Old 01-21-2007, 07:34 PM   #1
12 Volts for Fridge?
When I have my fridge running on gas, how much or or important is the battery voltage? last year I had a terrible time keeping my fridge running in the gas mode. It could run for several hours or just a few minutes. I never knew what to expect.
A few days ago I was installing a new converter and Trimetric meter. I discovered that my batteries were shot. So, now I have my new coverter, meter, and 2 new size 31 Trojan batteries. When I had the old batteries tested under a load, they would fall to 10 volts. Could the bad batteries been my problem?
Greg
85 Sovereign 25'
85Sovereign is offline   Reply With Quote
Old 01-21-2007, 08:33 PM   #2
east stroudsburg , Pennsylvania
Greg
85 Sovereign 25'
It depends if the refrigerator has electronic controls, like a circut board and electric gas valve. If it's all manual, batteries won't have any effect.
RV_cool is offline   Reply With Quote
Old 01-21-2007, 11:27 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
the problem I've found in my Caravel and Overlander is that the burner is not baffled sufficiently and blows out with slight wind (ambient or towing). I fabricated a small box with appropriate slots and crimps to fit around the bottom and sides of the burner. Problem solved--very reliable since then.
This was with a 30 year old model and a brand new model (neither has electronic controls). Another old model, which the new one replaced, had a hand-made baffle box installed, but I didn't take the hint until the new one blew out as soon as the trailer moved.
Zep
Old 01-22-2007, 07:22 AM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greg-
You don't mention the make, model or year of your frig. Let us know and I am sure someone can be more helpful for you. I know our new one uses very little amps when on LP. Just enough to run the board and ignite.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-22-2007, 07:24 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The fridge in my 75 does not require any 12 volts. A little propane and a spark makes it work!
Richard
Old 01-22-2007, 08:15 AM   #6
2005 22' Safari
1960 24' Tradewind
Ahh, yes you are connected to your 12V system, contol board and ignitor both run off your 12V system. Or do you have to go outside an use a piazo ignitor?
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 01-22-2007, 01:43 PM   #7
Sorry, I forgot some important information. The fridge is a Dometic 2804 (I think). I have the eyebrow panel in the TT with buttons for gas and A/C. Runs without any problems on electric. But with gas, I never know what it is going to do. I looked at the burner before and I think I remember that there is some type of shield around the flame, at the bottom of the flew. I had not turned the fridge on for over 12 months until yesterday. After I installed the new converter, meter, and batteries, I could hear the ignitor hit a few times and then bam, it lit and ran all day without any problems.
Thanks for all the help,
Greg
Old 01-22-2007, 02:05 PM   #8
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Greg, Unless I am mistaken, there is also a couple of elec switches on the inside of the fridge door, up at the top, pointed downward. Look closely. If you do, they are for humidity control, both inside as well as outside. If they are turned on, they pull enough power, that, with bad batteries, they could indeed pull them down to the cut off point for the computerized unit.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 01-22-2007, 04:48 PM   #9
Thanks for the info. I'll look for those switches. I made a mistake about the model #. I actually have a Dometic 2611. Anything special about this model that would cause this problem?
Greg
Old 01-22-2007, 05:24 PM   #10
2002 25' Safari
Dewey , Arizona
Images: 62
I do not think so. Model RM67 has no board. It has a piazo ignition. At least that is how I think it works. The manual shows no 12 volt connection.
Richard
Old 01-22-2007, 05:33 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Greg
85 Sovereign 25'
Greg,
I would say good possibility...if your fridge requires the twelve volts. I know the replacement unit in mine is very sensitive to low voltage. 11.75 volts and it quits on the spot. FWIW my fridge is a Norcold that was installed in 2000, they had to add a 12v line to feed it because the old one did not require it.
Aaron
WBCCI #XXXX AIR #2495
Old 01-22-2007, 05:51 PM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Greg,
I have the Dometic RM2620 in my 25' and it was a replacement. If you have buttons or switches which have ON/OFF, GAS/ELECTRIC/AUTO, a button for increasing or decreasing coldness and small lights to let you know what your fridge is doing then that panel uses 12 v. DC.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-22-2007, 06:19 PM   #13
Craig,
Yours sounds almost identical to mine. So does this mean that the fridge, when in the gas mode is very sensitive to battery condition?
Hopefully, with the new system I won't have the trouble I had with the previous set up.
Greg
Old 01-22-2007, 08:40 PM   #14
davidz71's Avatar
1986 25' Sovereign
Greg,
10.5 volts is considered 0% charged and 11.31 volts is considered 10% charged. You batteries were toast and I'd say they were the reason for your poor functioning refrigerator.
Craig
AIR #0078
3.73 rear end
12 volt
6.5 volts instead of twelve photoguy Batteries, Univolts, Converters & Inverters 4 05-28-2010 03:10 PM
New 6 volts draining too fast ! Phantom Batteries, Univolts, Converters & Inverters 4 09-19-2009 12:54 PM
12 volts shutoff then come back on??? dnrtheil Electrical - Systems, Generators, Batteries & Solar 9 05-01-2007 10:54 AM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
AC Guru 141 Volts Over59 Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-27-2006 10:56 AM
