Old 06-16-2013, 12:02 AM   #1
1971 23' Safari
Arlington Hts , Illinois
Is there an adapter from the Airstream 7 pin on my '71 Safari to a 7 blade?
The pigtail on the 1971 Airstream Safari we are buying has a 7 pin pigtail, and the 2005 Honda Pilot with which we plan to tow it has a 7 blade receptacle. Our dealer has offered to replace the pigtail, but I understand from messages here that it may be better to instead add an adapter and keep the 7 pin pigtail.
My question is, what such adapter works? The ones I see in catalogs for 7 pins don't look like they would take the scalloped edges between pins of the pigtail now installed.
See attached photo of the current Airstream connector:
Name:	Trailer lighting connector-email.jpg
Thanks much!
MrJim is offline   Reply With Quote
Old 06-16-2013, 06:03 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Get rid of that round pin connector. They are impossible to meet clean and operational. Nothing modern connects to it. A newer blade type is very inexpensive....easy to install.
Old 06-16-2013, 06:14 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I bought the entire pigtail assembly, this will also update the pin configuration so everything will work correctly.
Old 06-16-2013, 08:11 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Not sure how your AS is laid out... on my 1975 you need a double ended pigtail, round pins on the AS end and blade plug on the TV end.
Aaron
WBCCI #XXXX AIR #2495
Old 06-16-2013, 08:24 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings MrJim!
Attachment 188369
Thanks much!
I don't believe that I have seen the style of round-pin connector that is in your photo. The only 7-pin round to 7-blade adapters with which I am familiar utilize a round plug with a square/rectangular reference "bump" to mark the top of the plug. The photo below illustrates the adapter that I utilize as an "emergency" adapter to use in the event that my trailer must be towed by someone who doesn't have a round-pin connector on their tow vehicle.
The adapter is available from E-Trailer as well as several other sources.
I made the switch from the blade-type connector to pin-type connectors over five years ago. Several long-time Airstreamers suggested that I consider making the change when they learned of my frustration with annual replacements of the blade-type connector on my tow vehicle and every-other-year replacements of the blade-type connectors on my trailers (due to corrosion). Since upgrading to the heavy-duty self-cleaning seven-pin connectors, I haven't had to make any replacements of either trailer or tow vehicle connectors. The one thing to keep in mind is that the Airstream 7-pin round connector is not wired to the industry standard for that device so it is necessary to rewire the trailer to match the pin-out for today's industry standard for the round-pin connector.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 06-16-2013, 08:47 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Change to the blade type connector and have it wired to match your vehicle so that it matches the industry standard. That way your trailer is compatible with any vehicle that may need to hook to it.
I have not had any problems with the 7 blade connector that a shot of contact cleaner wouldn't fix plus they are universally available anywhere if you need to replace one.
There is nothing wrong with the old connector that airstream uses except they are non standard since 1984 or so.
The 71 trailers did NOT use the current color code on the wiring so you will have match the function rather than the color marked on the new plug
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-16-2013, 08:15 PM   #7
1971 23' Safari
Thanks for all the replies. Very helpful!
