Old 04-17-2019, 11:55 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
No running lights, brake lights or trailer lights work from tow vehicle
So trying to find out why no lights from the tow vehicle umbilical work on my 72 Safari thatís going through restoration. First should say that the tow vehicle connector works perfectly with my 06 FB LE Safari so the issues lie within the 72 23í Safari.
When we bought her in last Sept some of the lights worked, one turn signal and a brake light. Now Iím getting nothing. Today I connected my ďrallyĒ plug into the trailer that turns on all running lights and nothing happened no exterior lights. The trailer was plugged into 120 v ac, new battery charged, all 12 volt working.
Also I just took out the old Univolt and put in a new Boondocker DC unit and a new ac/dc fuse panel so basically all electrical replaced but all internals in the trailer are good.
Next thing will be to unplug the trailer from shore power and start up tow vehicle connect to trailer and start metering for incoming voltage. Any other clues from you rivit masters?
RichHog is offline   Reply With Quote
Old 04-18-2019, 05:28 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I just went through this with a boat trailer. When ALL lights don't work, it might be the trailer ground.
2012 Dodge Durango Hemi/AWD
Old 04-18-2019, 06:52 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
IMHO you have 2 problems.
1. Old trailer wiring and fixtures. Probably more to do with bad connections and burnt out bulbs.
2. The trailer 7 way plug is not wired for todays TV's. You must rewire the 7 way trailer plug to match the modern lighting configuration.
The exterior lights have nothing to do with the 12 volt DC system inside the coach.
I would use a battery charger for a power source to troubleshoot the problems.
Old 04-18-2019, 08:42 PM   #4
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Electric brakes worked today towing home.
Old 04-18-2019, 08:53 PM   #5
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Check the GROUND!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 04-18-2019, 08:59 PM   #6
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Ground coming from the tow vehicle ? Thereís a white wire ground connected to 12 v conveyer and a bare wire frying to frame from AC power in.
Old 04-18-2019, 10:08 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The negative side of the converter should be connected to the negative of any batteries, the negative buss bar in the power panel, the ground wire from the umbilical, and probably the trailer frame as well. Some trailers use the shell/frame as the return to ground for the lights.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-18-2019, 10:15 PM   #8
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
So the white ground wire that runs from the umbilical to the back of trailer is connected to the ground on the boondocker dc power. Thinking it needs to move to the ground bus bar on the progressive dynamics dc fuse panel. Thoughts?
Old 04-19-2019, 12:56 AM   #9
As I said above, all of the grounds should be connected together somehow - umbilical, battery negative, converter, negative buss bar. If the white wire is the only wire connected to the converter negative, that will allow the converter to charge the TV battery but not provide power to the TT unless that junction is tied to the negative buss bar somehow.
Al
S/OS #004
Old 04-19-2019, 06:45 AM   #10
1994 34' Excella
Warren , Manitoba
Do you have the trailer connected to the TV? Ground between the trailer and TV is through the hitch as well. The 12 volt trailer system does not have anything to do with the running lights, nor does the 120 volt or the power converter. Grounding, or lack of, is likely your problem. The power for the running lights originates in the TV, so must be grounded back throught the TV,
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-19-2019, 06:57 AM   #11
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
So inside the trailer the white wire is the common ground and others have said behind the wall it ties into other wires that are grounding points. The service manual (very handy)shows the white going off the old Univolt negative ground to the umbilical cord to tow vehicle. It also shows a breaker under the gaucho near the junction box so Iíll check this out. Iím thinking that the white should come off the convertor ground and move to the negative bus bar in the fuse panel.
Old 04-19-2019, 07:03 AM   #12
Gainesville , Florida
As has been reported before, is your umbilical cord updated to new type?
xrvr is online now   Reply With Quote
Old 04-19-2019, 08:07 AM   #13
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
To my knowledge no, donít know if it was original or was updated. The pins seem to match when plugged in. Will take a deeper look at it today. When we first connected it to bring trailer to Texas we got some of the back lights, brake and one turn light to work. Figured the rest was bad bulbs rust etc.
Old 04-20-2019, 05:13 PM   #14
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
So got most of the top running lights working, lots of bulbs out. One back taillight works, no brake lights or turn signal lights. Will replace the 7 wire umbilical connecter as suggested and take it from there.
Running lights working but no brake lights etc. jhuggins76 Lights - Interior & Exterior 16 05-14-2017 09:37 PM
Urgent Help....No Brake Lights when running lights are on Debnw Lights - Interior & Exterior 10 05-08-2015 03:04 PM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
