Old 05-26-2009, 04:41 PM   #1
2007 27' Classic FB
Havelock , North Carolina
Adjusting gas pressure
I have had an issue with my refrigerator not cooling well on gas while underway. I start out at 33 degrees and it heats up to 58 or so on a 80 degree day. After a little research i thought I should start by checking the regulator pressure and after building a Manometer using this nice description and testing procedure on this site RV U Tube Manometer
I found that the pressure was set too high at 18 inches with the refer, water heater and furnace running. I turned it down to 11 inches with all running. I did notice that the water heater, stove, furnace all have their own regulator but the refer does not.
Not sure if this will solve the problem but I can only assume the burner flame wasn't working efficiently at higher pressure.
Anyone have the same problem?
Phil
nsteel is offline   Reply With Quote
Old 05-26-2009, 07:00 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If all is well when you are parked, sounds to me like maybe the air flow up behind the refer may not be right for some reason when you are under way. Or the flame is not heating the chimney when you are under way.
Old 05-26-2009, 07:31 PM   #3
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I think that Jim may be onto something here -- I don't think it is the LP pressure, as the flame is nothing more than a pilot light (well sort of). You could easily retrofit a shroud around the flame / chimney to make sure you are adequately heating the chimney while driving.
Not sure I am interpreting your original post correctly -- do you get 33 degrees from the gas while parked -- or is this from the AC power?
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 05-26-2009, 08:26 PM   #4
2007 27' Classic FB
On propane
Self adjusting electric brakes. Inland RV Center, In Brakes & Brake Controllers 3 05-20-2009 05:51 PM
Adjusting water heater pilot? glacierrunne Water Heaters, Filters & Pumps 2 06-09-2008 05:29 PM
Adjusting my Reese Hitch wagnerda Hitches, Couplers & Balls 11 10-28-2007 09:53 AM
Adjusting flame on water heater Dan S Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-30-2007 06:37 AM
Adjusting Weight Distribution - Equalizer campadk Hitches, Couplers & Balls 33 11-06-2006 01:08 PM
