Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1969 - 1973 Safari
Old 10-23-2016, 10:48 AM   #1
1972 23' Safari
Middletown , Rhode Island
What are these lights for?
Anyone know what these lights were used for on a 1972 Safari? Is it for reverse polarity or something? When I reattached my umbilical cord to the airstream these lights lit up. Thanks.
Mx468 is offline   Reply With Quote
Old 10-23-2016, 11:51 AM   #2
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
I bet you didn't know you had fiber optics in your trailer!
Those "lights" are actually lenses. There are two fiber optic lines that go to each brake light from there. You can see in rearview mirror if your brake lights are functioning. Yours is missing the cover but I think they are available
Al Boondy is offline   Reply With Quote
Old 10-23-2016, 02:08 PM   #3
cameront120's Avatar
1972 25' Tradewind
Yep, optics so that you can view if your brake lights work from the drivers seat. I think Inland Andy sells a metal replacement cover. The plastic original is long gone. The reverse polarity light is a round, clear, crystal looking fixture on the trailer.
North Vancouver, BC
Old 10-23-2016, 04:32 PM   #4
1972 23' Safari
Camas , Washington
when I had all the walls out I cut the fiber Optic not knowing what it was. I still have most of the fiber optic lines and the lens, its fun to show the grand kids how it lights up with a flashlight at the opposite end. I just did a round patch over the hole where the lens was. I did change to LED tail light not sure how I could have made it work anyway. I think there are some LED tail lights made to hook up the fiber optics.
Pams72 is offline   Reply With Quote
Old 10-23-2016, 08:31 PM   #5
1972 23' Safari
Do you know the whereabouts this polarity light would have been located? Thanks.
Old 10-23-2016, 08:37 PM   #6
1972 23' Safari
Is this the cover? If yes is it just a aluminum cover?
Old 10-23-2016, 09:04 PM   #7
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Yes, that's the cover, and you may know that Vintage Trailer Supply sells them.
youngpeck is offline   Reply With Quote
Old 10-23-2016, 11:07 PM   #8
1972 25' Tradewind
On my tradewind it was on the left rear side just above where the fresh water connection was. Hopefully yours will be in the same general area, unless a previous owner removed it for some reason.
North Vancouver, BC
Old 10-24-2016, 09:23 AM   #9
1972 23' Safari
Nothing...
Nothing on my safari. Wonder if the 72 Safaris had them?
Old 10-24-2016, 10:32 AM   #10
1972 23' Safari
Camas , Washington
Our 72 Safari had a polarity light, I could not find a picture but I believe it was located just below the 120V breaker box looks like a junction box. When I get home I will check all my pictures and post if I have one. look in the rear wardrobe closet street side. Or under street side bunk if you have a twin, I can't remember if it was behind or in front of the water heater.
Old 10-24-2016, 11:37 AM   #11
1972 23' Safari
Ok great. So you're saying that the polarity light is inside the airstream not on the outer side so to check it, I would check from the inside.
Old 10-24-2016, 12:04 PM   #12
belen , New Mexico
BEST INVENTION EVER!
Sadly not used any more
alantbird is offline   Reply With Quote
Old 10-24-2016, 12:25 PM   #13
youngpeck's Avatar
1976 25' Caravanner
These two pictures show the polarity light electrical box from the inside of the trailer. My trailer ('76 25' Caravanner) has it just above the water heater, as you can see. On the outside it's just a little red glass fitting. I took mine out during the rebuild.
ID:	274113   Click image for larger version
Old 10-24-2016, 02:08 PM   #14
1972 23' Safari
Camas , Washington
I found a picture it was just in front of the water heater, you can see it in the picture, the water heater is gone in this picture, there was and orange light center of the cover, mine did not work I removed it when we remodeled, I now use a polarity checker that plugs into outlets.
Old 10-24-2016, 02:18 PM   #15
1972 23' Safari
Camas , Washington
I found one more photo showing how the two 120 V circuits were wired in the polarity light
ID:	274126   Click image for larger version
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 10:05 AM
Opinions on these recessed LED lights stevealbrech Lights - Interior & Exterior 7 03-18-2014 06:10 AM
Where I can order these lights? texasbound Lights - Interior & Exterior 14 10-15-2012 10:07 PM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
