Old 03-05-2011, 07:10 AM   #1
Lothlorian's Avatar
Loganville , Georgia
3 refrigerator installation questions
I am taking a Dometic Silohette refrigerator from another RV and installing it in my 1960 Overlander. I have the vented panels on the side and I have a plate inside over a chimney vent that has never been used (old fridge was electric). I was going to lay vinyl flooring where the refrigerator will sit.
What do I need to know that I might not be considering?
What is used to attach the refrigerator chimney to the one that is covered on the wall?
Does the floor need anything special?
All help and advice is needed.
Brian
Name:	dometic refrig.jpg
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 03-05-2011, 07:28 AM   #2
OO , OO
Send a message via Skype™ to cruiser54
Best of all you look in the Installations instructions with Dometic.
According to model (gas?) it needs in the ground or in the outer wall air supply.
In my Blog I have drawn the installation of my fridge.
Greetings from Switzerland
Werner
cruiser54 is offline   Reply With Quote
Old 03-05-2011, 07:31 AM   #3
Lothlorian's Avatar
Thanks Werner! I will do that.
Brian
Brian & Adrienne
Old 03-05-2011, 07:44 AM   #4
Images: 59
Check the location of the outside vent. It needs to be low on the outside wall.
My '59 Tradewind also had an electric only refrigerator. It had a small inlet vent in the floor through the belly pan, and an outlet vent at tummy level. If this is the same arrangement as your '60 Overlander it will not work for a 2-way refrigerator.
For best performance you need an inlet and outlet vent separated by at least 60 inches. More is better. More separation gives better draft and better removal of heat from the condenser.
You can build your own refrigerator chimney from aluminum, or lay one up out of fiberglass. I made mine out of aluminum.
Here is a picture of the inlet vent I added. The original vent at tummy level was changed into a door and shallow storage compartment for hoses and power cords.
Second is a picture of how I did the chimney.
ID:	123680   Click image for larger version
markdoane is online now   Reply With Quote
Old 03-05-2011, 08:45 AM   #5
Lothlorian's Avatar
Mark:
I have the lower vent like yours. Next thing I need to know is what do they attach from the chimney to the vent connection inside the trailer? Do I have to order it or can I buy it at a hardware store.
Brian
Brian & Adrienne
Old 03-05-2011, 09:12 AM   #6
Images: 59
Do you have a picture?
You can buy a premade refrigerator scoops made from ABS or fiberglass. I don't know if Out Of Doors Mart has them. I think they have them at Inland RV.
They might be pricy, which is why I built my own.
Is your chimmney round, or is it oval?
Old 03-05-2011, 09:20 AM   #7
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
No Connection
Originally Posted by Lothlorian View Post
Mark:
Brian
In our '66 Safari, there is no connection between the lower vent (ours is in the floor) and the upper "chimney" over the refrigerator compartment. The outer wall of the trailer, the back of the refrigerator, and the walls of the refrigerator compartment form a passage for the air to flow upward across the fins of the refrigerator cooling unit. Make sure the "chimney" is well sealed to the interior part (counter, etc.) over the refrigerator, and that the refrigerator is well sealed into its compartment.
We found a lot of great schematics and information at rvmobile.com.
mimiandrews is online now   Reply With Quote
Old 03-05-2011, 05:59 PM   #8
Lothlorian's Avatar
I am posting some pictures and please give me some of your thoughts.
If you notice you can see where there was a vent installed on this trailer. There is a hole under the metal protection cover. No screen and it does not go through to the inside. Why is it there? I have no idea. It is first picture.
2nd picture is the plate I removed only to find A.C. wires. Somebody must have installed the outlet.
3rd picture is of the refrigerator area
4th picture is the roof that does not have an chimney outlet to the outside.
I would like to use the chimney out let in the first picture. Is it big enough? How big does the exhaust hole need to be?
I have a plan for the cabinet. I will build it all the way to the top.
Brian
ID:	123724   Click image for larger version
Name:	plate removed.JPG
ID:	123726   Click image for larger version
Name:	outside vents.JPG
Brian & Adrienne
Old 03-05-2011, 06:03 PM   #9
Lothlorian's Avatar
Inside ceiling with not outlet for chimney.
Brian
Brian & Adrienne
Old 03-05-2011, 07:03 PM   #10
nmbosa's Avatar
Nowhere , Washington
Brian
Brian,
The chimney for your fridge is in the second picture in post 8, just above the outlet. The fridge gases were vented into the wall and up to the eyebrow vent on the outside of the trailer. Here are some pics of how it looks when the skins are off. You can see the tiny 1 1/2" hole that lets the gases out through the roof in the first picture just to the left of the larger collar. The original owner of my trailer installed the collar and later model fridge chimney/flue sometime in the 60's. I'm really not sure the original 1960 venting setup is sufficient for a modern fridge.
Norm
ID:	123742   Click image for larger version
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 03-05-2011, 07:10 PM   #11
Lothlorian's Avatar
Thanks Norm,
I guess this is going to get a bit more complicated. I will have to order the new collar and vent cover and install it.
Brian
Brian & Adrienne
Old 03-05-2011, 07:10 PM   #12
1972 25' Tradewind
Falling Rock , West Virginia
On my 72, a PO ran a extension cord through the floor and belly pan. The extension cord allowed to run the fridge, without hooking up the entire camper. You can also take off the access door for lighting the propane part of fridge, and switch to the Airstream 110 system.
HillBilySkMo is offline   Reply With Quote
Old 03-05-2011, 08:22 PM   #13
nmbosa's Avatar
Thanks Norm,
Brian
Brian, before you order the collar and vent cover, take a look at Frank's blog post from when he replaced his original Dometic. He went ahead and used the original venting setup with the small eyebrow vent and it seemed to work fine. He riged up a method of channeling the gases into the wall. You might want to call him and ask how that is working.
Norm
Norm and Mary
Old 03-06-2011, 03:37 AM   #14
Lothlorian's Avatar
Norm:
I really appreciate your ideas and help. If you look at my vent doors from the outside you can see I have two doors vent doors. That is a pretty big surface area of fresh air coming in. Convection currents is what I am most concerned about. Hot rises and leaves cold air to fill in the area (air pressure). I just want to make sure the hot air has a way to circulate out of the trailer. Much of those coils will be up against the vents and air circulation should be constant. I will have to measure and observe.
I may go with the original because I can always come back and add another vent.
I might give the person who kept his original vent a call.
Brian
Brian & Adrienne
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
Newbie Basics Question(s) Stonew98 Member Introductions 10 02-27-2011 08:21 PM
'62 Safari electrical update questions Peggy Wilson Electrical - Systems, Generators, Batteries & Solar 3 02-12-2011 07:23 PM
2010/2011 Sport 22 FB Questions smeghead Member Introductions 16 02-10-2011 10:09 AM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
