Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-24-2009, 02:28 PM   #57
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
More bummers!
Is there a chance that the adjustments to the refer put added stress on the side panel?
See my blog: http://1964airstreamsafari.blogspot.com/
VIKING is offline   Reply With Quote
Old 06-24-2009, 03:05 PM   #58
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
Send a message via Yahoo to Buttercup Send a message via Skype™ to Buttercup
I don't think so - This is actually the 2nd time it came out. Never came out with the old axles....
Buttercup's Web Site. Save WBCCI - Save Wally! Check out the SaveWally Unit Guide. WBCCI # 17330, VAC Membership Chair/Webmaster, CAC.
2009 Mouse count:
Buttercup - Possibly 3 but I haven't caught them - yet!
Airtini -
Buttercup is offline   Reply With Quote
Old 06-24-2009, 03:13 PM   #59
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Clearly there are some things going on that are shaking the RV more than it should if things are ripping out. I am not sure though if it could be tires or the axle. Have you tried putting Centramatics on it to help better balance it out? I realize at some point one could keep throwing money at the problem. Your problem is perplexing because I have been down some washboard type gravel/sand roads and have not had similar issues as you've exp and my fridge is now 6 years old.
Old 07-06-2009, 10:31 PM   #60
Buttercup's Avatar
1954 25' Cruiser
We are currently on thew road going from Waukesha, WI to Reno, NV. We spent a few days in Waukesha with family over the 4th of July weekend. Had a great time. The 50 minute drive from Madison to Waukesha caused no problems with the fridge. In fact, parked in Waukesha at my brother's place we were not quite level and still all was perfectly fine with the fridge.
But as expected, getting on the road yesterday, after about 2 hours, the fridge was already up to 50 degrees from 36. No check light, no nothing.
So, I tried all of the last things recommended to me:
I have that drain tube plugged. I sealed the seam between the plastic fridge walls where it meets the metal mounting flange. I used blue painters tape to seal that. This was the recommendation from Dometic's rep at International. Beyond that he has never heard of a problem like mine.
I pulled the duct cover that draws the hot air out of the top of the fridge, turned both my fantastic fans on medium sucking tons of air through the back of the fridge, across the condenser and out. It actually moves a very respectable amount of air! I did this to prove that it was not a ventilation problem and I think it is 100% safe to say - it ain't a ventilation problem!
What I see in this configuration is that the boiler is still nice and hot to the touch but the absorber coils are cool.
However, Having that vent cover removed allowed me to feel another parameter that I could not before - the outlet pipe from the boiler to the condenser. Guess what... it was also cool to the touch. In fact, If I reach my hand all the way to just beyond the boiler outlet, that also is cool to the touch or at least not too hot at all.
Let the fridge sit for an hour and the condenser gets warm but the fridge temperature does not improve.
Witness the picture of my happy wife Kimber holding the thermometer she pulled out of the fridge this morning - 58 degrees.
As of the start of this writing of this post we were at 65 degrees in the fridge and the freezer is starting to thaw, ice melting. I have once again thrown in the towel. The most perishable things already went into a cooler that we brought along - again. The rest of the stuff in the freezer is going into the brand new electric cooler we just purchased at Wally World.
And at this point I can not express enough the frustration I have with this fridge, my inability to prove that it is anything other than our axles shaking the daylights out of that fridge.
The only thing I can not yet try is running on electric. The demands on the batteries and the charging requirements for the inverter would be too great. Besides, it works all the rest of the time - on gas or electric.
Anyway, I think it is time we take it out to the Nevada desert and aerate the damned thing. I an still going to give Dometic another try. There has to be a reasonable explanation - if not the axles. There has to be.
ID:	83519   Click image for larger version
2009 Mouse count:
Airtini -
Old 07-06-2009, 10:47 PM   #61
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Kimber;
A better placement of your "finger" on the thermometer may help!!
whaaat. Drive safe.
I stumped also.
www.popasmoke.com
Proud Appellation American
Vine View Heights- now closed
practice safe eating- use condiments
YETI (65 quart)
doorgunner is offline   Reply With Quote
Old 07-06-2009, 11:34 PM   #62
NevadaGeo's Avatar
Profile:  1978 31' Excella 500
Genoa , Nevada
Tim, I haven't seen numbers on someone checking the refer freon coolant level/pressure. I'm sure you did it tho.
I had a drill rig once get a rock that would float in the air standpipe, the driller could not find why he couldn't get any reverse circulation off bottom of the hole, until they took the top head off and managed to blow the rock out. It would float up and block the exit of the pipe, but fall down when they were looking for it. Maybe a floating blockage right at the exchanger oriface. (Probably way off on nomenclature there).
