Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1969 - 1973 Safari
Old 10-19-2009, 12:39 PM   #1
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Shower?
We have a '71 Safari and the bathroom shower confuses me a little...
Sorry for the stupid question but what I'm wondering is should we use a shower curtain in the bathroom or should I expect water to get all over the place? The '71 Safari is one of the models with the rear 3/4 bathroom and shower pan in the center of the rear bathroom. I'm not sure that the walls are water proof or if they aren't should I cover them with some kind of sealant?
Thanks for your help.
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 10-19-2009, 01:37 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Some pics. that may give you a few ideas. (courtesy Vintage Airstream) One with a curtain and one with what looks like the original door.
1971 Safari 2
1971Safari6
Old 10-19-2009, 01:48 PM   #3
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Ganglin,
Thanks for the links to the photos. My bathroom is arranged like the in the photos. I like the shower curtain in the bathroom side of the folding door going into the bedroom. That's a good idea.
What about the other surfaces in the bathroom? I'm sure the walls should be waterproof otherwise water will leak into the bedroom and the closets next to the bathroom. Is the tambour in the bathroom cabinet supposed to be waterproof? Any idea if the wallpaper was coated with some type of waterproof coating when it was new at the factory?
Thanks again for your assist.
- David
Old 10-19-2009, 02:20 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Our Caravel has about the same layout. We use a curtain to keep the water in the shower pan. Covers the front of the toilet and comes around the open side to the counter top. It sits inside the lip of the shower pan. Saves lots of "mop-up" after showering.
Old 10-19-2009, 06:35 PM   #5
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks Jim. That certainly makes sense.
- David
Old 08-12-2010, 09:17 PM   #6
2020 27' Globetrotter
1999 25' Safari
Somewhere , Ohio
This is a little late, but we are going through the same thing -- just bought our first Airstream, a 1971 Safari with a "wet bath". Boy, did they name it correctly!
I am wondering if we can redo the bath; take out the existing and put in a shower pan, some sort of wall system, and very tiny oval sink in tiny cabinet. Have you explored something like this, or know of someone who has done it?
Thanks.
D. Hall
Air Cruiser is offline   Reply With Quote
Old 08-13-2010, 06:18 AM   #7
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks.
D. Hall
I'm going to install a shower track something like Mellow Mike's in this thread next weekend: http://www.airforums.com/forums/f446...2-a-17356.html
At some point in the future we plan to gut our AS and build it with a floor plan more suitable to our needs, but until then we're fine tuning the existing layout and replace and upgrade components as needed. I'm going to paint the bathroom sink and shower pan surfaces with a 2-part epoxy paint then a gel top coat. That should help the look of the bathroom.
Good luck!
- David
Old 08-13-2010, 08:13 AM   #8
1999 25' Safari
Somewhere , Ohio
Hi David.
I had thought about trying to rig up a shower curtain surround as a temporary fix too. I just can't rap my brain around showering and all the soapy water going all over the sink, walls, toilet, etc. Wow, that has to lead to a lot of time afterwards for scrubbing and cleanup!
We had been telling ourselves that we were going to buy an AS that had the floor plan we liked, welllllll.............we love the floor plan of this one, except the bathroom, and of course it has the one we liked least -- a wet bath. Oh well, I guess we need to take the bad with the good, right!?
I think we are going to do some major upgrades to ours this winter, if the weather cooperates.
First we have to buy new tires and check out our existing rims to see how good they are, and replace the wheel bearings. Then we are on to adding an air conditioner (our son has seizures, so we need to keep it cool for him). I've been reading a lot about tire and AC units, but after reading so much, it's a little confusing.
Good luck with your Safari and any modifications you decide to make. I'd appreciate getting a heads up if you come across anything you'd like to share.
D. Hall
Old 08-13-2010, 09:16 AM   #9
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
camping showers
When you use the shower you will be trying to conserve your water...usually. Otherwise you run out of water, or fill up your gray tank. That means that most of us figure out how to shower with way less water. "Military" style is the usual for us. Wet down, shut off water, soap and scrub, start the water and rinse. So it doesn't get too messy. And in our shower we have a hand held shower on the long hose. Very handy and water saving and maybe less splashing around.
In our Minuet we sit on a 5 gal. bucket to shower since the shower is short and in the back corner curve. We are both tall and wide. Makes for a tight fit otherwise. We had to remake a new shower curtain which snaps to the sides and keeps the water from splashing out too.
In the Excella we are lucky to have a hard plastic shower door to keep the bathroom dry. The walls are vinyl wallpaper. We wipe those down after showering, and use the bathroom fan to get rid of extra moisture.
Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 08-13-2010, 01:08 PM   #10
1999 25' Safari
Somewhere , Ohio
Loudruff,
That all makes perfect sense. After we patch the hole in the floor, I may give it a try.
Thanks.
D. Hall
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 27 10-02-2022 06:12 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
No shower Dan S All Argosy Trailers 6 06-24-2007 08:38 PM
Is a shower possible? 58BUBBLE Sinks, Showers & Toilets 11 03-31-2005 06:39 PM
What about that Shower? Razinni 2002 - 2005 International 4 05-18-2003 11:35 PM
