Old 11-21-2011, 08:26 PM   #1
crane422's Avatar
1978 23' Safari
Columbia , Illinois
'78 Safari Project
Well I have the beast for a few weeks now and as my wife is sick and tired of hearing about it I thought I would post some pics and hopefully get some positive feedback
ID:	145763   Click image for larger version
ID:	145765   Click image for larger version
crane422 is offline   Reply With Quote
Old 01-10-2012, 08:30 AM   #2
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Offficial Thread
SO I have been posting all willy nilly all over the forums and finally got some helpful advice that I could just sort of stockpile all of the reno post here and just head to the other sections when needing a specific answer. I plan to update fairly often as I have made some progress(all backwards..but hey). hope to get some good feedback from everyone.
Old 01-10-2012, 08:35 AM   #3
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Hiding in my attic
Turns out you can fit almost the entire interior of a 23' Safari, minus appliances and beds in the attic of a mid 50's ranch!
Old 01-10-2012, 08:43 AM   #4
crane422's Avatar
1978 23' Safari
Columbia , Illinois
A/C Removal
A few leaks around the A/C unit so I decided to pull it down and send it off to HVAC land for inspection cleaning and some TLC. I think the black plastic adds a nice touch to the roof.
ID:	148662   Click image for larger version
Old 01-10-2012, 08:52 AM   #5
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Rear End Issues
Apparently there was a bit of moisture in the rear end of my trailer. Nothing a wire brush and some putty can't fix right?
Old 01-10-2012, 09:29 AM   #6
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Looks like you are leaving no stone unturned with having gutted the interior and now moving out to the back bumper/storage area. Are you going to put it back together in it's original form, or are you going to customize the interior to your liking?
dirigible25 is offline   Reply With Quote
Old 01-10-2012, 09:49 PM   #7
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Worth Reposting
I posted this in the plumping section the other day but it is worth reposting here for hopefully more to see since it scared the crap out of me:
I am assuming that I am not the first person to be as dumb as I was yesterday. Decided to drop freshwater pan and tank to inspect since PO had said water poured out when he tried to fill. Friend and I removed all but 2 bolts....he was towards back of trailer me at front removing a bolt...BOOM down comes a A FULL Fresh water tank and pan. If not for having 3 extensions on socket which caught the tank about an inch off of ground I would be at best with a broken arm and missing fingers at worst a smashed head! Lesson learned..always assume tank is FULL. Here is the culprit after removal.
http://www.airforums.com/forums/f163...all-86354.html
Old 01-11-2012, 11:11 AM   #8
crane422's Avatar
1978 23' Safari
Columbia , Illinois
I am going to do a little of both. Same basic layout, new furniture style, updated materials. Going to silver powder coat all screen frames and hardware and use black screen I think. Still figuring all that out. Interior budget will depend on how much more stuff goes wrong by the time I get to all that.
Old 02-22-2012, 12:32 PM   #9
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Finally Back at it..
Well the weather is nice in my little part of SoIL today so I played hookey and got a bit done on the stream. I am getting ready to remove the belly pan so today consisted of removing all the gas pipes (WOW a lot of fittings) and the stabilizers. The stabilizers are heading for sand blasting and powder coat and I stripped all the fitting of the copper for future use. A few observations, would it have killed them to secure the pipe clamps with screws instead of rivets, would it have killed the PO to use the SAME size screws on the stabilizers when he repaired them and again WOW alot of fittings for 4 gas appliances!
ID:	151690   Click image for larger version
ID:	151692   Click image for larger version
Old 02-22-2012, 12:40 PM   #10
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Water Tank repair
Also decided to ATTEMPT to repair the crack in my water tank today. From reading posts it appears that this is almost impossible and I should just order new but I find it hard to believe that in 2012 I cant successfully repair a 1" crack in a plastic water tank. Used a two part JB Weld product..pictures tell the story. We shall see if it holds water.
ID:	151694   Click image for larger version
ID:	151696   Click image for larger version
Old 02-22-2012, 01:11 PM   #11
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Hope you have better luck with tank repair. I tried it on my 65 let it cure for several days and then filled tank with water. After 2 days it started to leak so I put in a new(smaller) tank.
Size of screw (self tapping bolts) used on your BAL stabilizers. I found that I had to go to the next size up when I replaced older model stabilizers. Threads got rusty etc. Keep posting pics of your progress.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is online now   Reply With Quote
Old 02-22-2012, 02:29 PM   #12
crane422's Avatar
1978 23' Safari
Columbia , Illinois
I am hoping since my crack is above the water line at anything except 100% it will be ok.
Old 02-22-2012, 05:25 PM   #13
Film and Fabrication
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Hi crane,
nice looking trailer! I see that picture of the back end rust, which brought back bad memories! I had a lot of rust damage to my frame that has taken me some serious welding to fix. The picture you posted looks like some serious permeating rust. I would suggest you somehow get a good look at the rest of the frame, maybe take a couple wraps off. If that C channel is that rusted it could be that it's gotten the outriggers pretty bad. If I was in your position I would make sure to replace that cross member that's rusted all through in places for sure. Did one of the POs live near the ocean? My trailer came from VA Beach and I think that had a lot to do with how bad the rust was.
Here's a link to my thread, if you look at the second page you'll see that I had to basically rebuild the C channel in places because of the rust... It really deserves a good look under there to check it out. Good luck!
http://www.airforums.com/forums/f421...ybe-85368.html
Eric H is offline   Reply With Quote
Old 02-26-2012, 05:27 PM   #14
crane422's Avatar
1978 23' Safari
Columbia , Illinois
Another good day
Well another nice day in the good part of Illinois. Got the biggest part of the bottom skin removed. Looks like that piece is toast. All the rivet holes are rounded out and there is some actual tears and big holes. Found pretty much what I expected after I raised the trailer 8" to have working room, insulation, rodent nest, rust and dust. Overall I call it a successful day there is noticeable progress and no injuries. On that note I think I am going to get a tetanus shot sometime soon. Lots of rusty things in my future and no idea of the last shot.
ID:	152080   Click image for larger version
ID:	152082   Click image for larger version
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 08:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
Vintage 1967 Airstream 22' Safari, Project or Parts eBay Watch Airstreams on eBay 0 05-17-2011 06:20 PM
