Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-06-2010, 08:01 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Any easy way to bypass thermostat on refrig to test fans?
I just installed 2 silenx fans and want to make sure they are working. Turned on refrig but think thermostat temp is preventing them from turning on. Any way to easily bypass the thermostat to test if they work??
Could I remove the hot thermostat connector and wire it directly to the thermostat ground to test?
Thanks!
bonginator is offline   Reply With Quote
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 08:12 AM
Bypass G. Traveler Sinks, Showers & Toilets 3 03-06-2010 08:42 AM
No Water Heater Bypass... Twinkie Winterizing, Storage, Carports & Covers 3 10-24-2007 09:39 AM
Bypass Valve tomb Water Heaters, Filters & Pumps 0 11-26-2002 06:42 AM
