Old 06-15-2012, 06:27 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Safari #2 -- 1973
Safari #1 is going slowly, so I thought I could find one in good shape and be on the road with it in a couple of weeks. Oops! It looked pretty good until I got under it.
So here we start the saga of Safari #2. I've been pestering this owner for 3 years and he finally realized he had let it sit too long. It is now my problem. All I can say is, it looked pretty good sitting in the storage area--here I am checking the fresh tank.
Name:	P1010307 nice shell-s.jpg
And here it is on our new lot, along with the grader that is preparing courtesy parking.
Name:	DSCN0021 two new projects-s.jpg
The fresh tank appeared to leak badly, so getting it out was the first priority. The rust is thick and flakey, but the steel, although badly pitted, seems to be strong. I may have to sister it with additional angles once I get the grinder on it. Getting the tank out was a nightmare. I couldn't budge the supporting plywood, so I tore the covering aluminum away so I could rout a cup into the plywood and use a sledge hammer. That didn't work either,so I finally used a skill saw to cut nearly through the curb and street side edges, then pulled the front edge down enough to get the tank out. The plyood was completely rotten along the front edge and most of the curb and street sides.
Name:	P1010304 rust-s.jpg
Name:	P1010310 fresh tank-s.jpg
The water system was OK, except for leaking faucets and a major toilet leak. My main complaint is the haphazard way the factory installed the copper tubing--no thought at all to dressing the lines or conserving space. Ugly, ugly, ugly. This will all be PEX next week. I think a lot of the heater ducting is coming out, too--how much ducting do you need in a Safari? So what if the bathroom is a little cool?
Name:	DSCN0034 rats nest-s.jpg
I need some help on the Thetford dump valve. This valve is installed to dump straight down. It appears that the outlet side is glued to the outlet fitting (the sinks and show come into that fitting from two sides). I hope the top of the Thetford is a slip fit with the black tank--the dump valve is leaking slightly, so I need to get it apart to put in new seals. Does anyone know which model Thetford this is--there are five or so?
Name:	DSCN0026 thetford-s.jpg
Thanks for looking. There is one additional problem--the entire back edge of the flooring is gone, not rotten, gone, about 4" wide, completely across the back. This is going to be the biggest challenge.
Zep
Old 06-15-2012, 07:07 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
So the fresh water tank is ok? Any signs of water coming from above to cause the water tank plywood to rot away?
Maybe the black tank valve fitting is threaded, and you can replace the valve completely. I know that would require cutting the other two drain lines, but it might be worth it. A couple of couplings would repair the cut lines.
Nice road grader by the way. Do you give rides or even better; let your guests drive it?
Chris
Old 06-15-2012, 07:57 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yep, thats it. got the same exact trailer. same "absent" rear section of floor, too.
(I patched the worst of it, and kept on camping for another 8 years or so, before finally deciding to bite the bullet, and "fix" it. pics here: Floor Project 2011 - Photo Gallery).
I actually did rebuild the dump valve about a year and a half ago; then used the camper twice, before deciding to rip it all out. It was surprisingly easy to do. I really thought it was going to be one of those "should be simple" projects that somehow morphs into a nightmare, but it wasn't. went very smoothly. came apart easy, went back together easy...no more leak.
That fitting is screwed to the valve; the valve is screwed to the flange that is glued to the bottom of the tank. as long as the screws aren't frozen up, it'll come apart easy.
I'll get the model for you tomorrow.
looks like someone went to a lot of trouble to replace the furnace in yours. interesting how they plumbed that in.
all those other original pipes are run exactly the same in mine.
I'm going to remove my (original) furnace, and go without; I find that I hardly ever need it, and when I have used it, its loud. The worst part is that the trailer doesn't hold the heat very well, so it cycles on and off so often, it disturbs sleep. I can keep the trailer plenty warm with a $20 ceramic/electric heater and/or the cat heater. The space consumed by the big old furnace could be put to much better use.
I'm also going to retrofit tanks below the floor. that black tank is only 13 gallons. The plan is to hang a large tank in the space below; I'll put the bathroom back as original, but instead of a tank under the cover, a wooden box to support the throne, and a 6" riser to go through the floor to the tank.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-16-2012, 02:12 AM   #4
1975 31' Sovereign
1977 23' Safari
MINNO, no sign of water from above. The steel angles that hold up the plywood are uniformly rusted all around. I think there was a long-time leak in the feed line, right at the tank, that kept the underside of the tank constantly wet. But I can't explain how the pump could draw water--seems there would have been an air leak and the pump wouldn't prime.
I did a short test of the tank. Longer test today, but it seems OK
No rides on grader. It cost a bundle to hire it!
Originally Posted by Chuck View Post
...I actually did rebuild the dump valve about a year and a half ago; then used the camper twice, before deciding to rip it all out... That fitting is screwed to the valve; the valve is screwed to the flange that is glued to the bottom of the tank.
I've done several valves, including the complicated pair for the Sovereign mid-bath. But this one isn't obvious to me. I looked at the bottom of the black tank pretty closely and it doesn't look like there is a fitting on it--I may cut the two gray lines and see how it all comes apart. I am considering adding a small above-floor gray tank so I can use the sinks during quick stops.
...looks like someone went to a lot of trouble to replace the furnace in yours. interesting how they plumbed that in.
Yes, and the P.O. says the dealer charged him an arm and a leg. Anyone want a heater?
You are singing my song! I use an Olympic catalytic when I'm boondocking and a small ceramic otherwise. Two ceramics can keep even a large Sovereign habitable (not comfy, necessarily) down to 5 degrees.
