Old 05-16-2015, 07:32 PM   #1
1970 25' Caravanner
ft collins , Colorado
ab Electrolux refridge
Hello, my name is Mike, and this is the first time to post a thread. I purchased a 1970 A/S Caravanner 25' in June 2013. After getting it home I discovered it needed a lot more work than I was expecting when I bought it. Long story/short version, gutted most of the interior, and refurbished. While I had the Refer out, I had a R/V tech I have known for over 25 yrs. check out all of the appliances. The Refer needed a new heater, which made the L.P. work just fine in the garage, and also the 110v worked fine. Once in the trailer I discovered that the L.P. flame is not adjustable, so whether it is set on #1 or #10 the flame is the same, and it just keeps cooling down. It was down to near -0- when I finally turned off the L.P. and ran it on 110v. Q. Does anyone out there know of a source for parts on this AB Electrolux made in Sweden. I am not sure if this is org refer or not, but I think it is. I would like to keep it and rebuild or replace the controls if at all possible. Model #mb-52-c prod#9260920 don't have a date of mfg.
Also would like to install electronic igniter, since the old manual spark igniter is worn out. Local R/V shop said this is now owned by Dometic and parts are not available.
Thanks for any help. Mike, Ft Collins Co.
greybeard41 is online now   Reply With Quote
electric only refridge pearl66 Refrigerators 24 05-30-2010 07:29 AM
Refridge in 72 Tradewind won't cool RichHog Refrigerators 14 03-01-2009 07:22 PM
RM 3807 Refridge-I-hate-ya dalefox Refrigerators 3 08-05-2008 12:13 AM
Refridge light not working, Well it works too good ??? myfirstrv Refrigerators 5 05-07-2008 02:24 PM
recommendation for Refridge Tech DKinsey Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-23-2005 07:51 AM
