Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-02-2008, 06:51 AM   #1
Profile:  1966 28' Ambassador
1965 30' Sovereign
1972 31' Sovereign
rutherfordton , North Carolina
'72 Refer Gurgle
Aside from the eerie gurgle, the refer does not cool. As best I can tell, this is a leak...ammonia is boiling but there is no hydrogen...yes? What's the prognosis? One site suggested pressurizing and fixing (presumably plugging) the leak.
Any help appreciated. I have not tried on gas as I haven't replaced the lp valves yet.
acanthus is offline   Reply With Quote
Old 05-02-2008, 06:58 AM   #2
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
If your refer has leaked any part of the coolant mix (hydrogen/ammonia) the unit WILL NOT COOL and no 'fix' will help the situation. Plugging it will do nothing to remedy the situation! And be careful....HYDROGEN IS EXPLOSIVE (remember the Hindenberg).
There IS one fool-proof solution...........REPLACE THE COOLING UNIT!!!!!!!!!!
Other than that............................IMHO.............. .you're wasting your time trying to repair a leaking unit unless you are properly equipped, trained and experienced in refurbishment of said units.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-02-2008, 07:02 AM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 35
If you can smell ammonia, you have a leak and will need to replace the unit.
If no ammonia smell you most likely have a blockage inside the cooling unit.
The following procedure has been done with success by several people who had the same issue. Results may vary...
1.Remove the unit from the trailer.
2.Turn the unit upside down for 24 hours
3.Install the unit back in the trailer (Right side up)
Lew, Ken and Ken did this last year and posted the results if I can find them...
This procedure will only cost you some time and effort. In my opinion, it is worth a try.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-02-2008, 01:58 PM   #4
"Anything to Camp"
Ike T's Avatar
Profile:  1976 Argosy 24
Marietta , Georgia
"Reefer gurgle"? I hoped this thread would describe some new way to get high.
Tim
1976 24' Argosy
1973 International Travelall 1010
1973 International Travelette 1210 4x4
See you at the Falluminum!
Ike T is offline   Reply With Quote
Old 05-03-2008, 08:29 AM   #5
1965 30' Sovereign
1972 31' Sovereign
'72 refer gurgle
Thanks Lewster,
I'm not properly equipped, trained, or experienced to do much of anything (smile), even replacing the cooling unit but I am willing to try. They are not cheap, I believe....what's the best avenue there?
Lance
Old 05-03-2008, 08:33 AM   #6
1965 30' Sovereign
1972 31' Sovereign
Thanks AZ, guess I'll have to take it out to replace anyway, worth a try...if you find the posts, lemme know.
Lance
Old 05-03-2008, 08:40 AM   #7
1965 30' Sovereign
1972 31' Sovereign
I was "refer" ring to to the refrigimerator although the "refer"erence you raise might be a "refer"endum on Saturday afternoon activities. smile
Lance
Old 05-03-2008, 09:44 AM   #8
Phoenix , Arizona
Images: 35
Here is the thread I was talking about...
Mythbusters Burp the Fridge
Richard
Pingbacks are On
Refer woes kevino Refrigerators 4 07-15-2006 05:59 PM
Rebuild Refer 3237 Refrigerators 8 06-05-2006 05:25 PM
Refer Madness! TroutStream Refrigerators 11 08-07-2004 11:36 PM
Is my refer working? Tin Hut Refrigerators 4 10-03-2003 02:49 PM
New refer. 77caravaner Refrigerators 1 10-31-2002 11:04 AM
SEO by vBSEO 3.1.0
