Old 03-17-2018, 06:29 PM   #1
1969 23' Safari
Mohnton , Pennsylvania
Door knob retrofit
Last year we had alot of problems with the door lock, the locksmith did get it to work for a temporary fix. I was surprised that the parts arent available for these locks or very expensive. I came up with a retro fit with reusing the original internal latch that goes thru the door. The vintage trailer lock assembly will not work with a long barrel latch assembly.
I ended up parting out the new lock assembly and retrofitting it into the old latch assembly. not the best looking from the outside but this is a user trailer not a restoration queen. Door locks now and life is good.
69bullet is offline   Reply With Quote
Old 03-17-2018, 06:37 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
That looks very good to me, you did a fine job. Very clean and definitely not hacked together.....nice work. Retrofitting a new entry lock hardware can be very tricky to get it to blend in as well as you did.
mayco is offline   Reply With Quote
Door lock retrofit for 2006 International CoSchoHo Windows, Doors, Locks & Vents 2 10-28-2017 11:21 AM
Screen Door Retrofit? Semmons Sprinter and B-van Forum 3 12-02-2014 10:07 PM
Exterior Door Knob??? Neighbors overspray? 64 Lawncondo Doors & Locks 3 09-15-2005 10:37 AM
need door knob/lockset '61 Overlander 61Overlander Doors & Locks 1 12-01-2003 12:59 PM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
