Old 04-17-2019, 07:50 AM   #1
1972 23' Safari
Clarkton , North Carolina
Bertha Restoration - 1972 Twin Axle Safari
Bertha is a trailer with a lot of potential . . . she also needs a lot of work.
So far we've removed the carpet and front gaucho to better access the subfloor.
Subfloor has significant issues in spots and the belly pan is full of wet insulation and yard trash, so this weekend we removed a large section of belly pan to start cleaning her up.
The very rear of the trailer frame has significant rot and will need repair (more on that later). We also plan to replace the entire subfloor. New axles are on order, as well as a carport to store Bertha under. We hope to remove some more belly pan this weekend, and I'll update this thread as time allows. I also have a blog with a few more pictures and color commentary - https://adventuresinaluminum.blogspot.com/ Any recommendations as we go along are welcome.Thanks!
Lydia
Old Yesterday, 08:10 PM
Wildwoman69 is offline   Reply With Quote
Old 04-18-2019, 07:08 AM   #2
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Build thee a gantry. You will need it when you separate the frame and shell.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 04-18-2019, 09:24 AM   #3
1972 23' Safari
Oh yes, gantry method for sure, but I think we have a cheat. We have two 40 foot HC shipping containers sitting 12 feet apart. It's where we park our tractor and we always meant to put a roof over it, but it's open space at the moment. A simple structure made of lifted 4x4s laid across the tops of the containers should work well for removing the shell . . . or at least that's the plan
Thanks!
Old 04-18-2019, 09:54 AM   #4
1972 25' Tradewind
Denver , Colorado
Perfect! If you've got any 12ft. steel I-beams laying around (sounds like you've got a "farm situation"), even better!
You shouldn't even need a "structure" if the shipping containers are high enough (just two crossbeams laid across that you can hang chains from). Otherwise, even just some cinder blocks would likely do to lift the crossbeams higher.
Good luck! And get ready for it to take a lot longer than you expect! (but it'll be worth it!!!!)
And since you're going "full bore" on the project with a complete floor replacement and framework, I'll plant the seed of thinking about radiant heat. I used to think it was a bad idea (road vibration and hydronics not mixing), but I have changed my tune. After a lot of winter camping, I have come to believe that a warm floor that can also keep tanks from freezing is definitely something to consider! And though they are pricey, you can get a heating unit that will do hot water for sinks/shower, heated fluid for the radiant heat, and some even have a small forced air unit for occasional *quick* heat to the cabin.
Old 04-18-2019, 12:29 PM   #5
2007 22' International CCD
Please don’t use ‘cinder blocks’ to support heavy loads. They can easily crush and drop stuff on you. They are intended only for masonry walls.
Wood blocks or cribbing is safer if you need to shim something up.
Old 04-18-2019, 05:56 PM   #6
1972 23' Safari
I'll have to look into the radiant heat option. It does sound nice and I hate being cold! Always on the lookout for an I-beam or two, but haven't found any yet. Hubby says a couple of 2x6s screwed together will have to suffice for our cross members. The containers sit on concrete blocks and max out at 10'2". The trailer appears to be 9 feet total (once the AC is gone). I'm thinking we'll need to lift the beams a bit to get good clearance, but I don't think it with be too hard to manage. Thanks for all the great suggestions folks
Lydia
Old 05-24-2019, 08:24 AM   #7
1972 23' Safari
New Axles, New Tires, New Shelter
Last week our new Dexter axles for our 1972 Safari arrived (thank you Colin Hyde Restorations), so I promptly ordered new rims & tires, and somehow convinced Scott to help me install everything over the weekend. We thought it would be a one day event, but it took us a day and a half (10 hrs total labor) and left us both a little sore.
Here's what the old axles looked like. They got us home after the purchase but were in horrible shape and dangerous to use, so we made replacing them priority #1.
We also decided to go with a 3.5 inch lift kit so Bertha would better line up with Emmy Lou (our F-350 tow vehicle) and not be so inclined to bottom out.
New axle #1 is pictured below installed with lift kit and new shocks. We also used Ospho to treat the rust on the frame and then painted everything black. We'll eventually treat and paint the entire frame when we repair it, but that's a project for another day. Who am I kidding, that's a multi-day project!
At the end of day 1, we had one new axle (plus new shocks and tires) installed, and you can really see the difference the lift kit makes. We got the tires (Contender ST225/75R15 Load Range D with Silver Mod Wheels) from eTrailer online, and they arrived 2 days after being ordered. The Dexter lift kit came from Colin Hyde Restorations.
On day 2, we took the new wheels back off and jacked everything up an extra few inches to give us more work space under the trailer. Then we removed the second axle, which gave Bertha a free flying look sitting on the 3-ton jack stands. Thankfully we had two beautiful (although hot) days to work on this project, and the beat up old Carefree awning (which needs new fabric and a few other parts) provided some much appreciated shade.
As you can probably imagine, thanks to freshly acquired knowledge, axle #2 went up much easier than axle #1. Unfortunately, none of the original axle holes were in line with the new axle mounting holes (or lift kit mounting holes), so we had to drill eight fresh holes in the steel frame. That was probably the most difficult part of the installation as the drill bits wanted to wander away from their intended targets, but thankfully we have lots of nice tools. Our die grinder was probably the most valuable, as it allowed Scott to finish off all the drilled holes exactly as intended.
The pups like the new look and have indicated they are ready to travel anytime.
Although Bertha looks ready for the road, at minimum the running gear needs to be redone before we take her out "tent camping." We may just go straight into disassembly of the interior, but we have no firm decision on what we'll be diving into next. As always, we are mired down in too many projects and have to pick and choose our poison each weekend.
Old axles went to the dump yesterday . . .
. . . but I still have the original rims, tires, and moon hub caps. The tires are trash, but if anyone is interested in the rims and moon hub caps, let me know.
Last, but not least, Bertha got a new home a couple of weeks ago, and we moved her in last weekend. She has a Kubota for a roommate, but so far they are getting along well
Old 05-24-2019, 08:55 AM   #8
75Excella500's Avatar
1961 16' Bambi
1975 31' Excella 500
Sanford , North Carolina
Congratulations, axles look great.
Ralph
75Excella500 is offline   Reply With Quote
Old 05-24-2019, 10:38 AM   #9
1972 23' Safari
Thanks! It's a good start.
Bertha's Restoration - 1972 Twin Axle Safari Wildwoman69 General Repair Forum 2 04-17-2019 07:37 AM
Bertha :: 2006 Airstream Safari ElliotA Airstream Registry Discussions 0 04-07-2016 03:46 PM
Resurrecting Big Bertha... or, 'How I spent $30,000 on a $2,000 trailer...' Panama Red 1974 - 1979 Sovereign 251 02-10-2015 07:08 PM
Bertha :: 2012 Airstream International Signature Msdixie Airstream Registry Discussions 0 11-22-2011 08:39 PM
Big Bertha :: 1978 Argosy stgerdonly Airstream Registry Discussions 0 08-19-2011 08:32 AM