Perry
no one ever reads the fine print
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 07-07-2009, 12:14 AM   #63
Luminati's Avatar
Profile:  1978 25' Tradewind
Petaluma , California
Have no fear;help is here
Tim...you need this special tool to fix that damnetic! -Karin
http://youheardme-rants.blogspot.com/
"However beautiful the strategy, you should occasionally look at the results".
Sir Winston Churchill
Luminati is offline   Reply With Quote
Old 07-07-2009, 02:13 AM   #64
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
Tim, if all else fails...
Boat drinks
By: jimmy buffett 1979
Boys in the band ordered boat drinks
Visitors scored on the home rink
Everything seems to be wrong
Lately, newspaper mentioned cheap air fare
I gotta to fly to saint somewhere
Im close to bodily harm
Twenty degrees and the hockey games on
Nobody cares they are way too far gone
Screamin boat drinks, something to keep em all warm
This mornin, I shot six holes in my freezer
I think I got cabin fever
Somebody sound the alarm
Id like to go where the pace of lifes slow
Could you beam me somewhere mr. scott?
Any ol place here on earth or in space
You pick the century and Ill pick the spot
Oh I know, (I know)
I should be leaving this climate
I got a verse but cant rhyme it
I gotta go where its warm
Boat drinks
Waitress I need two more boat drinks
Then Im headin south fore my dream shrinks
I gotta go where its warm (I gotta go where its warm)
I gotta go where its warm!
I gotta go where there aint any snow
Where there aint any blow
cause my fin sinks so low
Tim...forth verse seems to be one answer to your problem...
Wow, you've got a bundle of things going on with your cooler/warmer...
To my way of thinking, if it works when stationary, it should work when on the road...so, I'd really check around for something that's disturbing the burner or flame propagation...or disturbing the proper airflow up and over the coils...do you have any unusual fixtures on the roof, around the frig vent that might be screwing up the 'normal' venting process??? Have you checked to see if you have a big mud wasp nest inside the roof vent??? I found one in ours when we first bought it - it was blocking almost half of the vent!!! Just some thoughts...
Road 'bounce' should promote proper gas/fluid flow through the cooling system - provided the burner/flue is working properly...again, that's where I'd concentrate my 'search'...burner airflow when moving...
I also don't think the axles are a contributing factor...our 28 footer has it's original frig that works really great, on, off, the road or upside down, maybe...AND I've put those same #3500 new axles on our rig last year - and in fact, the 'ride' is much 'easier' when compared with the old 'stiff' axles...in about five trips on the new axles, I haven't noticed any evidence of 'motion sickness' in the AS's construction - loose rivets, etc...
I bought one of those fiberglass 'funnel' shaped manifolds that you mount over the upper coils - and has a muffin fan in the top that's controlled by a thermostat...As you have to remove the frig to mount this rig, and the frig continues to work great, I haven't made the effort yet to install it! However, it does look like a good way to improve the air flow in an Airstream's cramped ventilation quarters...a project for a future date...!
Good luck on your mystery...let us know when you solve it...
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
Old 07-08-2009, 03:37 AM   #65
Buttercup's Avatar
1954 25' Cruiser
You all are so funny! Karin - if I had that tool, I bet it would be fixed from FEAR! Wow!!!
Mexray, I have a feeling that when the boiler is warm but the outlet to the condenser is not, that also indicates a circulation problem. A hot boiler means that the flame is on and running but ammonia is not moving, right? I am no expert but learning more and more every day!
However, I believe that what Perry says may be a thought... But what could be plugging the pilot tube inside the boiler??? And how does it get free when the unit is off and all thawed out?
I am going to call Dometic again. I saw another '77 with #3500 axles like mine and the same fridge with no problems at all. So perhaps it is just the unit that is bad. New doesn't mean that it is good, does it?
2009 Mouse count:
Airtini -
Old 07-08-2009, 11:15 AM   #66
Profile:  2008 25' Safari FB SE
Crawford , Colorado
I'm thinking that no matter what you do, that refrigerator will not work properly. There's something wrong with it that can't be fixed without taking the whole thing apart and finding the beer can stuffed in there or whatever may be screwed up. Only if Domestic replaces the whole unit or rebuilds it completely, will you have satisfaction.
Gene
CrawfordGene is offline   Reply With Quote
39 year old Dometic Refrigerator BobbyW Refrigerators 24 05-10-2006 03:35 PM
Engine/Year Trans/Year Matrix 1985air345 Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 08:40 PM
New Dometic...warranty work? JohnGalt48 Refrigerators 5 06-28-2004 03:29 PM
they work....... another project Electrical - Systems, Generators, Batteries & Solar 3 11-30-2003 05:46 PM
How does this work??? thenewkid64 General Motorhome Topics 7 07-21-2003 09:58 PM
