Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1969 - 1973 Safari
Old 06-18-2018, 12:51 AM   #101
PaintedWagon's Avatar
1972 23' Safari
Arlington , Massachusetts
Great to see another 72 Safari on the road from New England. Glad that that you are traveling with it, so many get stuck in the back yard and never get on the road again. She is a great little trailer. So many State and National parks where the size is just right and towing is so easy. We restored ours in 2013-14 and headed to Burning Man in NV. She's been all over the West Coast and Canada since and we just love her. Like all ladies of a certain age, she needs some TLC and constant attention but well worth the time and effort.
PaintedWagon is offline   Reply With Quote
Old 06-12-2020, 05:59 PM   #102
1972 23' Safari
Middletown , Rhode Island
Finally after 3 years...
Finally after about 3 years I got my used bumper I bought a couple years back straightened and installed just today. It was a pain in the butt to find someone to straighten my aluminum bumper, no one wanted to touch it, they were too scared and thought it would crack, well I found a little shop nextb town over that fixed it for $75. Better late than never. I also resprayed my rear frame rails and underneath with a rustoleum rust paint.
I've enjoyed using the airstream the past 3 years and finally getting around to much needed updates to bring her into this century.
This weekend projects:
1. Weboost Cellular booster antenna and repeater install
2. Solar Panels on roof & combiner box install
3. Finish my Maxxair Fan install
4. install new roof vent pipe cover
5. Paint the roof white
ID:	370133   Click image for larger version
Mx468 is offline   Reply With Quote
Old 06-13-2020, 07:13 PM   #103
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Thanks for posting the update. Where does guy find a used bumper as we need one for our Sovereign project? Ours is bent and cracked.
Good to hear the Safari is out and about after all your hard work, and that you are enjoying it. It does look nice.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 06-18-2020, 07:31 AM   #104
1972 23' Safari
Bumper....
Hi David, I found mine on my local craigslist but here's a pretty good deal below. I would just double check the distance from your rear frame rails in back to make sure the holes will line up on the new bumper you acquire. I bought my front rockguard from these guys, they're located in New Orleans, I do believe. You can also call them, they seem like pretty cool guys. What year is your trailer?
https://zeereez.com/products/f18082a...a3e39574&_ss=r
here's another bumper option if the one above is not wide enough, but this one doesn't include free shipping
http://odmrv.com/catalog/index.php?m...oducts_id=1642
Old 06-18-2020, 07:29 PM   #105
1972 23' Safari
Roof top vent with solar control wires...
Just installed my new aluminum mushroom vent which I switched out for my regular style vent that came with my airstream. I drilled 2 holes on the side facing down and pulled my mppt solar controller wires through them which will eventually go into my rooftop solar combiner box. I wanted to use this style of vent so there wouldn't be any water intrusion down the vent when it rained. I also put screening material up inside to keep out the bugs.
ID:	370685   Click image for larger version
Old 06-21-2020, 06:55 PM   #106
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the references to a used bumper. We will look into it.
Now you have mushrooms growing on top of your trailer. Maybe its been in the dark too much. The vent does look very solid.
David
Old 06-23-2020, 01:02 PM   #107
1972 23' Safari
David
Ha ha, I do but only 1 mushroom. The other vents I left them be except I got new gaskets, resealed them and put on new bug screens.
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
New sewer hose for 1972 airstream safari Maggiefoss Waste Systems, Tanks & Totes 4 03-15-2011 12:56 PM
safari side name plate 1972 dick gates Ribs, Skins & Rivets 3 02-24-2008 06:12 PM
1972 safari.. Battery question Theo Electrical - Systems, Generators, Batteries & Solar 4 01-23-2004 04:29 PM
