Old 01-10-2013, 07:13 PM   #41
1972 23' Safari
Camas , Washington
New Axles
Axles arived yesterday, now just waiting for some warmer days to finsh taking the floor out and start working on the frame. We will change the axles after the frame work is completed.
Been doing a ton of reading here older threads and trying to use as many good ideas and techniques together to make this job go as smooth as possible. With the amount of knowledge here, research makes this job a bit less stressfull.
thanks again to all.
David and Pam
Pams72 is offline   Reply With Quote
Old 02-06-2013, 05:27 PM   #42
1972 23' Safari
Camas , Washington
old axles removed
Finally had a few warmer dryer days and we were able to get the old axles and rear belly pan removed. Now I can get on with removing the subfloor and repairing the rusted out portions of the frame. We will probably install the new axles first, because the only place we found to keep them out of the way was in the bedroom .
here are some more pics of the axles and bottom of the frame.
thanks, David and Pam
ID:	178414   Click image for larger version
Old 02-17-2013, 03:30 PM   #43
1972 23' Safari
Camas , Washington
A little more progress on the deconstruction, part of the old sub floor removed. Plan now is to finish removing sub floor, repair and POR frame, install new axles. Then we will start a new thread on reconstruction begining with the new floor.
thanks,
David and Pam
Old 02-17-2013, 07:34 PM   #44
cameront120's Avatar
1972 25' Tradewind
May I suggest that you continue with this thread, rather than start a new one? That way it serves as an archive of your entire renovation that allows future renovators to see your process from beginning to end. If you break up the process with other threads, people may not be able to piece all of your threads together. Cheers.
North Vancouver, BC
Old 02-17-2013, 08:47 PM   #45
BoCox's Avatar
1969 23' Safari
Raleigh , North Carolina
I agree with Cameron and the dogs, keep it as one post and you will enjoy the story from the preface to the the end of the story. Like many will say, it's like an ant eating an elephant, one bite at a time. Everything can be accomplished given the right mindset, thoughts and tools. I have a 69 safari and accomplished many things I never thought possible. All good things!
BoCox is offline   Reply With Quote
Old 03-13-2013, 02:33 PM   #46
1972 23' Safari
Camas , Washington
OK I have no problem keeping the post going as one We have had a bit of down time and have just got back to Pams project Stay tuned I am in the process of doing the new axles.
David
Old 03-13-2013, 02:56 PM   #47
1972 23' Safari
Camas , Washington
I forgot to say we have decided to do the axles now, because as of now they are in the bedroom.
I am preping the axle mount area (POR) and will attach new axles then continue with the rest of the floor removal and frame repair.
Going to put the brakes and hubs on before I lift the axles in place.
Has anyone lifted the axles with out the brakes and hubs and attached them after mounting the axles?
Just thought it easier to do it before mounting.
thanks,
David and Pam
Old 03-13-2013, 07:21 PM   #48
1972 23' Safari
Camas , Washington
old tires and screws
just a few pictures of the car tires that where on the trailer from the PO. He said the tires were new . The screws are only about half of what I have removed they rusted a bit from sitting in a cup that filled with rain water. axles in the bedroom with aluminum from interior.
ID:	180972   Click image for larger version
ID:	180974   Click image for larger version
Old 03-13-2013, 10:04 PM   #49
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
David and Pam,
The axles will be much lighter without the brakes and drums attached. Easy to attach after the axles are in place.
Bill
thanks,
David and Pam
Just my personal opinion
Old 03-13-2013, 11:51 PM   #50
strshpntrprz's Avatar
1973 23' Safari
Reese , Michigan
What an undertaking, but you will love the results and the pleasure your hard work will return to you. We have 13 or 14 outings planned for the year including a 240 mile trip to alumapalooza at the AS factory in Ohio.
