Old 12-02-2014, 09:01 AM   #1
projector's Avatar
1972 23' Safari
NSB , Florida
Exterior storage
From what I understand our '72 Safari at 3500 pounds dry has a tongue weight of 500-600 pounds, well over the 7-10 percent rule. The axles are pretty far back almost like a boat trailer. To carry a spare tire and bike without adding to this I had receiver hitch and tire stand fabricated for the rear bumper. I've read all the risks in doing this and talked to all my engineering friends and have no worries. The 1 1/4" receiver crosses a 2" cross member between the frame rails and Tee's into a shorter cross member bolted to the trailer frame. The tire carrier bolts to the end of the trailer frame.
We arranged it where the tire sits just below the tail lights and is just higher than the bottom the bumper.
The bike rack just clears the spare tire.
on a side note, we added racks to carry kayaks on top. Far enough forward to clear the camper in tight turns.
Thanks.
projector is offline   Reply With Quote
Old 12-02-2014, 09:05 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I made a similar hitch and bike rack for my Safari, before I read on this forum about rear end separation.
So... I have a custom made bolt on hitch for sale, CHEAP!!!
It's never been used! ;-)
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 12-02-2014, 09:51 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I don't think the concern is with altering tongue weight, but rather the well-known separation of the shell from the frame, caused by the rear frame weight increasing frame flex that the shell does not participate in. The connections of the two eventually fail and the shell and frame separate.
Doug and Cheryl
Old 12-02-2014, 11:52 AM   #4
millertimeUS's Avatar
1976 25' Tradewind
For all those more engineering savvy than myself....
I had my 1976 Tradewind frame completely redone with fresh steel and the new main 5 in rails are 1/4 in tube steel. Any thoughts on my adding an accessory receiver and a spare tire rack?
Name:	ImageUploadedByAirstream Forums1417542743.279757.jpg
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
exterior storage wire stop break Tim_S Exterior Storage Compartments & Access Doors 6 05-10-2010 10:00 PM
Exterior Hitch Storage Levon Hitches, Couplers & Balls 8 07-06-2009 03:43 PM
Seals For Exterior Storage Doors DEITZ645 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-25-2008 10:42 PM
Exterior Storage in the rear? darkStar Our Community 22 07-31-2003 08:56 PM
