Old 07-28-2014, 09:18 AM   #1
AtlasCoffee's Avatar
1965 24' Tradewind
Pleasant Ridge , Michigan
'65 Dometic M52B
Hi all!
I have run into a little problem with the original fridge in our 65 Tradewind. It works well on LP, but does not cool on AC. The pipe in the rear coming from the heating element gets hot to the touch, but apparently not hot enough. The switch at the bottom of the fridge is set to "On" and I set the thermostat initially to 4, and after several hours of no temperature change, set it to max which didn't change anything as well. I suspect the thermostat to be messed up but I don't know how to test it.
Does anyone have any insight as to what is going on?
Thanks!
Chad
AtlasCoffee is offline   Reply With Quote
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
