Old 12-22-2007, 04:48 PM   #1
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Is this '69 supposed to have such a fat bottom?
getting deep in the bath floor replacement but before I pull off the bellypan can anyone tell me if my '69 Safari is SUPPOSED to have such a large booty that hangs two inches below the frame? I'm guessing this might be what enables the black tank to go BELOW the floor instead of 'raised toilet' style?
thanks
fotochop is offline   Reply With Quote
Old 12-22-2007, 04:56 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This is what my 75 looks like, about the same except my tank drain is located there also.
Richard
Old 12-22-2007, 05:00 PM   #3
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Yes!
Those extensions to the frame are to enclose the black tank. I don't know what is intact on your trailer, but there should be a bent belly pan section that sits between those extension angles. Above that is a galvanized steel box in which some foam insulation surrounds the black tank. The galvanized box is held in place by some small angle that bolt between the frame extension angles.
Hope this is the info you were looking for.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 12-22-2007, 05:44 PM   #4
thanks
Those bottoms steel are very important.
There are called "skid plates."
When you go in and out of gas stations as an example, you more than likely will drag the rear end of the trailer.
Those skid plates prevent tearing up the rear of the trailer.
When they wear enough, just replace them, but never discard them.
A few owners have installed "dolly wheels" at the rear.
One word answer.
DON'T.
If you do, the first time you drag the rear end on each side, you will damage the rear quarter panel on that side.
Let the skid plates do their job.
Old 12-22-2007, 07:38 PM   #5
Jim Clark's Avatar
2012 28' International
thanks
Rick, I am in Algiers and did a 68 a few years ago, if you need moral support PM me.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Vendors must be fat. boatdoc Off Topic Forum 12 01-24-2007 05:20 AM
What is this supposed to look like??? Hamb7 Cabinets, Counter Tops & Furnishings 5 12-29-2006 08:04 PM
Is it supposed to take 10 hours? Safari Tim Repairing/Replacing Floor &/or Frame 9 09-03-2006 04:51 PM
How are these supposed to be sealed? guy99 Classic Motorhomes 5 07-02-2006 08:09 PM
Is this door supposed to fall off? tmcdougald Exterior Storage Compartments & Access Doors 9 07-21-2005 05:30 PM
