Old 09-13-2008, 11:45 PM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Am I missing the refrigerator intake vent???
All--
Today I visited the Confined Space Rally at the Eagle Creek Overlook just outside of Portland, OR. Francoise and I had a great time and we got to meet Janet and Gary, Stephanie and few others in person... not just as forum avatars.
One thing I noticed that brought a puzzlement to my simple brain... most of the older trailers (60-70s) had louvers or openings in the access panel to the lower back of the refrigerator.
My 75 Safari has an access panel with no louvers and I can't seem to fine and air inlet for the cool air intake (eg. bottom) side.
Is this bad? Do I need to get the access panel louvered? Do nothing an hope it works?
A bit confused...
Ron
ronstory is offline   Reply With Quote
Old 09-14-2008, 03:47 AM   #2
Baltimore , Maryland
Is there not a grill at the bottom of the fridge to let air come in under the unit?
Old 09-14-2008, 05:32 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Like Frank said, there should be a screen set in the floor at the bottom of the fridge that draws air in from under the trailer.
Old 09-14-2008, 07:58 AM   #4
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Look underneath your trailer, under the refrigerator area, and see if there is a screened vent in the floor. If so, that is how the air gets in, goes up behind the refrigerator (convection) and goes out the vent on the roof.
My trailer is a little older than yours and the vent is cut into the belly, covered with screen and then the vent up to the refrigerator is offset a bit. I surmise that this is to avoid getting moisture up into the floor area when traveling. Be sure yours has screen over the hole(s) to keep critters out.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 09-14-2008, 01:12 PM   #5
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Let me go take a look....
Ron
Old 09-14-2008, 01:29 PM   #6
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Yes... there is a vent in the belly pan under the refrigerator with a screen. Whew.
... but while I was under their I noted the curbside rear stabilizer was bent about 30 degrees at the leverage point. It looks like someone tried to use it as a jack. (sigh)
Ron
Old 09-14-2008, 01:31 PM   #7
It's always something huh? Sorry to hear about the stabilizer, but I guess it's best to know about it.
Old 09-14-2008, 01:45 PM   #8
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Yep... it just gets more interesting.
Ron
Old 09-14-2008, 03:12 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
The PO probably drove off forgetting it was down. I did that once but thankfully I was on soft, wet grass. I now hang a yellow tag from each stabilizer to get my attention they are down.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-15-2008, 11:50 PM   #10
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Cool and a good idea. I'm sure I'll forget one day... but I got to get it on the road first.
Ron
refrigerator vent not screened---WHY airstream4 Refrigerators 3 04-05-2008 08:12 PM
Refrigerator Hatch Door Missing -- Pictures IndyAnne Exterior Storage Compartments & Access Doors 3 04-04-2008 07:59 AM
vent under refrigerator dnrtheil Refrigerators 10 06-03-2007 05:11 PM
Refrigerator roof vent? aztlanco Refrigerators 3 10-27-2004 06:51 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
