Old 03-28-2015, 03:44 PM   #1
77 Safari 23ft - waster connector
I'm trying to source a replacement waste connector for my safari. See photos attached
I'm based in New Zealand and all metric here. 97mm on connection housing with outlet pipe (elbow) at 72mm
Help appreciated.
Name:	ImageUploadedByAirstream Forums1427578841.240016.jpg
ID:	235084   Click image for larger version
Name:	ImageUploadedByAirstream Forums1427578898.580248.jpg
Waipatiki is offline   Reply With Quote
Old 03-28-2015, 04:38 PM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
You can buy an adapter on Amazon to connect the old style plumbing to modern hoses, if they're the same in NZ as in North America,
With a trailer that age the plumbing is probably iffy at best, I ended up replacing all of the plumbing on my trailer.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 04-04-2015, 03:07 AM   #3
Thx - will look into it
Old 04-04-2015, 04:59 AM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
That is a Thetford connector. They are still available, and as AldeanFan mentioned, an adapter is also available to connect a Valterra connector/hose to the Thetford pipe on the trailer.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
2008 safari se by airstream 23ft.$ save thou sands$ eBay Watch Airstreams on eBay 0 10-23-2009 03:00 PM
New 2008 safari se by airstream 23ft.$ save thou sands$ eBay Watch Airstreams on eBay 0 09-17-2009 01:00 PM
New 2008 safari se by airstream 23ft.$ save thou sands$ eBay Watch Airstreams on eBay 0 08-22-2009 10:50 AM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
