Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 05-28-2015, 03:58 PM   #1
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
'67 Fridge Freon?
Does anyone know off hand what Freon type is in a fridge from a 67' Ambassador?
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 05-28-2015, 06:23 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is an RV refer. It does not use freon. There is no compressor. It uses ammonia which is heated in a boiler with a small flame or electric heating element to cool the refer.
Old 05-28-2015, 06:49 PM   #3
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
How would you go about refilling it?
Artisan Airstreams
Old 05-28-2015, 07:06 PM   #4
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Here is a pic of the back of the fridge. I see a port in the lower section of the unit, I'm assuming it is the port to fill and or replace the ammonia. I have all the necessary HVAC equip to work on automobiles so I can accomplish this, I hope.
Artisan Airstreams
Old 05-28-2015, 07:14 PM   #5
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
There are several companies who specialize in refurbishing the cooling units from RV fridges. The stuff inside is toxic. Probably not a job you should attempt yourself.
Old 05-28-2015, 07:17 PM   #6
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
yea I'm doing a lot of research including services that do this. I will have confidence if I attempt this, if I have any doubts I'll take it elsewhere.
Artisan Airstreams
Old 05-28-2015, 07:26 PM   #7
1974 Argosy 20
Kooskia , Idaho
It is basically impossible for you to do any refrigerant serviced work on an absorption refrigerator. They are totally different from compressor units. The port you see is not a service port like you are used to in automotive refrigeration. There is no way for you to tell in fact that it has had a leak.
This is not a do it yourself job, unfortunately.
Old 05-28-2015, 08:16 PM   #8
1972 25' Tradewind
McHenry County , Illinois
idroba is absolutly correct.
I've been an ACE, VW, Audi, Austin Rover NA Master Tech with additional factory training in BMW and Volvo for over 40 years. I've worked on Vintage Trailers for 25 years.
No disrespect, but what you think you know about the refrigerant cycle in auto service is only partially applicable to RV absorption refrigerators.
I had a most unpleasant emergency room visit 15 years ago due to an ammonia gas leak.
Search the threads on bringing these fridges back to life, it can be done, but, do not open any lines fittings or valves. Your eyes, lungs and wallet will thank you.
Tom
Tom Nugler is offline   Reply With Quote
Old 05-29-2015, 03:13 PM   #9
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Im convinced, I don't know why I would want to but I was assuming it was a similar system to automobiles and that you would have to "refresh" the refrigerant. I will obviously need to do some more homework about this unit... Thanks everyone for pointing the right direction! That was the point of the thread. Uncertainty gets people in trouble.
Artisan Airstreams
1987 P30 R12 Freon Capacity 8rmesse Classic Motorhomes 21 05-15-2013 06:26 AM
any ideas??? Dometic to freon conversion? bookman Refrigerators 8 09-20-2008 01:13 PM
AC needs freon charge? 1977 excella gunny2007 Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-13-2007 06:39 AM
Electric/freon type RV Refrigerator adonh Refrigerators 2 05-03-2007 03:49 PM
Armstrong freon charge Gino Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-02-2004 12:18 PM