Zep
Old 06-16-2012, 01:45 PM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
The fitting is there on the tank, visible in your picture; it just looks like its part of the valve; its glued onto the bottom of the tank.
These pics should explain it:
Name:	IMG_6248 (Large).JPG
ID:	161158   Click image for larger version
Name:	IMG_6249 (Large).JPG
Name:	IMG_6250 (Large).JPG
ID:	161160   Click image for larger version
Name:	IMG_6251 (Large).JPG
Air:291
Wbcci: 3752
'73 Safari 23'
Old 06-16-2012, 01:52 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Roger, last photo I saw of your place featured a couple of feet of snow and a bunch of buildings with a few trailers. Have you moved? Looks like you could have many, many more trailers in that field to work on. How many trailers will you have at the "balloons"?
Gene
Old 06-16-2012, 02:03 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
This would be the replacement part: 08706 of Thetford Valve 01447
you can see on the valve page that they also have that part that glues to the tank, too. as well as a re-build kit.
Mine was a re-build, but I was lucky to get the kit that was in a dusty old bag at my old-timey local rv supply place. the notes on the VTS rebuild kit say that you need a different one if your valve has the stainless steel top, as mine does.
If you only want a small grey tank, you could use VTS's 16 gallon model; it'll fit nicely in the frame bay behind the axle. The galley drain line runs under the street-side bunk, and drops down through the floor just in front of the shower wall; e-z to move that forward a few inches so it drops right into that bay, and into the top of the tank. Nothing is in the way. the heater duct might be a little, but there's plenty of room.
I was thinking of maybe going with 2 of these; didn't think there would be room for a second one in the middle bay, due to the shower drain, but someone here the other day said it would fit in their 73 gt (same bath) so I measured...only a couple of inches to spare, but it would fit.
Anyway, with either one or 2, you could easily tie it into the existing drain lines going to that collector. (which is "unobtanium").
I'm going with a different black tank, as mine is broken at the toilet flange; 13 gallons doesn't quite cut it for capacity, and also, that is an extremely awkward dump location. pretty much impossible to access it without crawling on your hands and knees at the dump station.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 06-16-2012, 04:21 PM   #8
1975 31' Sovereign
1977 23' Safari
Haven't moved yet. It's a large vacant lot about a mile from the house. We'll be in our current house at least another year, but I am prepping the new lot for parking.
I keep threatening to bring two Airstreams to Balloons, but it never seems to work out. One is enough, but at Burning Man I did have two back in 2010.
Zep
Old 06-16-2012, 04:25 PM   #9
1975 31' Sovereign
1977 23' Safari
Chuck, thanks for the pics! This totally explains the assembly. You are da man!
I think I have the all-pastic Thetford repair kit in the shop, now I just need to decide on how much surgery I want to do, eg, gray tank. I want to get this Safari roadable in three weeks, so an "under" gray tank is probably out of the question for now.
I am going to take out the heater and the heater duct, so moving the plumbing around a bit on that side won't be a problem.
Zep
Old 06-16-2012, 04:33 PM   #10
1975 31' Sovereign
1977 23' Safari
The P.O. delivered the rest of the accessories today--a blue boy, battery, equalizer hitch, and (whoot) the Service Manual. I'll probably redo all the systems, but it's a nice reference for the shell and frame.
Name:	DSCN0039 service manual-s.jpg
Name:	DSCN0041 panel page-s.jpg
Zep
Old 06-16-2012, 04:40 PM   #11
1975 31' Sovereign
1977 23' Safari
Anyone know what this black stuff is and how to get rid of it? It's only on the top and sides (inside the tank).
Name:	DSCN0042 tank gunk-s.jpg
I'm going to modify the tank with two 3/4" drains in the bottom. I can get the Metal Company in Denver to spin in the flush fittings. Hopefully this will allow me to spray high pressure water into the tank and get the crud out. Besides, it takes the tank more than an hour to drain through the original feed fitting.
BTW, when I was checking the tank for leaks I noticed that the vents are about 1" down from the top in the 5" tank. That means that if you fill the tank with the trailer level, you only get about 80% capacity. Depending on which side your kitchen is on (generally the tank fittings are on that side), you need to have that side of the trailer high, maybe 5 degrees, in order to fill the fresh tank to something like 95% capacity.
Zep
Old 06-16-2012, 04:54 PM   #12
Minno's Avatar
1972 31' Sovereign
Looks like our fresh water did. Green crud is probably algae, black crud is either mold or dead algae. Our was full of black and green crud, which we never did get cleaned out all the way, hence our new tank. We did try the denture cleaner trick someone suggested, and it worked fairly well, but you need a lot of it. A whole lot. More than you think... We used a full large economy sized box (180 tabs) as an experiment, and it did really help, but we didn't have a way to scrub or high pressure rinse the tank out. The new fittings you’re talking about should help with that. Kay says you need a new tank.
Chris
Old 06-16-2012, 04:55 PM   #13
Minno's Avatar
1972 31' Sovereign
Originally Posted by zeppelinium View Post
no rides on grader. It cost a bundle to hire it!
dang!!!!
Old 06-16-2012, 04:58 PM   #14
Master of Universe
Gene's Avatar
Black stuff could be mold. If it's not eating the plastic, why worry about it as it appears to be the grey tank? Clorox may help with killing it.
Read your post over again and it is the fresh water tank. Get a new one if chemicals can't remove it; maybe an opportunity for a bigger one. Of course, you could use it for non-potable water and drink bottled water, beer, gin, and of course, red wine.
Gene
