Old 02-12-2007, 11:30 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Adding a fridge vent
I'm adding a chimney for the fridge vent on the Ambassador.
I purchased a modern vent collar and cover. In order to center it properly above the fridge, the hole I make for it will have to span a rib.
I noticed the factory service door for the fridge was also put in with a rib running into it by 1/3rd of the way.
I don't imagine it being a problem, I'll just notch the collar around the rib when I cut my opening around the rib.
Anyone else run into this before?
-Tim
theVAP - Airstream Podcast
Old 02-13-2007, 05:04 PM   #2
To restore the support, you should add a "horizontal stringer" at the top and bottom of the door frame, that connects to both main bows, and the bow that you cut. Rivet the stringers to all three main bows, and to the inside metal as well as the outside metal. Rivet as much as you can, to the stringers, the access door frame.
You now have created a "box" type support, that is stronger than the original design.
If you do not add the stringers, in time, the side wall at the access door will start bulging.
Remember, the shell does twist and tweek. Without proper support, it will do that one time too many, and then stay that way. That becomes bad news.
Old 02-13-2007, 06:29 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Your depth of detail addressing Tim's question is just too cool, Andy.
Thanks.
Tom
Old 02-23-2007, 05:41 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I'm not trying to hijack this thread but it is also a fridge vent question. Why does Airstream mount a fridge vent duct to the interior skin. Is there any good reason not to seal the cavity between the interior and exterior skins and use that sealed up space for the fridge vent.
Old 02-23-2007, 05:53 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
There's not enough volume of air between the skins to act as an effective fridge vent. The cooling action of the coils is by convection, so adequate airflow is key.
Also, the sun's heat on the outer skin might not be a good idea to be right next to the fridge coils, without insulation.
I had the same thoughts when I built my trailer, but dismissed the idea for the above reasons.
Uwe
www.area63productions.com
Old 02-23-2007, 06:10 PM   #6
Images: 59
I went hafsies with my refrig vent. I recessed it into the wall, but also built it out by about 3".
That gives you a full 4.75" 22" channel for adequate airflow. Heating of the outside skin as long as it is above the condenser is not a problem.
The advantages, in my opinion, are a thinner and more attractive scoop, and you gain 2" of aisle space.
ID:	32957   Click image for larger version
Old 02-23-2007, 08:01 PM   #7
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Nicely done Mark. Wish I had thought of it.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 02-23-2007, 08:03 PM   #8
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I guess I'm going to have to start a new thread, how to make a chimney :-)
Still waiting for my pictures Don... lol
I've about decided to make it out of wood anyway. I'm not that great a woodworker and even a worse metal worker!
-Tim
Old 02-23-2007, 08:12 PM   #9
Images: 59
Gee, I sent them to you last friday at your VAP address, and they didn't bounce. I just sent them again. Four pics. Let me know.
Old 02-23-2007, 08:33 PM   #10
Aerowood's Avatar
Arvada , Colorado
Thanks everyone I knew there had to be a reason other then ease of manufacturing and cost. I believe I will go the "halvies" route also.
Old 02-23-2007, 10:13 PM   #11
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Oops! My bad. All my VAP mail runs through googles gmail and they thought you were spam .
I got it now.
Sorry for the goof up!
-Tim
Old 02-23-2007, 10:36 PM   #12
Images: 59
Are you telling me that everything gmail sees that isn't a gmail address is spam?
I'd get rid of it if I were you. What good is an email server that sends everything to the junk folder?
Old 02-23-2007, 11:12 PM   #13
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Not at all.
In the few months I've been using it, yours is only the second email that I expected that went in the spam folder.
-Tim
-Tim
Old 02-24-2007, 03:37 AM   #14
Images: 59
I'm curious what filter they used when they decided my message was spam.
Do you think it was the number of attachments?
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
