Old 02-24-2015, 05:55 PM   #15
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
The exact same fridge from truck fridge is $300 less than isotherm from marine suppliers. Both are built by the same people. Look at them. They use the same model size name. Have the same shelfs, same compressor. Also note the door can be made to open left or right and the front panel can be switched as I did with wood veneer or an aluminum sheet.
Name:	ImageUploadedByAirstream Forums1424825673.860804.jpg
Name:   ImageUploadedByAirstream Forums1424825692.554579.jpg
FC7039 is offline   Reply With Quote
Old 02-26-2015, 10:48 AM   #16
Wolf Alaska's Avatar
Madison , Alabama
Thoughts on 12VDC Refrigerators
JRF0st3r, here's a few thoughts on your quest for a candidate 12VDC refrigerator. I'm new to the forum but have a long history with RVs since 1983.
12VDC refrigerators for RV use may be 110VAC/12VDC powered. The refrigerators will run on 110 if it is available and switch to 12 VDC automatically if the 110 goes away. A few are designed to run on 12VDC only.
I have a Norcold DE490 still in service at 19 years. It will run for 48+ hours on one 12VDC 115 A-H battery. The Norcold model that replaced the DE490 is the DE-0788. It has a 0.5 cu. Ft. freezer and a 3.1 cu ft. refrigerator section. The refer uses 0.8 amps @ 110VAC and 3 amps @ 12VDC. Estimated power consumption is 36 A-H per day. Weight is 62 lbs.
A larger Norcold is the DE0061 and EV0061. It has 1.7 cu ft. freezer and 5.3 cu ft. refrigerator section. Power consumption is 0.4 amps @ 110VAC and 3.2 amps @ 12VDC. Estimated daily power needed is 36 A-H. Weight is 105 lbs.
Dometic has a model CR1140E with 4.81 cu ft. It runs only on 12VDC and draws 5.9 amps. Estimated power consumption is 72 A-H per day.
A world famous DC refrigerator manufacturer is SunFrost.A good model for RVs is the SF RF12.This unit offers a freezer with 2.05 cu ft. and a refrigerator section of 8.07 cu ft.Daily power consumption is 24 A-H @12VDC @ 70o and 39 A-H@12VDC@90o.The unit weighs 230 lbs. SunFrost lists a price of $2579 + a $50 crating charge.
To summarize, 12 VDC refrigerators can be continually powered by an adequately sized battery bank supported by a PVC system that can generate a daily A-H harvest equal to the refer’s daily power consumption.With extra battery recharge sources from shore power, genset power, or alternator power from the motor coach’s engine or tow vehicle (TV) engine, there should be no shortage of power to keep the refrigerator running.Other advantages found with the 12VDC refrigerator include: no requirement to level the RV for safe refer operation, no need to buy propane for the refer, no additional load placed on an existing inverter (or possibly eliminate the need to install an inverter or replace an existing inverter with a larger inverter), and possible longer life compared to a propane RV refer.
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 02-27-2015, 08:16 AM   #17
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Wolf Alaska,
Thanks for sharing your abundant knowledge on this topic! I do appreciate it!
JRF0st3r is offline   Reply With Quote
Old 06-29-2015, 07:14 PM   #18
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Look for "Koolatron" plug in coolers. I have four of them, one in each car, and the others as req'd. They drop the inside temp about 40Deg. below ambient. One of them fits between the seats of a van, or in the back floor of our Camry. No Ice Cubes needed, just keep it plugged into a 12VDC outlet and the food stays Kool.
MelGoddard is offline   Reply With Quote
12 volt
24 volt or 12 volt solar panels advantages?? purman Electrical - Systems, Generators, Batteries & Solar 13 09-06-2012 02:29 PM
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 08:54 AM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