Gene and Sharol in starship enterprize (earthbound) don't grow up, it is a TRAP ---repairing, not restoring since 1999
strshpntrprz is offline   Reply With Quote
Old 03-15-2013, 06:36 PM   #51
1972 23' Safari
Camas , Washington
new Axles mounted
Thanks to Inland, the new axles mounted no problem . I had cleaned up the axle mounting plates and painted on POR 15 so we could mount the new axles and get them out of the bedroom . This weekend I will add the brakes and the hubs and then the new wheels and tires.
Then we will get back to removing the rest of the old floor and do the rearend frame repair .
thanks again,
David and Pam
ID:	181081   Click image for larger version
Old 03-16-2013, 03:16 PM   #52
1972 23' Safari
Camas , Washington
Brakes, hubs and new wheels and tires
Pam and I got the brakes on the new axles followed by the hubs and then the new wheels and tires today. Suprised me only took about three hours. here are a few more pictures.
ID:	181130   Click image for larger version
ID:	181132   Click image for larger version
Old 03-18-2013, 07:43 PM   #53
1972 23' Safari
Camas , Washington
more floor removed
all we have left of the old sub floor is the front and rear pieces, quite a bit of rust in and around the mid section, I think caused by water tank leaking, door area and window leaking?
Does any one have a good way to remove the front piece without cutting it? I need to pull the floor out from under the chanel. Here are a few more pictures.
David and Pam
ID:	181353   Click image for larger version
Old 03-24-2013, 07:08 PM   #54
1972 23' Safari
Camas , Washington
We had to cut the front piece out in three pieces to get it out and the rear piece in half. Today I was out early grinding away at the rust on the frame. What a dirty job! . I can now POR-15 the frame back to just behind the axles, the rest of the frame needs some attention .
Old 03-24-2013, 08:04 PM   #55
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
thanks again,
David and Pam
Are those flower slippers steel toe?!?!?!
Protohyp is offline   Reply With Quote
Old 03-26-2013, 05:15 PM   #56
1972 23' Safari
Camas , Washington
nope not steel toed. At that time I was torqueing the axle nuts, Pam was on the other side holding the bolt with a wrench.
Old 03-26-2013, 05:26 PM   #57
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Looks great David and Pam. Looks like the frame is pretty good shape and a POR-15 coating will give you a nice solid foundation. Nice work!
surfpod is offline   Reply With Quote
Old 03-30-2013, 10:09 AM   #58
1972 23' Safari
Camas , Washington
Frame POR 15
This past week has been nice and warm in the 60's so we have been painting the good parts of the frame. First we used the marine clean then did the metal prep and then the POR 15. The frame looks good with a fresh coat of POR 15. Here are a few pictures, you can see in one of the pictures where we have to repair the rear end frame starting just in behind where the axle mounting plate attach to the frame and replace the back two cross members. I need to find me a welder to do the job. I will then concentrate on the rear hold down plate area and figure a better way to keep the H2O out.
David and Pam
ID:	182110   Click image for larger version
ID:	182112   Click image for larger version
Old 04-13-2013, 08:49 AM   #59
1972 23' Safari
Camas , Washington
We had a welder / fabricator come and give us a bid on the rear frame fix yesterday.
He will fabricate the two main frame pieces about 3' on both sides and add the two cross members and outrigger I ordered along with a new hitch coupler. Fair price for the job. Will be nice to get started replacing the subfloor.
thanks,
David and Pam
Old 04-13-2013, 10:06 AM   #60
1973 25' Tradewind
Beautiful , Oregon
Nice work.
I was curious do you know what the red wire running down the street side of the trailer in the frame is for?
Keep up the good work.
Tony
Tony S is offline   Reply With Quote
Square footage of floor in 1972 23 ft Safari Land Yacht Maggiefoss Repairing/Replacing Floor &/or Frame 7 01-13-2015 11:09 AM
Warranty work on new 2012 25fb Flying Cloud danlehosky General Repair Forum 8 02-04-2012 08:55 PM
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
2006 Airstream Safari 22' 75th Anniv Special 500 miles! eBay Watch Airstreams on eBay 1 01-04-2011 07:08 AM
