Old 12-30-2015, 02:42 PM   #29
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by KJRitchie View Post
I guess the worse case scenario when dry camping is also having to run the furnace. How much amp/hrs would be enough from 5pm to 8am the next day during the winter to power both the fridge and furnace?
Kelvin
In weather that demands the furnace, the fridge probably won't need to run the compressor nearly as much as in the summertime.
— David
Old 12-30-2015, 06:02 PM   #30
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
The big complaint I have with our Domentic is that it's never consistent. EVER. It's always freezing things, even at the highest setting. Sometimes in the summer it can't even keep up. Had food spoil while it was on the lowest setting. Had the thermostat looked at. It just isn't meant for the kind of use a full-timer sees I feel. And the other fridges seem better suited.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-30-2015, 07:41 PM   #31
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Mike,
I only know about the Danfoss from a marine perspective. IIRC they are marginal in the tropics with an refrigerant-to-air heat exchanger. In Florida they are often installed with a water jacket condenser. This may or may not be an issue with the unit you are looking at, but check the performance and environment specifications carefully.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 01-17-2016, 09:50 AM   #32
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
I think that TruckFridge uses the same Danfoss compressor system at a much lower cost. I think the lower cost is due to the fact that it doesn't say marine on it
Anyway, I bought the TF 130 model which, as far as I can tell, is identical to the Isotherm cruise 130 model.
timzog is offline   Reply With Quote
Old 01-17-2016, 03:19 PM   #33
Nomadic , USA
I don't think TruckFridge is selling the size we want. We are looking at the Cruise 195
Old 01-17-2016, 04:02 PM   #34
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
It looks like the Truck Fridge TF2600 is the Vitrifrigo DP2600i.
Lance
Top is offline   Reply With Quote
Old 01-31-2016, 10:31 AM   #35
lewster's Avatar
Naples, FL , Hood River, OR
OK Gang,
Here's the 'skinny' on Truck Fridge:
Since I am a Factory Authorized Distributor for both Isotherm and Vitrifrigo, I phoned both companies to inquire about Truck fridge and their look-alike fridge units.
BOTH companies said that they do contract manufacturing for Truck Fridge. They also said the the units look the same BUT ARE NOT THE SAME as the ones sold thru their respective companies.
The box and outer shape is the same and the interiors match as required by the manufacturing process, but the internal components, latching mechanisms, hinges, compressors and evaporators are not the same quality as those use to build the units sold under the Isotherm or Vitrifrigo name.
The bottom line: TRUCK FRIDGE IS CHEAPER BECAUSE THEY ARE MADE USING CHEAPER COMPONENTS!
Perhaps you don't need the quality or better warranty that Isotherm or Vitrifrigo offer. No problem there!
I'll be staying with them as my suppliers of quality marine grade refrigeration components, as they have solidly stood behind every product that I have sold with their names on them!
Old 01-31-2016, 12:29 PM   #36
Nomadic , USA
Anyone know of any place between CA and Washington that sells/install these? I noticed most require freight shipping, and so I don't think I'll be able to UPS Store or General Delivery one to the post office.
My plans for the spring/early summer are to drive up California and into Oregon and Washington. And so I'm looking for someplace I can get one. And possibly just have them install it and recycle the old one.
Old 01-31-2016, 12:48 PM   #37
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Like maybe Hood River Oregon?
Lance
Old 01-31-2016, 01:25 PM   #38
Nomadic , USA
You mean AMSolar? I didn't know if they did anything else. But yea...
Old 01-31-2016, 01:53 PM   #39
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Hood River is one of the locations of Master Tech Energy Systems which Lewster is the owner - he is a masters trained engineer and from my experience his work is impeccable - I would suggest contacting him about you fridge install
Ken J
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 01-31-2016, 02:59 PM   #40
Nomadic , USA
Lewster huh? Never heard of this guy.
Old 01-31-2016, 03:19 PM   #41
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I highly recommend him. Super nice guy and is willing to share his knowledge and experience.
Lance
Old 01-31-2016, 04:16 PM   #42
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Top, Bold is pulling your leg. I would say he is full of something but I have not met him yet and he just installed a new privy.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
About to pull trigger on danfoss fridge CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 30 01-17-2016 09:38 AM
Any experience cleaning screens? WHR Windows & Screens 0 03-18-2007 05:32 PM
Any experience with a Twin Temp Jr? Jacob D. Water Heaters, Filters & Pumps 5 11-28-2006 11:28 AM
Any experience with RV'S OF SACRAMENTO guy99 Commercial Listings 0 07-05-2005 11:07 AM
