiltrakis is offline   Reply With Quote
Old 12-29-2015, 10:06 PM   #14
Chelsea , Michigan
Images: 12
Mark
Mark, the OP and I both have travel trailers and not Interstates (AS' Class Bs) and we have upgraded our batteries to LFP's (400 AH in both cases I think) and do extensive camping while not connected to shore power. I would be hesitant to recommend switching to a 12 volt fridge to anyone who plans to boondock extensively unless they have at least 200 AH of available battery capacity (which means 400 AH if using AGMs or wet cells or 300 AH if LFPs.) I know that Interstates do not come with that much capacity (neither do Airstream's travel trailers) so boondocking with an electric fridge with the stock batteries from Airstream regardless of TT vs. Interstate is not really all that practical unless you upgrade the batteries (and get decent solar) or are open to using the generator on a regular basis. However, if you go from one electric site to another (which a lot of - if not most - people do) then the electric fridge and stock batteries (in good condition) are just fine.
Bob Martel
WBCCI# 5766
Old 12-29-2015, 10:18 PM   #15
Chelsea , Michigan
Images: 12
Our 8.1 cubic foot Vitrifrigo (which fits in the same space as the 7 cubic foot Dometic on a typical 27 foot Airstream) is rated at 5.6 AH (@ 12v) and my experience indicates it runs about 65 - 75% of the time in typical camping conditions (i.e., not 100 degree days in the Mojave!) so that works out to between 85 and 100 AH per 24 hour period. The Vitrifrigo is a quality model so I am skeptical that there exists a similar sized fridge from another manufacturer that will only use about 25% of this amount of power (i.e., 28 AH/day.) Anyone contemplating a 12 volt Danfoss fridge needs to plan for making up the requisite amount of power usage between their shore power, batteries and solar set-up. We have 400 AH of LFPs and 540 watts of solar on the roof and a number of other electric intensive activities (TV and internet) and can do fine basically forever without running the generator or needing shore power unless we hit two or three cloudy/rainy days in a row (or camp in the shade.) Then we haul out the Yamaha for a couple of hours to get us over the hump. Even when we "have to" use the generator (which is converted to propane, btw) we still use way less propane than we would if we had a standard Dometic fridge, plus of course, the Danfoss fridge works so much better than the adsorption style (i.e., Dometic) fridge.
Bob Martel
WBCCI# 5766
Old 12-29-2015, 10:38 PM   #16
Silver Hilton
1959 24' Tradewind
Astoria , Oregon
Thanks Bob. My best choice may be staying put - 2x Lifeline AGM's 105 AH each and a refer I can run for days with no worries about battery drain. I have a generator but use it as little as possible.
Mark
Old 12-29-2015, 11:09 PM   #17
Not having to cut even more great gaping holes in the side of the Sprinter van body probably has something to do with it— Mercedes is a lot more particular about what an upfitter can do to the Sprinter van than were Freightliner and Dodge, the previous dealers for Sprinter vans. It wasn't until 2014 that Mercedes approved the first Sprinter van conversion with a slide-out, for example, and to the best of my knowledge only one upfitter, Leisure Travel Vans, has ever gotten approval for one. But back to fridges…
Fridge location in an Interstate varies from one floor plan to another but the exterior fittings all stay the same (except the T1N and maybe the Grand Tour). For example, on mine, the municipal water intake and fresh tank fill are directly behind the fridge, exactly where a Dometic propane-fueled fridge would have exterior access to the working parts. Installing a propane fridge would require ripping out the galley entirely and rebuilding it to put the fridge where a hole could be cut into the side of the van. A lot more expensive and time-consuming than switching to 6v Lifeline house batteries in series to get more amp-hours and adding more solar capacity to run the fridge longer on battery power. And all to get a less-efficient fridge.
But the older T1N-based Interstates (2004-2007) had a Dometic propane fridge— and a different floor plan. So you may want to consider a used T1N Interstate if having a Dometic propane fridge is really a make-or-break decision point for you.
Old 12-29-2015, 11:56 PM   #18
Nomadic , USA
There are about 28 of us over here now, Airstreams, can't miss us. The wife I know would love to see it. My Amazon wishlist has significantly increased in the past week.
Knowing you have the 27 EB makes me all the more interested in seeing it, since our setups are similar.
When AMSolar gets back from Vacation I'll have a total of 705 watts of power. Currently we have 505 watts.
Old 12-30-2015, 12:24 AM   #19
DKB_SATX's Avatar
Hmmm... I found a confusing Dometic chart that may have been the source of the Dometic data on the report I linked earlier. It shows a 4.5A draw at 12V, 2.25A at 24V... but then shows a power consumption of 28W. The only way to get there is to multiply the 24v amperage by 12v. 2.25A at nominal 12v gets you 27W, about 12.5V gets you 28W, but it would only be half the real number.
— David
Old 12-30-2015, 07:59 AM   #20
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Maybe someone can post photos of their Danfoss fridge installation?
I guess the outside vent door is not needed. Have you just left it in place or replaced it with a solid door. Can the space be used for storage?
What issues did you encounter installing one of these fridges? Its it just a simple swap out, plug in the AC to the existing receptacle and connect to the existing 12v in the vent compartment? Any issue with trimming the fridge out on the inside?
What would be the suggested battery capacity for running one of these fridges for someone who has a 50/50 spread between powered campsites and non powered campsites. Sounds like 200ah is not enough for conventional batteries but maybe enough if Lithium.
Kelvin
About to pull trigger on danfoss fridge CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 31 07-10-2021 11:22 PM
Any experience cleaning screens? WHR Windows & Screens 0 03-18-2007 05:32 PM
Any experience with a Twin Temp Jr? Jacob D. Water Heaters, Filters & Pumps 5 11-28-2006 11:28 AM
Any experience with RV'S OF SACRAMENTO guy99 Commercial Listings 0 07-05-2005 11:07 AM
