Old 06-26-2013, 03:43 PM   #183
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
how about just having a martini and taking a nap.
doorgunner is offline   Reply With Quote
Old 06-26-2013, 09:16 PM   #184
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Yes, Problem solved! zzzzzzzzzzz
SuperTrouper is offline   Reply With Quote
Old 06-26-2013, 10:05 PM   #185
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
You can't diagnose some of these things with too many martinis in yer belly. Sometimes you need a clear head to figure out the problem. Yes, this is ME talking.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 06-26-2013, 10:23 PM   #186
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
clear head ? sounds like some Navy lingo to me.
the nap does wonders to clear the brain. lol
Old 06-27-2013, 06:05 AM   #187
1981 31' Excella II
New Market , Alabama
Buttercup did this overcooling problem happen because you tried to increase airflow or was it like that to start with?
Perry
Old 06-27-2013, 08:36 AM   #188
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Perry
It was like this from the start. In fact, I would guess that even the original fridge we had in this trailer had exactly the same problem.
I think it is perhaps a dynamic of the air flow around our TV that could be forcing extra air into the cooling path. Can't prove that but just suspect it could be happening. For now, our fridge is running perfectly - still.
Old 06-27-2013, 01:36 PM   #189
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Is your air inlet the type that goes through the floor?
Old 06-27-2013, 02:57 PM   #190
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
No, it is outside air supplied to the grated access door. That is where I put the piece of MDF board to restrict airflow.
Old 06-28-2013, 04:09 PM   #191
LFC
Memphis , Tennessee
Have you checked the gas pressure ?
Mine was doing the same thing on gas and the regulator just needed adjusting.
You can also adjust the temperature up or down by sliding the little white cover up or down (it's next to the fins in the refrigerator) on Dometics without an adjustable temperature knob.
LFC is offline   Reply With Quote
Old 06-29-2013, 09:12 AM   #192
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Oh yes, checked the gas pressure with my manometer at the regulator, at the fridge AND at the burner tip per Dometic's instructions and all were exactly as specified after some adjustment. Was not off enough to cause the problem and as always worked when we were steady, but quit going down the road.
Old 07-01-2013, 02:58 PM   #193
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I won the VAC Concours d'elegance award for best engineering feature for my thermalcouple system and fan modifications to my fridge.
Old 07-01-2013, 03:42 PM   #194
Ottawa , ON
Thumbs up
Yay!! Well-deserved!
Old 07-01-2013, 06:50 PM   #195
1981 31' Excella II
Next time you need to do a 6 DOF test before getting a new unit. You know one of those transducer driven shaker table things like they test fighter jets on. I am sure they have an Airstream simulation you could use.
Perry
Old 07-01-2013, 09:44 PM   #196
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Ha, the roads in Minnesota are doing that for me now!!! Bumpy!
3 hours on the road, 40 degrees.
39 year old Dometic Refrigerator BobbyW Refrigerators 24 05-10-2006 02:35 PM
Engine/Year Trans/Year Matrix ViewRVs Mechanics Corner - Engines, Transmission & More... 36 10-23-2005 07:40 PM
New Dometic...warranty work? JohnGalt48 Refrigerators 5 06-28-2004 02:29 PM
they work....... another project Electrical - Systems, Generators, Batteries & Solar 3 11-30-2003 04:46 PM
How does this work??? thenewkid64 General Motorhome Topics 7 07-21-2003 08:58 PM
