Old 07-28-2011, 09:24 AM   #1
AndrewM's Avatar
1954 25' Cruiser
Nashville , Tennessee
12V Conversion for Vintage 110v Fridge
My Cruiser was most likely a park model being entirely 110v. I am not sure (as many on this forum probably are) when 12v systems were introduced into Airstreams, but I know mine had nothing of it.
A few months ago my original refrigerator gave up the ghost. It in all purposes is not a well designed fridge just a glorified ice box with a condenser unit. But it is original, and has a great feel and look to it. It is a Marvel, as seen below:
Since that fridge stopped working I have been considering my options. I do not like a propane option because I do not want to add another vent on the street side, but I would love a 12v mode for camping and on the road. But then I really wanted to keep the fridge, but I believe our sailing friends have an excellent solution actually produced by Dometic.
Custom Cooling Kits - Dometic
Dometic bought the Adler Barbour company, which has been around for many years now and are known for their reliability, especially the units using the Danfoss BD50F compressors. These systems run exclusively on 12v and for a 4.5 cubic ft. space use about 40-50 amps per day (varying on application and evaporator unit)
I will probably do this conversion for a number of reasons:
1. it uses quick connections that allow for DIY install and you can even disconnect the unit from the evaporator without losing charge
2. it uses r-134a so if it ever needs recharged it will be a quick run to autozone
3. They are made for boats so they can handle movement and will work on a tilt.
4. it comes pre-charged
Now the cost will range from $800 to $1000 but for a r-134a 12v fridge that I can install and service myself, with a large community of support and parts, and that saves my original fridge; I find that to be a mighty good deal.
I still have a few questions to answer but I am pretty excited about the alternative. I know a few of the Cruiser guys may be excited to hear about this.
The blog of Airstream brothers: www.airstreamfever.com
AndrewM is offline   Reply With Quote
Old 07-28-2011, 09:54 AM   #2
1977 Argosy 24
Milltown , Wisconsin
So you could easily run 3-4 days without charging the batteries, sounds good.
ventport is offline   Reply With Quote
Old 07-28-2011, 09:54 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
That is a great idea. The CS NC 15 unit
As long as you have the space behind or along side the box you are home free.
2004 Excursion 4x4
Old 07-28-2011, 11:13 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
40 to 50 amp hours per day is a pretty good load when boondocking. Normal power consumption for us is in the 30 to 40 amp hour range which is pretty typical. Add another 50 amp hours to that and you would pretty well discharge a 1 battery system in a day.
Thats assuming that the 100/120 amp hour rating per battery is honest and the batteries are fairly new.
It will take a fair number of hours of generator time or a large solar system to keep up with it.
I can understand you not wanting to cut another vent, but the other side of the coin is a 30 lb bottle of propane will run a fridge and cooking for around 3 weeks for about the same weight as the battery that discharges in one or 2 days at best
If you usually have hookups, no problem. If you frequently boondock for long periods as we do I don't think it would work out too well
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-28-2011, 04:43 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Hi Andrew
First of all you want to be absolutely sure that any of the existing coils you're planning on reusing don't leak. Leaks are the main reason really old fridges fail. You, or a refrigeration tech you trust, should pull vacuum on the system and observe that it will hold it overnight with no measurable loss. If there are leaks you want to be sure either that they can be fixed or that you do not reuse that part of the system.
Second of all if the original compressor failed you will want to be sure that it did not contaminate the sealed system. It is common for there to be substantial debris introduced into the refrigerant during catastrophic failures. There is no 100% effective way of cleaning the sealed system once this happens. Techs used to use R-11 as a flushing agent but that's not permissible under the current laws. Other methods pose fire hazards, as even compressed air can cause the remaining refrigerant and oil to form a flammable mixture. Strategies vary. In any case you will want to add a filter/dryer to catch anything that never got flushed out.
Finally even though the Danfoss parts come pre-charged you will want to pull a vacuum on the existing system before releasing refrigerant into it as the air and water vapor that are present will pose problems for thermal performance as well as leading to premature compressor wear.
I think the old fridges are well worth keeping. You're on the right track but be sure you don't skip any important steps.
Old 07-28-2011, 04:56 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Finally you may want to see what the Marvel originally used for refrigerant and how its thermodynamic properties compare to R-134a. If it originally used R-12, then R-134a will work fine although the amount of cooling will drop by about 10%. If it originally used R-11 then R-123 may be a better choice. Most compressors will work with either, I'm not sure what Danfoss says about theirs.
Old 07-28-2011, 05:21 PM   #7
pbearsailor's Avatar
Port Hadlock , Washington
I'd sure second what Rick posted.
I've used 12 volt units on our boat for over 20 years. They are reliable, easy to install, and last a long time. But, the power requirements are large. We run a 12 volt system with a cold plate instead of evaporator, so it's more efficient, but still it uses around 40 amps a day for a very small, top opening box with no freezer. We have 6 inches of insulation around the box. We cruised fulltime for years, unplugged, and it took 200 watts of solar and a wind generator to keep up.
Don't think a large, front opener like the Marvel can approach our efficiency.
If you're plugged in all the time, it'll work great. It'll do fine, fairly quiet, and very reliable. If you boondock, I seriously doubt how you can do it.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 07-29-2011, 02:39 PM   #8
AndrewM's Avatar
1954 25' Cruiser
yes but...
If I wasn't so committed to the original fridge I believe a Norcold would definitely be the way to go. The option to do propane is the best way to go when boon-docking, I wasn't trying to argue against that. I think the 12v refurb is only for those who do not wish to let go of antique appliances.
But for now I am full timing and the the next year or two my setup will be mainly for full-timing. As I say that it may seem useless to go for 12v at all; and it may be, but the ability to keep the fridge cold during transportation and a 2 day boon-docking seems like a good deal to me. 40 to 50 amps per day is no small pull, you're right; but it is doable. If I was to get serious about boondocking in a few years, which I hope to, I would like to get two solar panels on the roof that would let me extend my boondocking into a week or two.
Jammer, your concerns are valid if I were to use some of the existing components; but I do not think I would if I were to do the conversion. That means that both the original condenser unit; piping, and evaporator are being removed and I will install either a new evaporator or 'cold plate' in its place. The main concern is for releasing the r-12; I will need a pro to come evacuate it so as not to kill the enviroment. Otherwise from my current understanding, both the evaporator and the unit come sealed and filled ready to be hooked up with 'quick-connect fittings'
So while it is not perfect; I believe the 12v marine option is the best for those trying to preserve the antique feel of 50's appliances while updating to 12v/modern guts
12v
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
Fridge Sorta Kinda Works perryg114 Refrigerators 17 10-23-2011 07:46 PM
New fridge on the Outs? skydiva Refrigerators 2 07-04-2011 03:04 PM
Swap 12V LED for 110V Bulbs? Roadrunner Lights - Interior & Exterior 1 06-12-2011 03:12 PM
1960 Electrical 110V & 12V question Lothlorian Electrical - Systems, Generators, Batteries & Solar 19 05-08-2011 11:58 PM
